#1 |
iTrader: (1) Bronco Info: 1996 Bronco, Eddie Bauer Maroon/Tan, 5.8 6in lift with 35 " kumho mt's (craigslist special)
custom built radius arms??
anyone built/fabricated their own or could point me to a write up?? Yes, tried searching but couldnt find anything
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Feb 2011
iTrader: (0) Bronco Info: 1995 EB 351W, E40D
What is it you want that you cannot find in the open market? I've seen a thread here where someone lengthened / modified his stock arms.
#3 | |
I know there are some aftermarket options out there, and a good majority of custom arms are on rigs with solid front axles. |
#4 |
I extended min with 36" 2" Dom tubing back to cross member.
I did not slide over existing but rather ran the entire tube up to 1/2" before housing, the Stock arm I cut reliefs so 2" would slide in then it was reinforced with angle. Moved the stock brackets back 15" |
#5 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
I got a set of used rancho extended arms for $75 and plated them for anouther $20. Never going to bend or brake them.
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#6 |
i have a 6" lift and put the drop brackets in for the stock radius arms, yes in the future I plan on doing the SAS, but for now sticking with what i have. I am asking about the custom extended radius arms because I figure I can just build a pair for less instead of buying something for over $400, so just looking for ideas
#7 |
Thanks 351w500
![]() ![]() Join Date: Mar 2005
Location: Northcentral,CA.Twain Harte, up here in the mountains
iTrader: (52) Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
search for custom extended RA here. there are plenty of threads on them.
![]() I take Prayer Requests. God Bless |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
