grinding dayton calipers to fit 15"rims? - FSB Forums
Thread Tools Display Modes
Old 12-30-2012, 05:53 AM   #1
joesolo71
Bronco Info: 91 Nite edition
Question grinding dayton calipers to fit 15"rims?
Have a 79 hp dana 60 with Dayton dual piston calipers. Can these calipers be ground down to fit 15" rims? I have seen and read a lot of info on grinding calipers but none were daytons. They actually look lower profile than the ones I've seen ground down. They don't wrap over the top of the rotor but they do seem pretty long. Anyone ever tried to fit 15's over these?
joesolo71 is offline   Reply With Quote
Old 12-30-2012, 10:32 AM   #2
badass1tonf100
Hit it n' Git it
badass1tonf100's Avatar
Bronco Info: 4 wheels, 1tons, 3 sticks, sheet metal & some tubing.
I ran 15's with dual piston calipers on my rig only way for it to work is getting wheels with a 2.75" back spacing. No grinding necessary.
badass1tonf100 is offline   Reply With Quote
Old 12-30-2012, 11:56 AM   #3
joesolo71
Were theses Dayton calipers?
Old 12-30-2012, 04:23 PM   #4
Billy89EB
Billy89EB's Avatar
Bronco Info: 1987 Eddie Bauer 302, 4" rancho lift, dual magnalfows, 35" Discoverer stt's
He never said that they were.
Billy89EB is offline   Reply With Quote
Old 12-31-2012, 09:48 AM   #5
badass1tonf100
Hit it n' Git it
Originally Posted by joesolo71 View Post
These were Dayton calipers?
Yes they were the Dayton calipers...
Old 12-31-2012, 11:41 PM   #6
helirich
helirich's Avatar
I guess you could get 1" spacers and stock wheels would work.
helirich is offline   Reply With Quote
Old 01-01-2013, 03:38 AM   #7
joesolo71
Awsome, they look just like mine. Thank you.
So your saying 2.75 bs and i can fit 15" steelies on it. Cool. If i wanted more backspacing i would have to do some grinding then. Do you think 2.75 bs won't put to much stress on the wheel bearings? How far did your wheels stick out. I'll be running 35" 12.5 r15 tires.
Old 01-01-2013, 03:41 AM   #8
joesolo71
It looks like you did your own break refurbish/rebuild. That's what i would like to do. Where did you find the new parts?
Old 01-01-2013, 06:58 PM   #9
badass1tonf100
Hit it n' Git it
If you want more backspacing that would require you running a 16" wheel or bigger. I had no premature bearing wear/failure. With 15x10's the tires stuck out 2 inches from the fenders with 35x12.50's. I ran 44's with the same wheels and thats when you start burning out bearings and snaping knuckles at the ball joint.
Old 01-01-2013, 07:00 PM   #10
badass1tonf100
Hit it n' Git it
I got all my parts from NAPA Auto
Old 01-01-2013, 10:08 PM   #11
joesolo71
thanx
i really appreciate all the great advice. One more thing. Did you use compressed air to remove the pistons and do you need special connectors to do this?
Old 01-01-2013, 10:31 PM   #12
badass1tonf100
Hit it n' Git it
Pistons are easily removed. pull the silcone/rubber boots on the piston and the cups slide right out. only speciality tool you need is a brake hone.
Old 01-02-2013, 10:10 AM   #13
joesolo71
Smile
Thanks
You may not post replies
Forum Jump
