#1 |
High Compression and low oil pressure
Getting my fresh motor ready for swap, yesterday I ran motor on stand with water and my oil pressure would not go above 10-15 psi.
I've search here and other stand forums for possible causes and the list below is what I will check when i get home as I'll drop the pan. Will get a mech guage, currently have a stang sender to autometer guage. Timing cover oil galley plugs Rear plug I know it's good I checked it twice between runs Clogged oil pickup Oil pickup with crack sucking in air Oil pump press relief stuck open Worst case spun a bearing It's run fine the past two weeks in the stand Another question, I spun the motor over without power to Coil and the motor fired and ran for a good 2-3 mississippi seconds on its own. Is this norm? I've had motors not shut off in an old 361 LTD but spooked me on starting. I have a 7.3 and I was just turn the motor over to check for oil in sensor passageway. |
| Sponsored Links | |||
Advertisement | |||
#4 |
Bearings where in spec. Motor was primed several times before first start. Motor ran fine last weekend and this week
It's a .010 over 302 from a 99 explorer with gt40p heads, comp cam, FMS headers, std oil pump, 7 quart pan from explorer which I made pickup tube for. Also read assembly lube could have blocked the filte. I Have motorcraft filter on it. I did use rtvin the valley but I it cure for 6 hours only wonder if it's plugged up somewhere |
#7 |
Salt blows goats for fun
![]() Join Date: Aug 2004
iTrader: (8) Bronco Info: 2006 Kia Spectra
NO. a stock pump is MORE than adequate for this build. OP, fix the problem, don't band-aid it with an hv pump. those are for extreme high performance applications.
#8 |
Sorry I built a stock motor so stock pump was used, infact everything is factory except the cam. I read up a lot from Ryan's post with headers to the gt40/p reviews.
#10 |
Installed mech guage Cold start idle at 55-60 settled down to 40 after 3 min.
Bled line a few time to make sure but revving it gets 60 psi. I have some diesel oil in there mixed so its a bit thick. Blew out freeze plugs oops forgot drain water guess new brass ones go in now What gives why would an auto meter guage give low reading with new sender. Oh well. |
#12 |
No not really! I forgot to drain water and two of freeze plugs popped. So I'm going to run it tonight then do a tear down to check and replace all plugs.
I know brass is preferred, why? I can only think dissimilar metal they will Expand a bit faster, rust resistance is better. If I'm good on my cooling std iron should suffice. I can't remember if there are plugs behind timing cover? Are those freeze plug heaters any good? |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
