another set of broken motor mounts - FSB Forums
Thread Tools Display Modes
Old 12-07-2012, 05:17 PM   #1
85turdburger
Bronco Info: 85 Bronco, 300 straight 6, early carb and dist conversion, 33X10.50 4inch rough country lift
Ok guys, here's the problem I'm having with my old girl. I just broke my second set of motor mounts and I'm trying to find a suitable replacement. Either poly or solid. I was doing some mild flexing when this set popped. The first set was Indian Napa brand, the second set were anchor's from Advance. I've been searching the forums and haven't come up with much for the 300. I know I saw some threads that were saying the O'Reileys brand were made in the usa. Anyone running these brands? I've checked my trans mount and its not broken or bad. It's an almost bone stock engine so I wouldn't think the torque would be enough to keep breaking these. The first time I broke the drivers mount so I replaced the pair, second was the passenger mount so again I replaced the pair. I've checked Jeff's website and he only has listings for rubber mounts. I don't mind these but I just don't want to keep dealing with this. Thanks in advance
85turdburger is offline   Reply With Quote
Old 12-07-2012, 06:28 PM   #2
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
I could not keep a drivers side mount on my 78 bronco. I finally cut the stud off flat than drilled through the whole mount where the stud was. Then ran a grade 8 bolt all the way through it. Put it on with a lock nut snug but not cranked down. The lock nut will hold it. Never broke that mount again.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 12-07-2012, 07:30 PM   #3
kemicalburns
Never Done
kemicalburns's Avatar
some will also use a chain to secure the motor. I had the same issue back in the day in my old hi-boy. the 300-6 is torquy.
94 XLT 357/E4OD Trans-go stage II
6" Stage II ProComp,35x12.50BFG/AT
4.88 f (aussie) / r (open) / Custom Sliders
JBA headers,Custom Y pipe hi flow cat & Full 3"
kemicalburns is online now   Reply With Quote
Old 12-07-2012, 07:38 PM   #4
yoomooman
my bko ate my money
yoomooman's Avatar
Bronco Info: 92 Eddie Bauer Bronco 5.0, E4OD,MAF Conv, sixltre tune-up, OBA, on 31x10.50x15s
the chain method works great
92 Eddie Bauer bronco 5.0--Travis
Originally Posted by jopes
11:47 pm: hand pack it on the shaft. it's somethign you should be good at
yoomooman is offline   Reply With Quote
Old 12-07-2012, 07:52 PM   #5
Steve83
Steve83's Avatar
Here's an idea: buy FORD mounts.
Old 12-07-2012, 11:27 PM   #6
zimmerkm
Bronco Info: 94 Bronco 5.8L Auto
I'm new to the forum, but I know Autofab in So. Cal. makes bulletproof ones using their bushings.
94 Bronco
87 F150 Pre-Runner
89 F350 Crew 4x4
zimmerkm is offline   Reply With Quote
Old 12-07-2012, 11:42 PM   #7
zimmerkm
Their number is (619) - 562 - 1740 . The P/N for the 300 straight 6 mounts is FT300N .
94 Bronco
87 F150 Pre-Runner
89 F350 Crew 4x4
Old 12-08-2012, 02:36 AM   #8
Kingfish999
Nothing beets a Fullsize
Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
i love my JBG poly mounts. i use toi break mounts every couple of weeks. yet to break these. they jsut need to make one for 300 and then a tranny mount to go with it
anyone know where i can get poly tranny mount other than autofab?
Kingfish999 is online now   Reply With Quote
Old 12-08-2012, 10:56 AM   #9
85turdburger
Thanks zimmer, I'm going to give them a call on Monday. If they can't help then ill have to bite the bullet and go with Steve's suggestion. Thanks everyone for your ideas. Im ready to get my girl back on the road.
Old 12-10-2012, 01:14 AM   #10
El Kabong
Driving Stuff Henry Built
El Kabong's Avatar
Bronco Info: -90 xlt, 351w, e4od, 3.55:1, sag, warn hubs, trans cooler, 35" bfg m/t, -73, 400, np435, 35s
I've used that method with good success on other engines that were hard on mounts. Snug but not cranking the bolt tight allows some movement, but keeps it from pulling apart. It solved the problem for me.
El Kabong is offline   Reply With Quote
You may not post replies
Forum Jump
