Plastic inner door sheilds? - FSB Forums
Thread Tools Display Modes
Old 01-06-2013, 01:38 AM   #1
bosshoff
Bronco Info: 67, 70, 73, & 96 DD
Who sells the plastic barrier sheets that go between the door panels and the metal door? I checked JBG and did not see them. Searching here yielded nothing.
bosshoff is offline   Reply With Quote
Old 01-06-2013, 02:17 AM   #2
Steve83
Steve83's Avatar
AFAIK, they are NA; never have been; never will be. Even when I worked at the dealership, I could never get new ones for any vehicle. Not even for an $80K Range Rover.
Old 01-06-2013, 02:35 AM   #3
forbye
forbye's Avatar
Bronco Info: 1990 XLT 5.0, K&N Hot Air Intake, Motorsport Headers, 3" Dynomax Exhaust
I would use a garbage bag cut open...just make sure it's the thicker "contractor" type. That way you can get it to stretch over the armrest mount.
"I can't say that a '90 is going to change your mind about Fords... That era of truck isn't known for exceptional reliability or simplicity of maintenance"-Steve83...Now he tells me!
forbye is offline   Reply With Quote
Old 01-06-2013, 02:37 AM   #4
rhauf
rhauf's Avatar
Bronco Info: 82 bronco 408w 4" lift 35's, 88 bronco 351w all stock on 31s
oh i always got annoyed at that plastic crap and ripped it out.
probably not the best thing for staying weatherproof though.
-Ryan
Check out my youtube page. Many bronco videos.
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 01-06-2013, 02:56 AM   #5
bosshoff
Thanks guys. I like the idea of the contractor bag.
Old 01-06-2013, 05:00 AM   #6
Late Model Man
Late Model Man's Avatar
Bronco Info: '95 351, ZF5, Dana 60s
If you want thicker stuff than a bag, pick up some visqueen at a hardware store, it's way more durable.
SuperFord 95 8-lug Bronco with some stuff...
Late Model Man is offline   Reply With Quote
Old 01-06-2013, 07:38 AM   #7
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
shower curtain and construction tape.
GetBent4x4 is offline   Reply With Quote
Old 01-06-2013, 07:42 AM   #8
Apache0715
Apache0715's Avatar
Bronco Info: 1987 XLT, Locked 9"/Posi D44 SAS, 4.10s, 351W/C6 37" STT 1995 XLT 6" lift, 351W/E4OD 35" AT
garbage back is too thin, get a roll of plastic sheeting (a 10x25ft 6mil at lowes is $23) its used as a vapor barrier in construction, same intention as in a vehicle. Use some 3M strip caulk around the perimeter and a few contact points in the center, then apply the sheeting. the 3m strip caulk doesnt dry up and seals nicely.
Apache0715
1987 Ford Bronco XLT362W/C6 Holley 4bbl Edelbrock Performer, Comp cams
8" SAS Lift, 37" Discoverer STT
D44 Eaton Posi 4.10, Strange 9" 35sp Detroit 4.11
3G Alt and hydroboost
1995 Ford Bronco XLT; 351W, E4OD, 6" Lift, 35" BFG AT
Apache0715 is offline   Reply With Quote
Old 01-06-2013, 08:03 PM   #9
Diesel_Brad
Diesel_Brad's Avatar
I use the wrapping that car bumper covers come in. It is a plastic skin on one side and thin closed cell foam on the other. It is a Vapor barrier and sound barrier in one. I then duct tape it all the way around the edges
96 Bronco 347? 5spd 6" procomp 35" Dick Cepeks
And a ton of other Ford trucks
Diesel_Brad is offline   Reply With Quote
Old 01-06-2013, 09:09 PM   #10
Alex95
351w500 bought my
Alex95's Avatar
Bronco Info: 88 Custom 4.9L, 3.55 gears 31" Dynapro ATMs, BW1356/Top-Hats, K&N FIPK, Welded on bumpers
i just ripped it all out and never looked back. no issues yet
A general rule in modding a vehicle is: Powerful, Reliable, Cheap; You can only pick two, not three.
88 Custom; 4.9; C6; 3.55's; TTB, 8.8; BW1356; Top-Hats; K&N FIPK; 160A 3G, 2G compatible; Flowmaster 40 Series; GT Rollbar; Full Replacement F/R Brush Guards; 2 gal. Viair Air tank/compressor; HornBlasters Shocker XL Train Horns; Full MTX Audio System; Rollin on XD Addicts
Alex95 is offline   Reply With Quote
Old 01-10-2013, 01:52 PM   #11
bosshoff
I am going to use one of those Home depot Husky brand contractor garbage bags. I got some 3M VHB RP5952 series double sided tape to secure it with. I have some other times to address before I fix this, but this is the direction I am taking.
Old 01-10-2013, 02:40 PM   #12
JKossarides
JKossarides's Avatar
Bronco Info: 1986 Bronco XLT 4x4 -AOD -Warn Hubs, NEW stock 302EFI, MSD cap, rotor, 48kv coil, 9mm FMSR wires
I don't have any either but it came that way when I bought the BKO......interesting....lol lol
Good Luck ~
Old 01-10-2013, 09:49 PM   #13
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Hadn't put it in yet but I'm wanting to use "plastic corrugated cardboard"
like political signs are made from. :) Other outdoor signs are being made
from it too it seems, my wife was given a sheet at a convenience store
by the clerk taking a sign down. She knew I wanted it for "her" Bronco. ;)
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 01-11-2013, 01:23 AM   #14
Steve83
Steve83's Avatar
Anything corrugated is too thick to fit between the door skin (which isn't flat) and the door panel (which also isn't flat). It has to be flexible.
Old 01-11-2013, 11:57 AM   #15
Gacknar
The Anti Yam!
Gacknar's Avatar
Bronco Info: 86 Bronco XLT 357w/AOD
Peal-&-Seal
Used as a sound deadener, but if installed properly will act as a vapor barrier.
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears
Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT
My SuperMotors Site - My Engine
The Greatest Thread on FSB
Gacknar is offline   Reply With Quote
Old 01-11-2013, 03:24 PM   #16
Alvin in AZ
AKA: Butthead
Cool, Gak. :)
My plan is to just make the plastic "cardboard" a small L shape.
Going to put some P&S on the plastic after seeing your picture.
Inside...
Anybody on FSB brace their doors besides Butthead?
1/2" square pipe popped riveted to the inside...
...it's -way- more solid than it was but still too floppy. :/
I ain't licked yet. ;)
Alvin in AZ
Old 01-11-2013, 03:40 PM   #17
Gacknar
The Anti Yam!
Gacknar's Avatar
Yes
The light green bar is a steel fence post, runs from the top of the door to the bottom. Did that back in the '90s.
Old 01-11-2013, 10:00 PM   #18
Alvin in AZ
AKA: Butthead
Originally Posted by Gacknar View Post
...a steel fence post, runs from the top of the door to the bottom.
:thumbup
Yeah, top to bottom. :)
That's what I was going to try next. :)
I'm going to bolt it in so it's removable.
Alvin in AZ
Old 02-21-2013, 08:27 PM   #19
mettler
Bronco Info: 1989 XLT
The vapor barrier keeps the cold breeze out. Usually you feel it around the door handle when its cold out. I like the idea of using a shower curtain.
Real men do it in the mud
mettler is offline   Reply With Quote
You may not post replies
Forum Jump
