#1 |
Is 250 a fair price for a ZF5 with 5th gear out
Just wondering what these things are going for. A guy wants 250 for one, came off a straight six 4.9 4x4. Says it wont go in 5th gear. So I'll be tearing it apart or using it as a core.
| Sponsored Links | |||
Advertisement | |||
#2 |
iTrader: (0) Bronco Info: '89 bone stock. Got 3/4 of parts for spring resto and disel swap tho!!!!
my local junk yards charge 150 for manual cores, of unknown working quality, knowing you play to rebuild it.
That said, 250 for a rebuildable core is high, at least for my area (central PA)
** 1989 Bronco XLT - 7.3 idi NA / ZF5 speed conversion underway. Build thread http://www.fullsizebronco.com/forum/...=1#post2865645 |
#3 |
Thanks 351w500
![]() ![]() Join Date: Mar 2005
Location: Northcentral,CA.Twain Harte, up here in the mountains
iTrader: (52) Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
keep looking. also it wont be a ZF5, if it was behind a 4.9 it was/is/should be a Mazda tranny= not even worth 250 if it worked perfect.
![]() I take Prayer Requests. God Bless |
#4 |
Big Six
![]() Join Date: Feb 2006
iTrader: (1) Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
Couldn't it be a ZF5 if the 4.9 was in an F-350?
1981 & 1984. Both w/ 300 I6. Holley 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust. Supermotors Pics |
#6 |
1/2 the 1/2 tons w 300s and 5 speeds were ZFs. the other half were Mazdas.
OP, $250 for a core trans is too much. A GOOD WORKING one is worth $250
96 Bronco 347? 5spd 6" procomp 35" Dick Cepeks And a ton of other Ford trucks |
#7 |
Allright I'll keep looking around, I dont need it now. I have the m5od now and its getting to be a pain (I think some synchros are gone), but it still works fine. Just trying to find one for a decent price.
#9 | |
AKA: Butthead
iTrader: (0) Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
make like 1/2 ton's (F150's, U150's and lighter F250's) could-have a ZF in it. ...As if it was an option or something? :) (its' been a while since I read it) Alvin in AZ ps- You know, when it comes to Ford making stuff it's best not to use words like: "never" or "always". LOL :) HolmanMoody and Shelby and others made stuff and the guy picking it up at the dealership wouldn't know the difference. pps- At work we had an old Ford/Utility(?) line-truck. F700? Body style was prior to the Bump Side (I don't know what that body style is called). ppps- "line truck" ...for linemen. ;) Any other new or old linemen on FSB? :D |
#10 |
Yeah. I have been around quite a few ZF equipped F150s. Every one was a 300 6cyl. and 2 of them were original owners that nothing was ever done other than oil changes and brakes(by the dealer) so i know they were not swapped in
#12 |
Salt blows goats for fun
![]() Join Date: Aug 2004
iTrader: (8) Bronco Info: 2006 Kia Spectra
never ever seen one or ever hear of a zf in a half ton. maybe they do exist but they are probably as common as the 302/aod combo in an f250 (rare bird)
#13 | |
AKA: Butthead
ppps-
That's an 8 pound (small) sledge hammer there. And the open-end wrench in the 2nd picture is a 15/16"x 1". Those are pretty big gears, bigger than a T18's. I can shift my T18 quicker than my ZF. It's "supposed to be that way" according to guys that actually know something. (not me :) So... when you swap to a ZF don't be looking for it to shift as fast as your old Mazda could. ?? Quote:
You mean their "position" so 5th is back and reverse is forward? :) --------------------- 5th gear has its teeth slanted the same direction as the other forward gears but reverse's gear teeth are slanted the other direction... See? :) That's reverse there in the middle... {with its teeth slanted the "other way"} ![]() 5th gear at the bottom. {these are all driven gears on the main shaft} {a beefy} 1st gear at the top. 2nd gear laying there on the wood. (wood has a 15/16" hole in it ;) 3rd gear isn't in the picture. ...and there isn't a "4th gear" at all. ;) Alvin in AZ ps- GB sez he got it from here but I can't hear it, and he don't understand it. Got any ideas? http://www.youtube.com/watch?v=JuXi7TXYpSY pps- The shaft at the top is the "input shaft", just below it is the "counter shaft", I think some guys call that the "cluster gear"(?). Anyway the gear teeth that are cut-right-into-the-shaft is first-gear's drive-gear... ![]() Those two shafts are pointing the same direction and the "main shaft" off to the right is pointing the opposite direction. So, 5th gear is on the left-end of the main shaft (mostly hidden by the bearing splitter) and 5th gear's drive-gear is on the right-end of the counter-shaft. ...I'd sure like to know how they can be "swapped"! LOL :) |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
