Differential Spider Gears - FSB Forums
Thread Tools Display Modes
Old 12-18-2012, 08:06 PM   #1
zdumpor
Bronco Info: 1989 Eddie Bouer 302
This weekend I went in to replace my U-Joints, as I suspected that they were the cause of a high pitch sound, as well as a banging sound during my automatic transmission shifting gears. When I removed my drive shaft, I found that the U joints were in good shape. I did find that there was an enormous amount of play in my differential. After taking off the cover, I found that spider gears were completely destroyed.
I only want to replace the spider gears, however most places that I look, all I find is the entire differential. I'd like to put new gears in instead of going to a junk yard. Does anyone know of a good place where I can find this?
zdumpor is offline   Reply With Quote
Old 12-18-2012, 08:22 PM   #2
JBfab
JBfab's Avatar
Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
I belive jeffs bronco graveyard has them.
It's not custom if you bought it from a catalog!
Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825
JBfab is offline   Reply With Quote
Old 12-18-2012, 08:29 PM   #3
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Traction lock set at JBG
These are for the 8.8
Not sure what you have because you haven't got any info over
<-------------HERE
Click user CP up top and enter some info in so it comes up on every post.
~ Scott ~ ~ Ford's, please bring back the Bronco!! ~
~ My Exhaust clip on YouTube ~ 203k on the odometer and no longer a daily driver. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
sackman9975 is offline   Reply With Quote
Old 12-18-2012, 11:17 PM   #4
SCRebel
SCRebel's Avatar
Bronco Info: 1989 F150 XLT Lariat, 4x4, D44 SAS, 9" rear axle, 8" lift, 35's. 5.8 EFI bored 40 over, AOD trans
O'rielly Auto parts sells them too.
$92.99 http://www.oreillyauto.com/site/c/de...7110&ppt=C0363
Carolina Man
SCV member. Camp Litchfield #132
The name is Joseph. Aka: Big Joe
SCRebel is offline   Reply With Quote
Old 12-18-2012, 11:35 PM   #5
omp
Bronco Info: 96 302, 5spd, 4" lift
Good time to replace with a lock rite, Aussie or similar if you don't drive in snow or ice much.
omp is offline   Reply With Quote
Old 12-18-2012, 11:41 PM   #6
lifeizhard102205
lifeizhard102205's Avatar
Bronco Info: 1993 EB 351W, SAS'd 44, 37" Hummvee tires, 10.25 rear, smittybilt 12k winch homemade mount
if you do any offroading i'd take this time to replace the whole diff with at least a tru trac. i had one and loved it. no weird handling quirks like with a full locker, cheap, damn near indestructible and provide great traction. otherwise, beyond jeffs, a junkyard or ford, no i don't. i dont have mine anymore.
lifeizhard102205 is offline   Reply With Quote
Old 12-18-2012, 11:45 PM   #7
SCRebel
SCRebel's Avatar
I did mine not too long ago and wished I had the money for a Detroit locker.
Carolina Man
Old 12-19-2012, 12:18 AM   #8
CWbronco
CWbronco's Avatar
Bronco Info: 95 xlt, 302, 37's, 4.56's, D44 SAS, 10.25 FF
i got mine from ford. ran me about $160. i think getting them from ford will give you higher quality than a local parts place.
Build
SAS
FOTM Oct. 2012
CWbronco is offline   Reply With Quote
Old 12-19-2012, 12:12 PM   #9
omp
X2 on truetrac but it's 450$ vs used carrier off eBay or Craigslist for 50$.
Old 12-22-2012, 05:02 PM   #10
zdumpor
Sorry sackman9955 hole this helps.
I've gone to the Ford site (Ford Racing I believe), but I only saw entire differentials there. I'll consider upgrading, but it may be a bad time financially. I appreciate everyone helping out. I'm still new to the craft, but I do love a challenge.
Old 12-22-2012, 06:20 PM   #11
Kingfish999
Nothing beets a Fullsize
Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
EDITED
I'm sorry you don't have 75 post and this is not the for sale section. So I feel lucky I'm not banned for tying to offer you something I shouldn't be.
Kingfish999 is online now   Reply With Quote
Old 12-26-2012, 10:45 AM   #12
96EB5.8
Bronco Info: 96 eb 351 auto
I would get the cross pin also as there will be wear at the gear areas.
96EB5.8 is offline   Reply With Quote
Old 12-26-2012, 10:58 AM   #13
zdumpor
No worries guys. Ill be knocking it out tomorrow or Friday, so Ill keep you posted.
Old 12-26-2012, 05:13 PM   #14
Kingfish999
Originally Posted by Kingfish999 View Post
EDITED
aww ur mean. i wasnt jsut trying to sell him something. i also asked him questions and gave him info. gave him links where to buy and how to identify what carrier he has
for everyones info he does have trac lock
Old 12-28-2012, 08:08 PM   #15
zdumpor
Fellas Relax!
I appreciate the help. So today, I removed the entire differential in order to inspect the bearings. I goofed up by not taking a picture of the bearing orientation, but it turns out that the bearing brackets have different part numbers stamped on them. Though they do not appear to be different in shape, I still want to install them as they originally stood. I believe that the chamfered side faces the outside. With that said, which bracket goes on which side? Any advice?
Old 12-31-2012, 10:56 AM   #16
zdumpor
Talking
Any help? Trolley had the wrong set (non_ position) for me so I still haven't finished the install. I have the arrows facing outward but I'm not sure if they're on the right side. My ring and pinion mesh looks great.
Old 12-31-2012, 05:31 PM   #17
Kingfish999
im guessing you mean the differential main caps. cant way which side is which but i do remeber they point outward. remeber to loctite the bolts.
Old 12-31-2012, 06:17 PM   #18
zdumpor
Good call on the loctite.
I am just about done with the job, and all that is left is the install the S spring. I've gotten spring placed inside the carrier, however this prevents me from being able to install the C Clip that holds my axle from sliding out. Any advice here? I can start the clip on into the groove, but It wont go in much further. I believe hammering may not be a good idea...What do you guys think?
Old 12-31-2012, 06:37 PM   #19
Kingfish999
its been awhile since i messed with it. is the hole for the spring too smal ofr the c-clip?. my guess would be leave the spring in place, have the crosspin shaft out and try and put the c clips in. try to pry the spring alittle to get them started and tap them in the rest of the way.
Old 01-02-2013, 12:01 PM   #20
zdumpor
That worked! I have her all zipped up and took her out for a ride last night. Thanks for the help everyone!
You may not post replies
Forum Jump
