Stock Coils or Leveling Coils? Tire Wear Poll - FSB Forums
View Poll Results: Will leveling coils give bad tire wear and be hard to keep aligned?
Yes plan on bad tire wear with the leveling coils and an alignment that is never right 1 25.00%
No the leveling coils will align fine and give you similar to factory tire wear 3 75.00%
Stock coils is only way you're going to get good tire wear 0 0%
Voters: 4. You may not vote on this poll
Thread Tools Display Modes
Old 12-22-2012, 07:39 PM   #1
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
Can't make up my mind; Should I keep the stock coils or put on leveling coils and adjustable caster/camber bushings? Leveling coils that could risk bad tire wear? Stock coils the trucks look stuffed with 32s on 15x10s.
update: I aligned truck on the rack, so far so good. caster/camber/toe within specs.
GetBent4x4 is offline   Reply With Quote
Old 12-22-2012, 10:54 PM   #2
Kingfish999
Nothing beets a Fullsize
Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
i have leveling coils on my 88 and use to have them on my 96. 88 has great alignment. 96 i cant say cause after jumping ti soo much i almost needed 4" coils to fix the alignment
Kingfish999 is offline   Reply With Quote
Old 12-23-2012, 12:46 PM   #3
GetBent4x4
Thanks King.
Old 12-23-2012, 05:16 PM   #4
GetBent4x4
Hmm how do you remove springs? Never had to do it before.
Old 12-23-2012, 09:33 PM   #5
Kingfish999
you have to jack the front of the frame high enough for the axle to fully droop down (cant lift by the axle). disconnect the shocks form the axle and swaybar from the axle. disconnect the J clip on top that holds the spring in. toke the big nut and washer off that holds the bottom in. its either a 1-1/8 or 1-1/16 size and can be a struggle to get out. install is reverse but the new coils might be abit longer so you may need to have the axle droop alittle more than before
Old 12-29-2012, 09:05 PM   #6
GetBent4x4
Thanks, that will come in handy.
Also when I replaced the passenger ttb pivot bushing; I pounded out the old pivot sleeve (because I sure as hell wasn't going to go to the extra work to remove the ttb arm and press out the bushing), and it caused the ttb arm to bend near the end. The engine cross member where it bolts up also bent. I beat it back into shape and enlarged the frame hole to get it to bolt back up. It looks decent, a tad bit wavy. I wonder if this could affect the alignment?
Old 12-29-2012, 11:21 PM   #7
fartman
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs
I had rancho leveling coils on my old 81, no problems with alignment. But I think you might have issues with your beat arms.
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options.
J A S N
http://www.supermotors.net/registry/19528
free caveman
fartman is online now   Reply With Quote
Old 12-30-2012, 08:04 PM   #8
Kingfish999
every time i do my pivot bushing i end up having to take the radius arm brackets off because of that. all i can say is whats done is done take it to get an alignment and see the results. if you have serous problems then you might need to replace those. it should be fine tho considering getting TTB aligned is never permenant and is only really getting as close to possible
You may not post replies
Forum Jump
