#1 |
iTrader: (0) Bronco Info: 1996 351w zf5 4 inch lift 36" TSL Super Swampers
Super confused on parts compatability with dana 44's
Basically sometime in the somewhat near future i will be doing a sas on my bronco. my buddy has a 79 hp dana 44 that he is selling me super cheap but it doesnt have spindles or hubs. he also has a set of chevy knuckles laying around. What im asking is that is there any way to make the axle complete with the parts is have? I did try searching but I just got really confused.
parts available: -ford knuckles -chevy knuckles -ttb spindles -ttb hubs -ttb knuckles -ttb everything else |
| Sponsored Links | |||
Advertisement | |||
#2 |
gone fish'n
![]() ![]() Join Date: Feb 2003
iTrader: (4) Bronco Info: pile of parts
I know TTB knuckles will not work on a solid D44 axle
The TTB lockouts should swap between every internal lock out D44 out there for the most part.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun! ![]() Let's Go Fishing. |
#3 |
i know the lockouts work on all because i currently have the 79 style lockouts on my ttb. i just need to make a complete axle with what i have or for cheap. the axle has everything out to the knuckles. just no spindles hubs or brakes.
#4 |
gone fish'n
I probably would do chevy brakes up front. They work so much better at stopping that the fords. I know a bunch of this stuff interchanges, I just can't remember off the top of my head.
GM made 2 different size spindles, small bearing and big bearing. I know you run GM knuckles, brake caliper brackets, and brake calipers. Ford hubs and rotors to retain 5 on 5.5. but I can't remember which spindle or bearings are needed.
#5 |
if there is a way to use my ttb brakes that would be awesome. Im in college and im on a very cheap budget. Basically i just want to get it done whether or not some things are done the right way i dont really care. I just want to get the solid front under there right before spring and i can always redo/replace things overtime.
#6 | |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
Brakes & steering are not things to screw around with. Either do it right the FIRST time, or park it & walk. It's cheaper to pay someone who knows what he's doing AND to buy good parts than to pay a lawyer, court costs, the ambulances, the emergency rooms, the physical therapists, all the damage you do, and a portion of your earnings for the rest of your life. |
#7 | |
#9 |
Thanks 351w500
![]() ![]() Join Date: Mar 2005
Location: Northcentral,CA.Twain Harte, up here in the mountains
iTrader: (52) Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
Steve in no way flamed you so relax. some of us care if ppl put unsafe hacked together stuff on the rd where it might hurt some family. And that is exactly what it sounded like you were going to do.
If your in school and short on $ you should just put off the sas And Do it right the first time. Go read the noobie sas thread before you start any more threads on anything todo with a sas. all this info is there already for you.
![]() I take Prayer Requests. God Bless |
#10 |
You posted on a public forum - you're asking for whatever you get, especially with a post like that.
And I still haven't flamed you, so get the twist out of your knickers.
#11 |
ate lug
![]() Join Date: Apr 2003
iTrader: (4) Bronco Info: 88ish bronco(?)/96 F250; both with D60s
I agree with Steve 100% because of this:
Steve didnt say TTB brakes were wrong, he simply said to do it right, and not to half-ass it because youre not the only one on the road. |
#12 |
I have read a decent amount of the sas threads on this forum. I know how to do the sas. All I am asking is that is do i have the parts to put together a fully functional axle. Can the parts that i have be put together so that the brakes are not off set, the bearings ride on the spindle and hub in the correct places. All i asked was a simple question as to if they will go together. I dont need to be told what is safe and what is not. ttb calipers will work completely fine whether they are on a sas or on the ttb
#13 |
what i meant by just wanting to get it done is put together all the necessary parts that i have around to make 1 complete axle and then over time upgrade to the more preferred parts
#14 | |
![]() Join Date: Jul 2009
iTrader: (1) Bronco Info: 90' 351/E40D 38" tires, 4.88 gears, full float 8.8, lockers F&R
In any case, if you read some suicidal tendencies into his remarks, you could just ask him to clarify before giving him a lecture. |
#15 | |
#16 |
Chillin on the Gulf Coast
![]() Join Date: Apr 2009
iTrader: (3) Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
I paid $127 for my D44, complete hub to hub, even the brake line. You can get better prices. The parts that are missing are not cheap. If you are planning to stay 5 on 5.5" then you might do well to wait for someone to convert their solid D44 to 8 lug and pick up their outers. I already have my 8 lug parts and am just waiting to get back to the states to swap my stuff out. I am also not the only person doing such a swap.
#17 |
Ok so basically all i really need to complete it then is chevy brake calipers? I can put chevy knuckles, ttb spindles, ttb hubs/rotors, and chevy calipers and that works?
#18 | |
Student of life, man.
![]() Join Date: Aug 2005
iTrader: (0) Bronco Info: 1979 Freewheel'n, PowrLok, ARB, OBA, and anything else I can cram in
amiright?
I <3 FAR 43. |
#19 | |
RAAAAAH!
iTrader: (0) Bronco Info: '90 FSB, SAS'ed, locked, geared, caged, gutted, built and filthy
![]() It looks like some TTB calipers will fit the 79 axle and some will not. Refer to post 18 of this thread Best way as of now is to try and see.
302 roller, GT40 heads, E-fan, off-road cam, headers, 35x14.5 Pitbull Bias Rockers, 10" aluminum wheels, 4.56 gears, rear Detroit Locker, front Truetrac, built AOD, Kodiak auto steps, custom exhaust, full 2" DOM cage, PRP reclining suspension seats and harness, D44 SAS, 1.5" DOM/heim steering, Deaver coils, Bilstein 7100 14", F350 brakes |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
