Buying bronco which drivetrain to look for? - FSB Forums
Thread Tools Display Modes
Old 01-03-2013, 10:42 AM   #1
Grits&Gravy
I am going to be buying a bronco shortly, I am set on a 5.8 as I have a parts one ton with a reman crate with 30k and it runs very strong, if I ever had to swap it would be direct.
Now here's the deal I love the 92-96 but I've read some about the e40d and I'm leaning towards c6
I have a 92 3/4 ton 2wd 5.8 e4od that has yet to give me a single trans problem at 130k
The one ton parts truck is 89 5.8 c6 2wd 4.10 and it screams at 70 mph
Plans for bronco are sas 1 tons leafs with 35s-38s
Will a e4od survive or should I get a c6 bronco?
How about t case differences? Strength wise
Will be a weekend toy, once in a while 15 mile drive to work,with the occasional tow my quad on a 60 mile trip on 55 mph roads.
Not a serious beat the snot out of it wheeler
Would a c6 4.10 with 35s be gutless? What's your opinion on best all around drivetrain
89 F-350 2wd Jasper 5.8L
92 F-250 2wd Supercab Tired 5.8L
Grits&Gravy is offline   Reply With Quote
Old 01-03-2013, 11:43 AM   #2
CrazyBRONCOguy
SOD BUSTERS Member
CrazyBRONCOguy's Avatar
Bronco Info: Which One?
I think the e4od would be fine. I had one in mine that had 243k on it with no issues. I sold it to a buddy who is still driving around with that trans in his truck.
The E4OD is not a bad transmission, its just expensive to rebuild. Or more expensive then a C6 to rebuild for sure.
I don't think it would be gutless. 4.10's with 35's is close to what the stock truck would be with normal sized tires.
the BW1356 is a good transfer case, just try to get a manual shift one. I would not worry about its strength.
'92 Eddie Bauer- C6 Swap, Roller 351W, MAF, RJM Harness, B.O.C. SCT Tune, 35" BFG's
'78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's
'96 F250- Tow Rig, 460, E4OD Punisher Valve Body, Triple Piler Gauges
'92 F150- 2wd, Winter Beater, 3.73's, 5.0
'79 F250- 2wd, Farm Truck, Waiting Restoration
'03 SVT Focus- Daily Driver, OZ Wheels, 6 Spd
'86 Mustang- Fastback, SOHC 4.6L Swap Project
CrazyBRONCOguy is offline   Reply With Quote
Old 01-03-2013, 11:52 AM   #3
Shadofax
Owned 17yrs, now for 20
Shadofax's Avatar
Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" MTR Kevlar, 4.56etc.
I like the E4OD choice as well. While the C6 has proven to be strong and simple (at least simple in the sense of comparing it mechanically/electronically with an E4OD), I don't like the lack of OD, it's just so limiting. With the E4OD they are strong, dependable as well and give you more leeway with your gearing (going deeper so no worry on anything being gutless). Only issue with the E4OD is if you do lose one, the cost of a rebuild is much more than a C6.
______________________
Click my supermotors link for tech on TCase, SAS, OBA, Soft Top, Overhead Console, Stock bumper Winch install, much more..:
http://www.fullsizebronco.com/registry/628
Shadofax is offline   Reply With Quote
Old 01-03-2013, 12:46 PM   #4
cajunrebel
Chillin on the Gulf Coast
cajunrebel's Avatar
Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
A built E4OD is pretty darn strong. But you have to keep them cool. I had a Mazda 626, which had a Ford engine and transmission in it, and when Mazda got the design from Ford they got the wrong numbers on the cooling required for the transmission. They put much too small a cooler on the car and as a result the cars had a very high failure rate for the transmissions. Mine had around 22,000 miles on it when I bought it and the transmission was already overheating and acting up. I ended up putting a large cooler and fan on the thing and never had another issue with it. I ran that transmission hard, but I never let the thing get very warm. I know that is a much different vehicle, but the concept is the same. Keep automatic transmissions cool.
cajunrebel is offline   Reply With Quote
Old 01-03-2013, 12:52 PM   #5
Grits&Gravy
What could expected cost be to rebuild e4od with all the goodies ?
Do the broncos come with different t cases like the old Chevys or is the Borg Warner pretty standard for e4od
I'm liking the deeper first gear as opposed to c6
Old 01-03-2013, 01:06 PM   #6
Shadofax
Shadofax's Avatar
yes, nice 1st gear and on top of that you could easily step up to 4.56's if say you were wanting to run the 35's you mentioned.
You can spend over $3k for a built one. When it's time to do mine I'm going to do my best to keep it at about 3k. You can go cheaper, but if you are wanting upgraded pieces to put in your unit, it's going to be over 3.
Most of the tcases (at least later broncos) are 1356, though earlier ones had several other variants. But the 1356 is a strong unit and was used in all the ford fullsize trucks up through the 1 tons.
Old 01-03-2013, 01:46 PM   #7
Grits&Gravy
Now I have read and read about the vss and I keep confusing myself
If I swap my 89. 1 ton 10.25 4.10 into a 92-96 bronco I won't have odometer or speedo with a psom reprogram? Can't I just use the vss off stock bronco 8.8?
I am not too concerned about rear abs as I believe my 89 doesn't have rear abs
Although I wouldn't mind having the rear abs after 1 ton swap
Old 01-03-2013, 01:47 PM   #8
Panthers65
Bronco Info: '93 F150 5.0
I'd love a 5.8 with a E4od and a Manual shift Tcase and Manual locking hubs. later trucks will have MAF too
Panthers65 is offline   Reply With Quote
Old 01-03-2013, 02:10 PM   #9
Grits&Gravy
Any issues with swapping a 5.8'from 89 into a newer maf truck? I am assuming just swap all maf stuff onto older sd motor
Old 01-03-2013, 02:41 PM   #10
cajunrebel
cajunrebel's Avatar
A sterling from an 89 should have the VSS on the top of the differential for the RABS and the PSOM for later trucks.
You may not post replies
Forum Jump
