FI 460 AC Compressor Elimination - FSB Forums
Thread Tools Display Modes
Old 12-27-2012, 10:19 PM   #1
Shane C.
Shane C.'s Avatar
Bronco Info: 78 Bronco, FI 460/1995 RIP
Guys and gals,
I have a FI 460 from an 89 F350 in my 78. I eliminated the AC when I did the swap, but left the compressor in. Its starting to squeal and the end is in site. Its a dual belt system and as it turns out that they don't make an elimination pulley for this. Looks like I probably need to eliminate it and replace it with a shorter belt.
Anyone have any info on this? Belt size, PNs, experiences to share?
Thanks all...
My other car has doors.
Shane C. is online now   Reply With Quote
Old 12-28-2012, 09:55 AM   #2
InfoFord
InfoFord's Avatar
Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
they do make a elimination pulley for it
http://www.ebay.com/itm/Dorman-A-C-C...cc820d&vxp=mtr
less then a minute for searching
Trent
NORTH COUNTRY SPECIALTIES
Picador (1979 4door Bronco)
79 Ford CrewCab 4X4(My Dually Project)
79 Ford Bronco and My Boat
InfoFord is offline   Reply With Quote
Old 12-28-2012, 11:03 AM   #3
SomeDude451
Bronco Info: 1989 F350 XLT Lariat, 4x4, 7.5L SD, E4OD
Should be the same compressor used on the 5.0/5.8 so whatever eliminator that works in those should work on the 460.
My Supermotor
SomeDude451 is offline   Reply With Quote
Old 12-28-2012, 01:20 PM   #4
Shane C.
Shane C.'s Avatar
Thanks. That part only lists back to 1990, and does not list the 460 as a compatible motor... Same issue I had at the part stores and the reason for the post...
I wonder if they just dont list it and if it is as SomeDude says, the same as the AC compressor for the 302 and 351. I thought that would be the case when I went in looking for the part, thats why I was surprised when they told me it wasnt available. Maybe I just need to buy one for a 302/351 and see if it works...
Old 12-28-2012, 02:41 PM   #5
SomeDude451
I didn't realize is was inthe 78/79 forum. So my statement may not be true. The eliminator mentioned above should work for any EFI V8 from at least '87 up. But I'm not as familiar with the 78/79s, so I don't know if the AC compressors are the same. I don't see why they wouldn't be, but I don't know. Looking at some pics of the carb engines I don't think the eliminator shown above would work. You'll probably just need to remove the bracket and get a shorter belt.
My Supermotor
Old 12-28-2012, 02:49 PM   #6
Shane C.
Shane C.'s Avatar
I think you were right though because the motor is from an 89. I just put it in the 78/79 forum because the motor is in my 78 and I figured that was the most common 460 swap (vs newer models). It sounds like that elminator the InfoFord posted is the one. Maybe the 89 is just too late a motor for them to list it for or something stupid like that...
Old 12-28-2012, 03:05 PM   #7
SomeDude451
If the motor has the 89 EFI power steering bracket, that eliminator should work perfectly. If you kept the 78 engine brackets, it probably won't work.
My Supermotor
Old 12-28-2012, 07:04 PM   #8
shadowcaster
shadowcaster's Avatar
I have an '89 FI 460 in my '78 as well. The eliminator bracket came from a fellow FSB guy (Miexter) years ago. I believe it came from a 5.8. From my recolection, that bracket is universal between years/ motors. Couldn't get a pic, my phone battery is dead.....
If it ain't broke, keep trying to fix it!!!!
shadowcaster is offline   Reply With Quote
Old 12-28-2012, 07:08 PM   #9
CS79bronco
Bronco Info: Red/White '79 Custom-400, 435, 205. '86 EB beater, 302, 435, 208 stock on 35's, '95 XLT, 302, 5spd.
There should be something available. Surely not all EFI 460 vehicles had AC from the factory, so there would be a bracket/tensioner instead of the compressor.
man... the things I've learned on this site simply boggle the minds of everyone I talk too. (Biker Pepe)
CS79bronco is offline   Reply With Quote
Old 12-28-2012, 07:28 PM   #10
Shane C.
Shane C.'s Avatar
Thanks guys. Makes sense and is what I suspected. I will order one as InfoFord posted and give it a run. I am confident it will work...
Old 12-28-2012, 08:19 PM   #11
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
If it doesn't ill buy your truck for $500.
2006 Kia Spectra 4 banger/5 speed.
I like to eat poop.
New nuts are in the plan.
TheUnforgiven is online now   Reply With Quote
Old 12-28-2012, 08:22 PM   #12
Shane C.
Shane C.'s Avatar
That would give me 10 nights with your mom.
Old 12-28-2012, 08:26 PM   #13
TheUnforgiven
My mom is in a coma bro
I like to eat poop.
Old 12-28-2012, 08:30 PM   #14
Shane C.
Shane C.'s Avatar
Oh shit dude... My bad. I am truly sorry. Maybe we can get this deleted?
Old 12-28-2012, 08:32 PM   #15
muffinman944
muffinman944's Avatar
Bronco Info: 1990 Bronco Custom, 1995 Bronco XLT (Fummins)
I guess Shane can really throw it down
Sent from my iPhone using AutoGuide.com App
Originally Posted by Joes93Bronco View Post
...I have NEVER had any probs with my 4 incher ...
'90 Bronco...parting out
'95 FSB: D60/AAM 11.5'', BTS E4OD/Atlas II, 6.7 Cummins conversion in progress
muffinman944 is offline   Reply With Quote
Old 12-28-2012, 08:34 PM   #16
TheUnforgiven
Before you change it
I like to eat poop.
Old 12-29-2012, 09:13 AM   #17
InfoFord
InfoFord's Avatar
you may need to use the steering A/C belt from a 96 460 if that pulley on that eliminator is smaller dia then your A/C pump pulley
Trent
Old 12-29-2012, 06:35 PM   #18
Shane C.
Shane C.'s Avatar
Got the eliminator. Pulley on it is 5.25". Pulley on AC compressor is 6". I bought the 96 belt in case that difference in size warrants a smaller belt. Not sure if there is enough flex in the tension pulley to make up for the slightly smaller pulley or not...
Old 12-30-2012, 01:16 AM   #19
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
BTDT same sort of thing before and the guys at the parts house were
glad to work with me on it.
One minute use on a belt doesn't hurt it, was what they were thinking.
Just to get an A/C equipped vehicle going all it needs is a clutch bearing.
They're relatively cheap and easy to replace.
The compressor can be dead but still carry a belt quiet as anything with
a new clutch bearing. ;) 5106 bearing is used in both my '75 and '91.
Anyway, cool thread. :)
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 12-30-2012, 01:33 AM   #20
TheUnforgiven
Shane, that small of a difference won't matter, if it does it will let you know quickly.
I like to eat poop.
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
