is this a factory wheel ? - FSB Forums
Thread Tools Display Modes
Old 01-02-2013, 05:31 PM   #1
maro
maro's Avatar
Bronco Info: 1990 XLT, 351W E4OD
anyone knows these wheel ?
seller says it is from ford pickup, maybe F-150, is it factory or aftermarket ?
one of five FSB in my country
1990 XLT 351W E4OD BW1356
Superwinch EP9, Warn premium hubs, 33x12,5 Hankook Dynapro MT, 6" BDS lift suspension
maro is offline   Reply With Quote
Old 01-02-2013, 06:19 PM   #2
phobos2deimos
phobos2deimos's Avatar
Bronco Info: '86 302, Bassani Y, 3" exhaust, 6l ignition, 33" KM2, Saginaw, Drop in K&N, Chopped Top
Looks *extremely* similar to my factory wheels.
Originally Posted by TheUnforgiven View Post
you could use your own piss as brake fluid, it would just boil at a lower temperature.
phobos2deimos is offline   Reply With Quote
Old 01-02-2013, 06:22 PM   #3
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
His do not have the center cap mounting holes?
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 01-02-2013, 06:59 PM   #4
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
x2 and I say "aftermarket". :)
The center hole is bigger that stock to fit other makes/models than a Ford 1/2 ton.
My 16"x8's are the same way, that way.
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 01-02-2013, 07:13 PM   #5
OBS Brody
OBS Brody's Avatar
Bronco Info: 1996 xl auto 4x4
Factory. My book says late 89 to 92. You had the "option" of center caps. Look on the back near the hub. Should see a ford stamp, Along with size.
Sent from my iPhone using AutoGuide.com App
OBS Brody is online now   Reply With Quote
Old 01-02-2013, 07:20 PM   #6
convcit
convcit's Avatar
Bronco Info: 1984 with a 351W, HEI Dist, Hedman headers, Holly carb, C6, 3in suspension lift, 33'in Sport Kings
I would say Factory for a 4wd, no center caps.
When in doubt... use more duct tape...
1984 with a ecently rebuilt 351W, comp. cam, Holly carb and intake, 3in suspension lift, sitting on 33
's
convcit is offline   Reply With Quote
Old 01-02-2013, 07:22 PM   #7
Steve83
Steve83's Avatar
Aftermarket copy - there's no lip between the ring of fake rivets & the 10 holes. Center caps MIGHT have been optional (I've never seen a truck with Aluminum rims that DIDN'T have caps), but the holes for those screws in the Ford rims were NOT optional.
Old 01-02-2013, 07:54 PM   #8
black95-302/M5OD
Bronco Info: also a white96-302/E4OD and a 1993 F150 SC XLT 2WD 351/E4OD
I think that style of wheel was/is available from multiple brands, such as Outlaw IIs from American Racing (though I don't think those are Outlaw IIs). Aside from the other differences between those and OEM wheels already noted, the OEM wheels have 10 holes and those have 12.
black95-302/M5OD is offline   Reply With Quote
Old 01-02-2013, 08:34 PM   #9
buffaloroams
Man with a Golden ticket
buffaloroams's Avatar
Bronco Info: 96 blackout XLT Sport 5.8L E4OD, 4" Rancho w/ 35" MTR's
Should be a stamp in tha back hub.
Any factory wheels I've ever had seemed to be stamped FORD somewhere.
In fact all the aftermarket wheels seemed to be stamped with the manufacturers brand.
You just might be a redneck if you start a conversation with:
"happened to us when Dad got pinched by the feds."
- Biker Pepe' -
buffaloroams is offline   Reply With Quote
Old 01-02-2013, 09:13 PM   #10
78-79FordMan
Ford Hoarder
78-79FordMan's Avatar
Bronco Info: 7 of them 1978-79's
There not factory . They look real narrow . There not worth much.
Ford It Man
78-79FordMan is online now   Reply With Quote
Old 01-02-2013, 09:32 PM   #11
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
common aftermarket american racing had a version
GetBent4x4 is offline   Reply With Quote
Old 01-02-2013, 09:43 PM   #12
Alvin in AZ
AKA: Butthead
Originally Posted by 78-79FordMan View Post
TheY're not factory .
TheY're not worth much.
The factory wheels are crap too IMSAO*. :/
(*in my sorry assed/attitude-ed opinion ;)
7.5" wide 15" wheels?
One size is supposed to fit both 31x10.5x15's and 235/75-15's and
fit neither tire worth a crap! :/
So what size are the aftermarket wheels? :) Might be worth buying. :)
Sometimes it's stamped inside and sometimes stamped on the back.
There's ways to measure 'em with tires on 'em BTDT, it's more of a
"comparison" type of information than a -direct measurement-, but
they do work good enough. No need to explain the methods just do
what you think'll work for ya. ;)
You just need a "known size" the compare your measurements to. :)
Alvin in AZ
Old 01-02-2013, 09:52 PM   #13
buffaloroams
Didn't notice when I first read your post where you are from.
If you found a decent deal on these they should work fine if you are just wanting to have a factory look.
Can't be easy to get good cheap parts where you are so if I was in your shoes I think thy would be good enuf but ultimately it's your call.
- Biker Pepe' -
Old 01-03-2013, 12:18 AM   #14
Steve83
Steve83's Avatar
Originally Posted by black95-302/M5OD View Post
...those have 12.
Good eye. I totally missed that.
Old 01-03-2013, 05:55 AM   #15
maro
maro's Avatar
thanks for response. I bought them, now I do not have them here yet, need to transport some way. They do not have threaded holes for center caps, center hole diameter is 10,8 cm what is 4 1/4 " according to seller, overall dimensions are 7x15". Can be these wheels used for 35 or 36" -12,5 - 15 tires ?
Old 01-03-2013, 11:40 AM   #16
buffaloroams
Dimensions should be stamped on back of wheel too along with manufacturer.
I would have guessed they were more likely 15" x 7.5-8" but it should say.
You should be fine with a 35-36" tall tire, tire height really doesn't matter.
As for width that's different as on a wider tire you are squeezing it with a narrow rim. I run a 12.5" tire on a 8" rim and it works fine. Some would say better. Since it is less likely to break the bead when aired down to about 5psi.
Still a nice looking wheel on Bronco's.
Good score for you
- Biker Pepe' -
Old 01-03-2013, 01:42 PM   #17
Panthers65
Bronco Info: '93 F150 5.0
I would say aftermarket too, lots of companies made similar designs.
My general rule is to find a tire no more than 1.5X's the wheel width (10" wheel for 15" wide tire, 8" wheel for 12" wide tire). As long as your pretty close, should be fine.
Panthers65 is offline   Reply With Quote
Old 01-03-2013, 03:39 PM   #18
maro
maro's Avatar
Good score for you
Thanks.
One more pic, side view, they looks minimum 7.5" in my opinion too.
I drive 33x12,5x15 on the factory steel rims without any problem, just was curious how about 12,5" wide tires on 7" wheel.
Old 01-03-2013, 03:56 PM   #19
Alvin in AZ
AKA: Butthead
Oops, didn't know that wasn't your picture. :)
From post #15...
"...I do not have them here yet, need to transport some way." -Maro
Thanks.
...looks minimum 7.5" in my opinion too.
Cool! :)
Good buy on those wheels, they will fit your tires way better than the original wheels.
I'm guessing 8+1/2". :)
But -you- stop guessing, measure the width...
Alvin in AZ
Old 01-03-2013, 04:09 PM   #20
maro
maro's Avatar
thanks, sure will do deeper inquiry but have to wait until they get here. Seller charged me $358. Not so bad if considering they are not usual here at junkyards at all. Plus I have to pay transport.
You may not post replies
Forum Jump
