| Sponsored Links | |||
Advertisement | |||
#2 |
Thanks 351w500
![]() ![]() Join Date: Mar 2005
Location: Northcentral,CA.Twain Harte, up here in the mountains
iTrader: (52) Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
did you search for them?
![]() I take Prayer Requests. God Bless |
#3 |
Man with a Golden ticket
![]() Join Date: Jul 2007
iTrader: (0) Bronco Info: 96 blackout XLT Sport 5.8L E4OD, 4" Rancho w/ 35" MTR's
If you are wanting information on where you can go and get them from a 4x4 supply place rather than online you don't even have any information on your location that others here can let you know about.
And like he says, try searching first so you at least have some idea what you are looking for.
You just might be a redneck if you start a conversation with: ![]() "happened to us when Dad got pinched by the feds." - Biker Pepe' - |
#4 |
I used to know this stuff
yo 3X'sacharm,
I have some sources for flares in my site @ http://www.broncolinks.com/index.php?index=459 scroll to; Flare some examples; Flare, Bushwacker Cut-Out Installation Instructions; 78-96 "...This Flare adds 3¾" of tire coverage; Front Part # 20021-11, Rear Part #20022-11; Available in a no pocket cut-out design; Offers extreme tire and wheel coverage, allowing you to increase the wheel well opening to accomodate large tires and wheels; Exclusive Dura-Flex® material fives maximum durability and flexibility while maintaining its shape during extreme conditions; OEM matte black finish, or easily custom painted to match or accent any vehicle..." Instructions also available for various Flares in 78-79, 80-86, 87-91, & 92-96 Source: by bushwacker.com http://www.bushwacker.com/Instructions/20021a.pdf Flare, Bushwacker Extend-A-Fender Installation Instructions; 92-96 Ford Bronco; "...Set Part # 20904-11; This Flare adds 1¾" of tire coverage; Also sold individually, Front Part #20019-11, Rear Part #20020-11; Adds additional coverage, great for large wheel and tire packages 100% UV protection. No chalking, No cracking, No warping; Exclusive Dura-Flex 2000® gives maximum durability and flexibility; OEM matte black finish, or easily custom painted to match or accent any vehicle..." Instructions also available for various Flares in 78-79, 80-86, 87-91, & 92-96 http://www.bushwacker.com/Instructions/20904.pdf Flare, Bushwacker Single Piece Street Flare Installation Instructions; 92-96 Ford Bronco; "Set Part # 20501-02; This Flare adds ¾" of tire coverage; 100% UV protection. No chalking, No cracking, No warping; Single-piece design and construction; OEM matte black finish, or easily custom painted to match or accent any vehicle..." Instructions also available for various Flares in 78-79, 80-86, 87-91, & 92-96 Source: by bushwacker.com http://www.bushwacker.com/Instructions/20501.PDF Flare, EGR No-Drill, Bolt On, Rugged Look, Thermoplastic; Flare Width, 1.500 in.; Product Dimensions, 44 x 23 x 6" Source: by egrusa.com http://store.egrusa.com/products/316281/Bronco Flare, Street Scene Installation Instructions for 92-96 Source: by streetsceneeq.com http://www.streetsceneeq.com/instruc.../950-58400.pdf
96 XL 5.0 E4OD, Man Xfer/Hubs USN (Ret) & MIL/DoD Contingency Planner (ret) THANKS to ALL WHO SERVE! my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php |
#5 |
![]() Join Date: Jul 2009
iTrader: (1) Bronco Info: 90' 351/E40D 38" tires, 4.88 gears, full float 8.8, lockers F&R
I have the cut out flares on my current 90' Bronco and my old 88' Bronco. Before I sold my old Bronco, I removed all the expensive mods including the 14" wide wheels and 15.5" wide tires. I replaced them with 12 x 35 tires on 10" wide wheels. I have to tell you that it looked kind of funny with those big ole flares and 35's. It made the tires look small. It also looked narrow because the flares stick out so far. You might want to consider this before. The other problem is their strength. Mine are some what protected by my wide tires (my tires are atleast 5" wider than the flares) and I still cracked them hitting stuff. Not saying I don't like them. They look great. But I wish they were a little stronger.
#6 |
yo,
Also in my site; Flare Info & pics in an 81; "...I wanted to install fender flares in my truck but they are not available in my country (Argentina).....so I got a set of cheap Warn flares in bad shape and sent them to make a copy.....Today I got the first set and installed them....the cost for each set it will be about $100.- bucks!!..." Source: by Henri at uc4x4.com Flare, Modification; "...Heres what jeep flares look like, i went to the junkyard and they let me have 8 for 30$ and i only used 2 on the back, just marked it for the flare contour, got out the old air nibbler and i like the way it turned out....but my main reason was to cut off the rusted thru parts of the quarter..." pic is gone Source: by sparkysmotorsports at karting.4cycle.com Flare, Modification; "...i used flares off of a 98 ford explorer sport 2 door 4 door wont work. the fender radius is almost the same. only mods i had to do was where the "V" shape is towards bottom of truck i had to slightly mod the flares by cutting them with a die grinder. the screw holes along the fender lip also matched up nicely. it tooka couple of days of trial fitting but they look nice. and along the top i instaled small bolts so they look the pocket flares made by bushwacker. this was necessary to hold them tightly to the body. it cost me a total of 50.00 to put these on. flares where 30.00 at pull a part auto wrecking..." Source: by shad351 at FSB
#8 |
ate lug
![]() Join Date: Apr 2003
iTrader: (4) Bronco Info: 88ish bronco(?)/96 F250; both with D60s
Im not so sure they even make them for our trucks anymore. I had to replace a flare on my 96 back in spring, and i couldnt find any in the pocket style.
#9 |
I thought "pocket" refured to the little countersunk mount bolts on my cut-out flares. If this is not true, please explain what they are. (or pics)
#10 |
ate lug
Yes thats correct. They used to be available as regular or cut-out flares, but these days it seems the pocket style arent available at all for our trucks.
#12 |
I just looked on the Bushwacker site and they still list cut-out flare for my truck (90'). It says with "screw pockets".
#16 |
Curious, I just got a quote from Woody's 4x4 here locally and mine is a 96?
Maybe they knew the ones for earlier model years would fit? I will have to ask them about this. I love the pocket style, I just wish they didn't stick out 4" from the fender, Looks funny to me unless I run at least 14" wide tires. I run 12.5" now and they barely extend beyond the fender well. The reason I didn't buy them then is I was wanting to see if there was a pocket option out there that didn't stick out so far.
#17 |
ate lug
I think theyre different up front, because of the different bumper & shape of the corners. I want to say that the older style flares come down lower than the newer ones, but its been a long time since ive seen a 87-91 with flares. Bushwacker must specify a different part # for the two styles (91/92) for a reason.
#18 |
Local # 40 Boilermakers
![]() Join Date: May 2007
iTrader: (20) Bronco Info: 5.8 w/ MSD, optima, K&N, OBA, 8 lugs, Detroit w/ 4.88's, 4 wheel disc brakes & Kick ass camo,
They do come down a bit further. There was a guy wo put them on his late model in the last year, he did a d60 sas on a red late model.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
