ran oil pan dry. pump wont prime - FSB Forums
Thread Tools Display Modes
Old 12-10-2012, 06:49 PM   #1
Kingfish999
Nothing beets a Fullsize
Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
i installed a oil filter relocation kit and a big cooler today plus replaced the pressure sensor. being distracted i forgot to connect a line. strated the engine and all my oil pumped out to the ground . i reconnected the line and put another 5 quarts of oil in it started it and guage wasnt working so after messin with the wire some starting it to test i never got it to work. thinking the new sensor was bad i checked to make sure oil was flowing so i loosened the filter where it would leak. no leak so i took it about half off with a big gap and absolutly no oil is flowing. oil is full. after starting the engine numerous times i think the pump would have primed itself by now. any ideas?
Kingfish999 is offline   Reply With Quote
Old 12-10-2012, 07:11 PM   #2
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
could have toasted the pump. pull the dizzy and use a drill to turn the pump over till you see oil pressure.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 12-10-2012, 07:15 PM   #3
inxy
Bronco Info: 88 Bronco 351 C6 33's redhead/saginaw
Something may be clogged. "To avoid the need for priming, the pump is always mounted low-down, either submerged or around the level of the oil in the sump. A short pick-up pipe with a simple wire-mesh strainer reaches to the bottom of the sump' (not my words). Or possibly not enough oil. A bigger cooler plus the hoses for the remote filter require more oil than the 5 quarts. Possibly with the five qts you just filled the hoses and cooler. Bad ol pump, hard to believe.
inxy is offline   Reply With Quote
Old 12-10-2012, 07:19 PM   #4
jopes
gone fish'n
jopes's Avatar
running the engine with no oil is pretty much saying your gonna rebuild it.
Let's Go Fishing.
Old 12-10-2012, 07:37 PM   #5
Kingfish999
its gonna be rebuilded soon. jsut not now. well with 5 quarts the dipstick is over. im going to prime through the dizzy when i can get access to a timnig light. i might try and take the hose loose and pouring oil through it to help prime the pump.
Old 12-10-2012, 10:17 PM   #6
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
The pump shouldn't have to be primed. It's not new.
Mark the distributor where the rotor is pointing and pull it. You won't need a timing light if you do so. If you ran it dry, the oil pump probably seized and the pump shaft should be broke. Listen closely once you pull the distributor because you just may hear half of the oil pump shaft drop into the pan. If this is the case, you'll see it once the distributor is pulled and you try to prime it.
You're probably looking at a costly mistake........
~ Scott ~ ~ Ford's, please bring back the Bronco!! ~
~ My Exhaust clip on YouTube ~ 203k on the odometer and no longer a daily driver. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
sackman9975 is offline   Reply With Quote
Old 12-10-2012, 10:43 PM   #7
JBfab
JBfab's Avatar
Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
now you done gone a did it.
It's not custom if you bought it from a catalog!
Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825
JBfab is offline   Reply With Quote
Old 12-11-2012, 05:16 AM   #8
garymunson
Bronco Info: 93 XLT, 5.8, E4OD, manual Xfer & hubs
If you think it's a problem with no oil pump prime, the old redneck trick to prime it is to disable the ignition, dump a couple gallons of cheap wallyworld oil in the crankcase and crank it until you get pressure then drain the extra oil. This makes sure the pump is submerged in oil. Beats pulling the pan to get some grease in the pump. If it's really dry the distributor trick won't work.
garymunson is offline   Reply With Quote
Old 12-11-2012, 08:27 PM   #9
Kingfish999
alright i got it figuered out and it wasnt my fualt this time!!! the company who made the filter relocation kit labeled IN and OUT backwards on the block adapter. you wouldnt think this would make a difference but because the oil filter has a backflow preventer in it, it was was stopping the filter from flowing. since the filter flows from the outside in, when it was reveresed it tried to flow inside out so when i had the filter half off this is why no oil was present.
i did pull the dizzy and found everything was good. pump had resistance, teesh wernt worn, pump was primed after all. then is when i took the filter all the way off and used the drill to realizr there was pressure. got everything all good now. oil pressure is good again. hopefully running with no oil didnt cause too much wear.
notice the outside is labeled IN even tho the oil flows out
Old 12-11-2012, 09:20 PM   #10
jopes
gone fish'n
jopes's Avatar
oil flows from the outside of the filter into the center and out the center into the hole it is screwed onto the block with.
By looking at that picture, the hose labeled IN comes from your engine and the one labeled out is the filtered oil.
I don't see how they have something labeled wrong.
Let's Go Fishing.
Old 12-11-2012, 09:59 PM   #11
Mikey350
Bronco Info: 1996 Black 302 XLT - 1994 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
Swap the hoses
Mikey350 is offline   Reply With Quote
Old 12-11-2012, 11:37 PM   #12
Kingfish999
one like me would assume when it says IN, it means the flow goes to there, not from. since the flow is comming out where it says IN that to me is wrong. when wiring say a TV, you have Video/Audio IN and OUT. OUT is a source and IN recieves. why woulkd you label something IN if its a source?
mikey i did swap the hoses but its really a PITA to do.
Old 12-11-2012, 11:43 PM   #13
jopes
gone fish'n
jopes's Avatar
your making my head hurt.
Let's Go Fishing.
Old 12-11-2012, 11:51 PM   #14
jopes
gone fish'n
jopes's Avatar
in is the unfiltered oil from the engine
out is the filtered oil which is sent out to all the moving parts in the engine.
it is plain and simply put. I am not understanding how you have this all switched around. To me that part is labeled correctly, you installed it wrong.
Let's Go Fishing.
Old 12-12-2012, 12:05 AM   #15
Kingfish999
if this was connecting to the filter then i would say yes. but this is going to the block. but im going to end this before i make you think. we all know what happened when you think
Old 12-12-2012, 12:14 AM   #16
ProBronco
ProBronco's Avatar
Bronco Info: 80 Bronco XLT 302 4sp, 4"lift on 35" Factory LS F&R
SPeeCHLESS >>>>>>>>>>>>>>
ProBronco is offline   Reply With Quote
Old 12-12-2012, 09:17 AM   #17
1starvingtrucker
1starvingtrucker's Avatar
X2
1starvingtrucker is offline   Reply With Quote
Old 12-12-2012, 09:35 AM   #18
1starvingtrucker
Jopes is correct. It is labelled correctly.
IN = In to the oil filter
OUT = Out of the oil filter
I wouldn't be running the engine until I understood this. I am not trying to be rude, I just don't see any reason to starve your engine of oil.
What oil filter are you using?
Old 12-12-2012, 10:57 AM   #19
mickaila
not banned
Bronco Info: 82 XLT Lariat, 351W, C6, NP208, 4.56:1, 37x13.5s, all sheet metal replaced
you don't lose prime on the pump.
the lines may be void until they are filled. you can fill them by cranking the engine with the hi tension coil disconnected.
Where we go one, we go all.
Mickaila's Rebuild
Originally Posted by Redwagon View Post
I guess most of our members are just WEB WHEELERs and dont need public land?
mickaila is offline   Reply With Quote
Old 12-12-2012, 11:40 AM   #20
tonyroc14
tonyroc14's Avatar
Bronco Info: 1993 XLT 5.8,1991 XLT 5.8 - sold
So you made a mistake no biggy. The part seems correctly labeled to me. But i have misunderstood easier things before. Hopefully the engine wasn't running without oil... I don't think you'd hurt the engine by cranking it over dry because of the residual oil. But running it dry? That hurts me! Haha
Sent from my iPhone using AutoGuide.com App
tonyroc14 is offline   Reply With Quote
You may not post replies
Forum Jump
