Power steering help - FSB Forums
Thread Tools Display Modes
Old 12-31-2012, 08:36 PM   #1
89broncoguy27
Bronco Info: 89 Bronco dana44 front dana 60 rear. NP 208 transfer case C6 trans 35's BFG's
Power steering help
Hey I have tonight to get my Power steering pump off and can't get the pulley off or brake loss the bolt holding it on. Which way does the bolt turn and best way to hold the pulley to brake it loss. Do I need a puller to pull it or? Kinda in a hurry lol
89broncoguy27 is offline   Reply With Quote
Old 12-31-2012, 10:13 PM   #2
phobos2deimos
phobos2deimos's Avatar
Bronco Info: '86 302, Bassani Y, 3" exhaust, 6l ignition, 33" KM2, Saginaw, Drop in K&N, Chopped Top
You need a puller built for power steering pulleys - don't use a three jaw, it will screw things up. I borrowed one from autozone. The puller threads in to the shaft and separates the pulley from the shaft.
Originally Posted by TheUnforgiven View Post
you could use your own piss as brake fluid, it would just boil at a lower temperature.
phobos2deimos is offline   Reply With Quote
Old 12-31-2012, 11:43 PM   #3
89broncoguy27
Ya My buddy has 3 pullers but I got to figure out this bolt thing. There's no way to use the puller on it like it is. I am about ready to bust the pulley off and spend 10 bucks on a new one. I never had this much problem on a power steering pump and pulley
Old 01-01-2013, 01:17 AM   #4
phobos2deimos
Got a pic of the bolt? I swapped in a saginaw on mine and it's just a pressed on pulley, no bolt.
Old 01-01-2013, 02:01 AM   #5
89broncoguy27
I can get one tomorrow but will have to email it. Wont let me post pictures but its a Hex head.
Old 01-01-2013, 09:09 PM   #6
89broncoguy27
So I spent all day working on trying to remove my power steering pump and the pulley and nothing will work. I have done everything I could think of and I have the right puller and nothing. Any ideas? I am about ready to cut the pulley off and all that.
Old 01-01-2013, 11:11 PM   #7
89broncoguy27
Ok I finally got it. Ended up braking the pulley and stuff.
Old 01-01-2013, 11:13 PM   #8
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
BREAKING!!!!!
2006 Kia Spectra 4 banger/5 speed.
I like to eat poop.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 01-02-2013, 01:36 AM   #9
Steve83
Steve83's Avatar
Old 01-02-2013, 03:50 AM   #10
BigBud
You thought what......
BigBud's Avatar
Bronco Info: Sold the 79 waiting for a next to free 80s to snatch
That sucks. I wonder if someone cross threaded a bolt pulling the pully on. It should have come apart under normal circumstances.
79 Bronco 6" lift, mild 460, and 3/4 tons----Sold
94 F150 4x4 302 zf5spd swap----run about
97 F350 Crew Cab 4x4 4" lift---work beast
Old guys,......they're tricky.
BigBud is offline   Reply With Quote
Old 01-02-2013, 12:10 PM   #11
Steve83
Steve83's Avatar
As p2d already posted, there is no bolt holding the pulley on. Click that thumbnail I posted.
Old 01-02-2013, 07:32 PM   #12
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
You suppose it just had a bolt threaded in the end of the shaft to protect
the shaft's threads?
On the puller I bought the internal threads in the shaft are only for pushing
the pulley back on.
Alvin in AZ
Alvin in AZ is online now   Reply With Quote
Old 01-03-2013, 12:11 AM   #13
BigBud
BigBud's Avatar
Originally Posted by Alvin in AZ View Post
You suppose it just had a bolt threaded in the end of the shaft to protect the shaft's threads?
Alvin in AZ
That's what it sounds like.
You may not post replies
Forum Jump
