Oil cap stuck. - FSB Forums
Thread Tools Display Modes
Old 12-11-2012, 06:41 PM   #1
Davey303
Davey303's Avatar
Bronco Info: 1994 XLT 351w almost OJ (Tow package)
Oil cap stuck.
My 94 with a 351w needs about a quart, but I cannot get this damn cap off.
http://imgur.com/AgHis
Is this supposed to be a two piece? Any advice on how to remove it would be great!!
Davey303 is offline   Reply With Quote
Old 12-11-2012, 07:03 PM   #2
351w500
Unforgiven's Pet
351w500's Avatar
Bronco Info: '90 xlt 351w E40D Truetrac I GOT ROLLER ROCKERS !
what is the direction that you are turning it ?
351w500 is offline   Reply With Quote
Old 12-11-2012, 07:09 PM   #3
Davey303
Davey303's Avatar
Counter clockwise..
Old 12-11-2012, 07:10 PM   #4
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Once you get that cap off, find an original. That's not the original cap....
~ Scott ~
~My Exhaust clip on YouTube ~ 204k on the odometer and no longer a daily driver. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
sackman9975 is offline   Reply With Quote
Old 12-11-2012, 07:18 PM   #5
Davey303
Davey303's Avatar
Will do. Is there a site in particular that has them for a good price? Or should I just pick one up at the junk yard?
Old 12-11-2012, 07:30 PM   #6
sackman9975
Probably just snag one at the boneyard. I've just checked Jeffs Bronco Graveyard and didn't see any there.
~ Scott ~
Old 12-11-2012, 07:38 PM   #7
Mikey350
Bronco Info: 1996 Black 302 XLT - 1994 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
NPD has them:
http://www.npdlink.com/store/index.p..._str=F-6766-21
Mikey350 is offline   Reply With Quote
Old 12-11-2012, 07:43 PM   #8
ToughBronco
ToughBronco's Avatar
Bronco Info: Sold
Big pair of channellocks or a pipe wrench will bust that thing off.
1997 Ford F250 Heavy Duty XLT 4x4
7.3L PSD CCSB, E4OD, D50 TTB, 10.25 FF LS, 3.55's
2001 Ford E350 Super Duty Work Van
5.4L V8
ToughBronco is offline   Reply With Quote
Old 12-12-2012, 04:52 PM   #9
85turdburger
Bronco Info: 85 Bronco, 300 straight 6, early carb and dist conversion, 33X10.50 4inch rough country lift
I've found an oil filter wrench will fit between the recesses of the aftermarket cap and usually take them off with no problem should you have to reuse it
85turdburger is offline   Reply With Quote
Old 12-12-2012, 05:02 PM   #10
Clarke
Clarke's Avatar
Bronco Info: F150 ext cab, 5.8 auto/ 96 bronco 5.8 MAF with E4ohishitmyself pushy button 4x4
if all else fails take a sawzall to that sucker
then take it to the PO who put that cap on
"The definiton of insanity is doing the same thing over and over again and expecting different results." Albert Einstein
obviously he shouldve used a bigger hammer
Clarke is offline   Reply With Quote
Old 12-12-2012, 06:38 PM   #11
Steve83
Steve83's Avatar
There are thousands of them in the junkyards - Ford used the same 710 cap on just about everything for many years.
Old 12-12-2012, 07:38 PM   #12
95bronco12
95bronco12's Avatar
Bronco Info: 1995 5.8 4 inch lift 1979 8' lift one ton in the works
X2 boneyard. I would use a hammer and flathead.
95bronco12 is offline   Reply With Quote
You may not post replies
Forum Jump
