460 c6 37's. what gears? - FSB Forums
Thread Tools Display Modes
Old 12-05-2012, 10:38 AM   #1
BIG GUY
This is my first post since getting my 79 xlt ranger. It has the 351m c6 in it now with 3:50 gears. Its gonna get street driven a lot with occasional trips offroad and to the woods for camping/hunting. Maybe a 500 mile weekend trip here and there. I'm working on my 460 build right now and I'm building the motor to hit 500ftlbs torque below 2000 rpm. The c6 is notorious for sucking fuel but I'm keeping it anyway with a stock converter. My thinking is that with a torquey 460, stock converter with stock gears my RPM's will be lower and I can get better milage( I'm not hoping for much I know it's a 460)
my question is will the 3:50's get me better fuel milage wih a motor that has 500ftlbs of torque below 2000 RPM's. I'm thinking like a diesel guy!
Thanks.
BIG GUY is offline   Reply With Quote
Old 12-05-2012, 01:34 PM   #2
wdford
wdford's Avatar
Bronco Info: 1995 EB 351W, E40D
With that much torque keeping the revs down will aid in fuel economy. But honestly if you're runing a 460 fuel mileage should not be a concern. I'd shoot for about 1500 to 1650 steady state cruise...
wdford is offline   Reply With Quote
Old 12-05-2012, 01:44 PM   #3
BIG GUY
I agree about the mileage and a 460. I'm sure someone has ran the is combo. Just wanting to hear some feedback. Maybe the engine would live longer too?
Last edited by BIG GUY; 12-05-2012 at 01:46 PM. Reason: Posted accidentally befor I was done.
Old 12-05-2012, 03:05 PM   #4
Robs79BBbronco
Robs79BBbronco's Avatar
Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
the 3.50's will be great on the hwy, but stop & go traffic or pulling a load will probably remind you of the 351m again.500 ft/lbs.?sounds good already....how about some engine details?
Robs79BBbronco is online now   Reply With Quote
Old 12-05-2012, 04:19 PM   #5
BIG GUY
The engine is on the garage floor right now. Lol. I've been following some builds on the 460 forum and a 545 stroker is just the ticket for gobs of torque down low. I figured with this much torque I could get away with higher gears. For offroad I'm looking at the 205 doubler. I've built a few jeeps but a 79 bronco has always turned me on and now I own one!
Old 12-05-2012, 06:48 PM   #6
badass1tonf100
Hit it n' Git it
badass1tonf100's Avatar
Bronco Info: 4 wheels, 1tons, 3 sticks, sheet metal & some tubing.
4:10's or 4:56's would give you best all around performance DD, offroad, and hauling
badass1tonf100 is offline   Reply With Quote
Old 12-05-2012, 10:22 PM   #7
96XLTJD
96XLTJD's Avatar
4:10's
1996 XLT, currently leveled, getting a bigger lift soon.
5.8L E40D, push button 4x4, auto hubs, custom front bumper.
96XLTJD is offline   Reply With Quote
Old 12-05-2012, 10:25 PM   #8
mickaila
not banned
Bronco Info: 82 XLT Lariat, 351W, C6, NP208, 4.56:1, 37x13.5s, all sheet metal replaced
you said 37s right? --> 4.56
Where we go one, we go all.
Mickaila's Rebuild
Originally Posted by Redwagon View Post
I guess most of our members are just WEB WHEELERs and dont need public land?
mickaila is offline   Reply With Quote
Old 12-05-2012, 10:35 PM   #9
BigBud
You thought what......
BigBud's Avatar
Bronco Info: Sold the 79 waiting for a next to free 80s to snatch
I have 3.55 in mine and a stock c6 converter. It's pretty darn nice. Don't need an overdrive to get decent mileage and the 460 has plenty of torque to take off even with a moderate load. I've pulled a trailer through soft fields in high range just fine. 4lo is still fast enough for the sand too.
79 Bronco 6" lift, mild 460, and 3/4 tons----Sold
94 F150 4x4 302 zf5spd swap----run about
97 F350 Crew Cab 4x4 4" lift---work beast
Old guys,......they're tricky.
BigBud is offline   Reply With Quote
Old 12-05-2012, 10:42 PM   #10
Black_mamba
Black_mamba's Avatar
Bronco Info: 1979 ranger xlt 400 cid with holley street avenger. 35 inch thornbirds
Roomate has a 429 in his ranger with 4.11's and 38's and is changing to 3.55's. On the highway he's at 3,000 rpm with the 4.11s
Black_mamba is offline   Reply With Quote
Old 12-06-2012, 09:04 AM   #11
CBboots
CBboots's Avatar
Bronco Info: 79 Custom, 460, C6
JBG's hard-copy parts book has a gear ratio chart, showing rpms and tires. I just checked and they don't have it online, just hardcopy. The chart shows what gears to run for the optimum rpm range for the best fuel economy.
I'm got 35s...460...C6...Holley Truck Avenger....running 4.56.
I get 5 mpg.
My 79 build http://www.fullsizebronco.com/forum/...d.php?t=207864 - Aluminum 3-core radiator, Mallory 85 HEI conversion distributor, High Angle Driveline One Tons front and rear, JBFAB Twin stick shifter kit, True trac differentials front and rear, Yukon 4.56 gears front and rear, Moser Extreme 31 spline rear axles, Borgeson adjustable steering shaft and rag joint, 95 amp 3G alternator, Fireguy/RJM Tech upgraded headlight harness, and a ton of other crap!
CBboots is offline   Reply With Quote
Old 12-06-2012, 03:29 PM   #12
BIG GUY
I know the gear charts are accurate for getting back to stock RPM's and such. But this is not gonna be a stock engine. For crawling work ill be running a 205 doubler.
What RPM's would I be at with 3:50's 37's and 60mph? Like I said, I'm building the engine to have peak torque very very low.
Old 12-06-2012, 04:36 PM   #13
huggyb1972
Dirty Minded
huggyb1972's Avatar
Bronco Info: 89' Bronco 5.8l Variable Speed V8, Forward, Rev, Turns left, right, stops, and everything.
I'm running 4.10's and 37's with a stock 351w and the cruising RPMs are a little better than with 35's but not by much I can give a solid number but I'm thinking right a round 2500 @ 65. I've got good enough power but I don't need to go fast anyway and it will pull a 5% grade with the cruise on loaded at 70MPH and still walk off and a leave land rover.
DRAFTHORSE
351W, C-6, 10.25/D44
FOTM DEC. 2011
"Quando Omni Flunkus, Moritati,"
When all else fails roll over and play dead.
I'm as Free as Federal, state, and local laws/ordinances allow.
huggyb1972 is offline   Reply With Quote
Old 12-06-2012, 04:47 PM   #14
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
RPM = (Speed * Transmission Gear Ratio * Final Drive * 336) / Tire Diameter
Roughly 1900 RPMs.
How fast is he going? If that's accurate, you'd need to do 80+ to get those RPMs with those tires and gears.
1981 & 1984. Both w/ 300 I6. Holley 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 12-06-2012, 05:01 PM   #15
Robs79BBbronco
i would still switch to 4.10's regardless.
Old 12-06-2012, 05:44 PM   #16
BIG GUY
Thanks for the input. 1900 RPM's sounds great! That's will help with planning the rest of my engine build. Not that I'm drag racing but some of the drag guys that go from a standard 460 up to a stroker will put in higher gears and have a better et's. Apparently with massive amounts of torque down low higher gears can net better acceleration. I've been doing my homework on this and was looking to see If its been done for a driver.
Old 12-06-2012, 06:51 PM   #17
BRONCONUT
Local # 40 Boilermakers
BRONCONUT's Avatar
Bronco Info: 5.8 w/ MSD, optima, K&N, OBA, 8 lugs, Detroit w/ 4.88's, 4 wheel disc brakes & Kick ass camo,
I would go with the 4.56 just for the simple fact that you have a 460 and if your like me you want to have that response off the line.
BRONCONUT is online now   Reply With Quote
Old 12-06-2012, 07:31 PM   #18
BigWheelz
Bronco Info: 1978 Bronco, 466 EFI
I have a 460, C6, 3.50 gears,& 35's. The truck runs great. The 460 has no problem spinning both 35's from a stop....
Opportunity is missed by most people because it is dressed in overalls and looks like work- Thomas A Edison
BigWheelz is offline   Reply With Quote
Old 12-06-2012, 09:40 PM   #19
f150inline
f150inline's Avatar
Bronco Info: f150
i would go 4.56.
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs. My build thread http://www.fullsizebronco.com/forum/...d.php?t=213623
f150inline is offline   Reply With Quote
Old 12-06-2012, 11:05 PM   #20
ProBronco
ProBronco's Avatar
Bronco Info: 80 Bronco XLT 302 4sp, 4"lift on 35" Factory LS F&R
Dumb post, really ??? High torque engine and U nwant 4.56-4.11.
3.73 would be max CAUSE a 460 is a low rpm engine high torque.
What are U gonna do in 4 low spin to 6000K !! Good luck with that !!
The DUDE Master 460
ProBronco is offline   Reply With Quote
You may not post replies
Forum Jump
