1996 Bronco exhaust ypipe ? HELP - FSB Forums
Thread Tools Display Modes
Old 12-08-2012, 12:49 PM   #1
Broncoxlt96
Broncoxlt96's Avatar
Bronco Info: Broncoless :(
Ok someone stole the exhaust off my truck from the last owner so now I need a new y pipe and cats. And the echaust from cats back because the muffler was rotted that's besides the fact... I need to find where I can buy a new pipe and 2 cats like factory could be aftermarket but must fit I need to pass emissons. I know where to find a cat back system that's not a problem but I need a ypipe and the 2 cats also the 96 has 3 oxygen sensors right?
(96 Bronco Xlt,93 frame,94 axles,96 body, 6 inch Rough Country lift 36x13.5 swampers) SOLD :(
1991 Bronco XLT ....stock for now
Just because it's rusty dosent mean it ant trusty
Broncoxlt96 is offline   Reply With Quote
Old 12-08-2012, 02:03 PM   #2
MudRider
MudRider's Avatar
Bronco Info: 96 XL 302-K&N-3" magnaflow exhaust no cats-33s-locker front+rear-4.10s-E40D-custom bumper-SOFTTOPPER
http://www.summitracing.com/parts/mp...d/model/bronco
This mall crawl session was brought to you by a pair of Aussie Lockers.
Ferris State University Automotive Engineering Technology student.
MudRider is offline   Reply With Quote
Old 12-08-2012, 02:34 PM   #3
Broncoxlt96
Are the 5.0 and 5.8 manifolds the same it says this is for 5.0 I have a 5.8
Old 12-08-2012, 02:38 PM   #4
c-dub
c-dub's Avatar
Bronco Info: 96 xlt 5.8 (blk) e40d
what motor, 5.0 or 5.8?
black 96 5.8 xlt sport, e40d, edelbrock intake, bassani y-pipe, bilstien shocks, 32"bfg's
azure blue 03 mach1 4.6 dohc
"Sorry - no matches. Please try some different terms."
c-dub is online now   Reply With Quote
Old 12-08-2012, 03:21 PM   #5
Broncoxlt96
5.8(351w)
Old 12-08-2012, 03:27 PM   #6
c-dub
c-dub's Avatar
find one for a 95. than you will have to add the bungs for the 02 sensor's. i did this with the bassani y-pipe.
Old 12-08-2012, 03:29 PM   #7
c-dub
c-dub's Avatar
yes, but no. the manifolds are the same, but the heads are wider apart on the 5.8. so the y-pipe needs to be also.
Old 12-08-2012, 03:38 PM   #8
Broncoxlt96
So would that link. Mud rider posted work if I also but a bung to weld in ?
Old 12-08-2012, 03:47 PM   #9
c-dub
c-dub's Avatar
no that was or a 302. go on the summit site and put your info in the search. just use 95 for your year. and you will need two exaust bungs also.
Old 12-08-2012, 03:53 PM   #10
c-dub
c-dub's Avatar
you will need the plug also
Old 12-08-2012, 03:54 PM   #11
Broncoxlt96
So order a 95 5.8 exhaust and order 2 bungs so do I just drill a hole in then weld two bungs in
Old 12-08-2012, 03:59 PM   #12
c-dub
c-dub's Avatar
some good info here, with my saga starting at page 6...
http://www.fullsizebronco.com/forum/...bassani&page=7
... helps if i post the link
Old 12-08-2012, 04:03 PM   #13
c-dub
c-dub's Avatar
after reviewing some old posts, you will need three bungs (one or each manifold and one ater the cat) and the plug for the cross over tube. i used one of those multi step drill bits to drill it out. just make sure you have the flanges in place when you get them welded on.
Old 12-09-2012, 01:17 PM   #14
miesk5
miesk5's Avatar
yo,
For exact replacement exh parts, I use Walker, who was and prob still is Ford's OE supplier (esp for our Broncos)
walker 16365 Sizing and Specifications
Item Weight32 Pounds
Height 12 inches
Length 44 inches
Width 26 inches
gOOgle part #s for best price; ask local parts stores beat or meet price w/out S&H
USN & DoD Planner (ret)
THANKS to ALL WHO SERVE!
Old 12-09-2012, 01:31 PM   #15
c-dub
c-dub's Avatar
wish i knew that when i did mine. after going to 3 shops that told be they could not find anything, i re-worked the bassani.
Old 12-09-2012, 06:28 PM   #16
Broncoxlt96
So could I just buy the 95 bassani y pipe and weld another bung in and call it a day does placement of bung matter
Old 12-09-2012, 09:11 PM   #17
c-dub
c-dub's Avatar
if you use the bassani you need to add a bung on each side bellow the flanges and one after the cat. you will also need to plug the co2 bung on the cross over tube for the 95 that the 96 does not use. best bet would be to look into the walker system that miesk5 posted.
Old 12-09-2012, 11:35 PM   #18
Broncoxlt96
I'm gonna order the walker setup thanks though
Old 12-10-2012, 02:46 PM   #19
miesk5
miesk5's Avatar
yo,
Shop around for Best price and ensure that Y is included I asked this @
http://www.amazon.com/Walker-State-S.../dp/B001FMJ634
Does this include the "Y" pipe from exhaust manifolds to converter as shown in image or is just the converters; are both converters included as shown?
check for a reply from seller.
$401.72
+ $16.30 shipping
Old 12-10-2012, 11:27 PM   #20
Broncoxlt96
It includes everything as shown in the picture
You may not post replies
Forum Jump
