dana 44 hd swap question - FSB Forums
Thread Tools Display Modes
Old 01-01-2013, 09:08 PM   #1
basssque
basssque's Avatar
Bronco Info: 92 Bronco Custom, 5.5" Lift (all Spring), BDS Ext. Radius Arms, Superrunner Steering
I can get a really good deal on a dana 44 hd leaf sprung front axle from an early 80's Chevy pickup. Can I use this axle for a SAS on my 92FSB? If so what do I need to consider or can some components be recommended for a successful swap? Thanks
basssque is offline   Reply With Quote
Old 01-01-2013, 10:35 PM   #2
badass1tonf100
Hit it n' Git it
badass1tonf100's Avatar
Bronco Info: 4 wheels, 1tons, 3 sticks, sheet metal & some tubing.
In the SAS section in the stickies on the top of the forum page there is a thread titled "God's of leafs swap" that will better answer all your conversion questions.
badass1tonf100 is offline   Reply With Quote
Old 01-01-2013, 10:42 PM   #3
rhauf
rhauf's Avatar
Bronco Info: 82 bronco 408w 4" lift 35's, 88 bronco 351w all stock on 31s
Well the diff on chevys is on the passenger side.. on fords its on the drivers side..
this is going to make the swap extremely difficult for technical reasons.
also before you jump on the SAS bandwagon, consider your reasons.
TTB is equal to or greater than a conventional d44 in many ways.
a couple examples would be;
it can land a hell of a lot more air without failure. no axle tubes to pull out.
no axle wrap (advantage over leaf sprung front ends)
high pinion
it's already in your truck.
just sayin.
-Ryan
Check out my youtube page. Many bronco videos.
http://www.youtube.com/user/rhauf1
rhauf is online now   Reply With Quote
You may not post replies
Forum Jump
