any other ideas on stripping paint from rims? - FSB Forums
Thread Tools Display Modes
Old 12-11-2012, 12:49 PM   #1
fdtdx18
fdtdx18's Avatar
Bronco Info: 1993 custom 302, flowmaster super 10, interco tsl's 33x12.5x15, rancho rs5000's, summit shortys
Ok, so for chrsitmas, santas buying me a set of 33 tsl's. I picked up a set of stock rims off of craigslist to mount them on and now am trying clean them up to paint them black. I've got them mostly done but I cannot get the paint off the inner and outer lip of the wheels. I've used aircraft stripper, a drill with a paint/rust remover and my grinder with a paint remover on it and none has gotten in there deep enough. I don't want to use a wire wheel because I don't want to score the metal and a dremel is way to aggressive. Anyone else have any ideas other then media blasting?
fdtdx18 is offline   Reply With Quote
Old 12-11-2012, 01:39 PM   #2
BakerBaker
BakerBaker's Avatar
Bronco Info: 87 EB w/302,C6,1356, 36 TSL's and I need a spare, PM me if you local and have a spare tire for sale
I cant believe the aircraft coating removal didn't work. Did you try the aerosol can? or the jelly.
Go ahead and save up for ball joints and tierods after you run those TSL's for a while. They will kill the front end.
Are the stock wheels 8 or 10 inch. I think the TSL's are going to need a wider wheel. Have you checked into that?
They make a plastic wire brush for a dremel.
BakerBaker is offline   Reply With Quote
Old 12-11-2012, 01:45 PM   #3
mickey556
Bronco Info: '89 bone stock. Got 3/4 of parts for spring resto and disel swap tho!!!!
A guy somewhat local to me will media blast a rim for 15 bucks a pop. He uses plastic media instead of walnut and such that wont score the rims at all. That will most likely be your best bet.
** 1989 Bronco XLT - 7.3 idi NA / ZF5 speed conversion underway. Build thread http://www.fullsizebronco.com/forum/...=1#post2865645
mickey556 is online now   Reply With Quote
Old 12-11-2012, 02:03 PM   #4
Robs79BBbronco
Robs79BBbronco's Avatar
Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
carb or brake cleaner?
Robs79BBbronco is online now   Reply With Quote
Old 12-11-2012, 02:45 PM   #5
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
Bronco Info: '89 Bronco, 5.8, MAF, Summit shorties, Bassani SS, AOD, Tru-trac posi, Stocker
In the battle between brake fluid and paint......paint always loses.
Click HERE to visit my frame-off NOS restoration thread.
Photobucket Album ....and a crap load of pictures....
j. r. Nice is offline   Reply With Quote
Old 12-11-2012, 07:11 PM   #6
fdtdx18
fdtdx18's Avatar
i used the aerosol aircraft stripper. the problem is that its colder here then the suggested range of temperature so i know that has something to do with it. ive also tried brake cleaner but to doo all the rims, id need about a case nd a half. i did not know about using brke fluid though. ill try tht tomorrow
Old 12-11-2012, 09:12 PM   #7
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
I'm wondering if someone had them powdercoated.......
I've never used brake fluid either, but it always removes/ruins paint if left on very long. I'm surprised the stripper didn't do it...
Old 12-11-2012, 10:03 PM   #8
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
x2 :)
Used Brake Fluid = "hick paint remover" :)
But brake fluid vs polyurethane (in this case)(or powder coat)...
brake fluid needs a lot of time. :/
Acid works on polyurethane but I'm not sure which ones work
and how strong they need to be, either one. :/
Alvin in AZ
Alvin in AZ is online now   Reply With Quote
Old 12-11-2012, 10:19 PM   #9
fartman
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs
Oven cleaner, search on here and see the results. It will strip a rim clean.
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options.
J A S N
http://www.supermotors.net/registry/19528
free caveman
fartman is offline   Reply With Quote
Old 12-11-2012, 10:33 PM   #10
Billy89EB
Billy89EB's Avatar
Bronco Info: 1987 Eddie Bauer 302, 4" rancho lift, dual magnalfows, 35" Discoverer stt's
Yeah, oven cleaner can be used to remove anodizing, so it will most likely take off clear coat. Don't leave it on too long or it can cause pitting to the aluminum.
Billy89EB is offline   Reply With Quote
Old 12-11-2012, 10:39 PM   #11
Alvin in AZ
AKA: Butthead
Originally Posted by Billy89EB View Post
Yeah, oven cleaner can... ...cause pitting to the aluminum.
x2! :/
There's a thread somewhere about a guy using oven cleaner and decided
the mess it made was worse than what he'd started with. Especially when
you realize the anodizing is something you really want to keep. ;)
Alvin in AZ
ps- Oven cleaner is basic and aluminum reacts with strong bases. BTDT!*:)
Aluminum is anodized in an acidic bath. :)
pps- Hadn't tried it but, I'd bet on acid vs polyurethane before I'd put a
strong basic solution like oven cleaner on polyurethane coated aluminum.
Acid is known to work to remove/loosen polyurethane.
*ppps- A magnesium VW engine case in a lye bath that had an aluminum
plug in it... gases poured out of the bath foaming that sucker up something
awful. LOL :) Took the engine case out and it was sizzling hot around that
aluminum plug. Rinsed it off, removed the plug I'd forgot, put it back in
the lye-vat. -shrug-
Old 12-12-2012, 08:32 AM   #12
1starvingtrucker
1starvingtrucker's Avatar
I vote for oven cleaner, too. I would try to warm the wheel up a little if it is cold and use oven cleaner. I have seen oven cleaner strip paint to the metal.
1starvingtrucker is offline   Reply With Quote
You may not post replies
Forum Jump
