Headlight and other electrical issues - FSB Forums
Thread Tools Display Modes
Old 01-06-2013, 06:59 AM   #1
stangfromhale
stangfromhale's Avatar
Bronco Info: 1987 Bronco, undergoing surgery
The headlights on my '83 are acting weird. The poor truck had PLENTY of wiring problems from the PO and I thought I had them all worked out. The computer under the seat is removed completely, so the only things left are the lighting and basic engine wiring.
The driver's side headlight will work intermittently. The passenger works as it should. Bumps do not seem to affect the light and neither does switching from hi to low beams. What does happen is the left turn signal will come on (but not flash) and the headlight will go out. Any ideas?
The fuse for the heater keeps popping as well. I've installed a new resistor and all new control switches. Those are all plug and play, so I don't think I've cross wired anything. When the fuse is good, all works as it should.
The emergency flashers do not work. All turn signals work as they should, but when I pull the flasher tab out, nothing. All fuses check out.
The PO installed a Grant steering wheel. When the fuse for it isn't popped, when I depress the horn button, the horn barely blows and every now and again I catch a glimpse of a very small blue spark behind the horn button on the wheel.
I wish I could just order a whole new wiring kit and re-wire the entire truck. Seems like that would be easier than chasing down the little gremlins lurking around.
1983 Bronco, 351W/C6 For Sale
1987 Bronco, no computer, build in progress
2013 Brembo GT
stangfromhale is offline   Reply With Quote
Old 01-06-2013, 07:54 AM   #2
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
I would start out by pulling all the out side bulbs and see if any of the bulbs have any burnt out filaments, or possibly a filament burnt out in a bulbs and fell across a second filament causing it to seam to go on but not work properly.
I would also try to get a stock steering wheel and get ride of the grant wheel. I've always heard of people having issues with them when it comes to a horn or other wiring issues.
"hold my beer and watch this"
Hydroboost walkthrought
My Build Thread!! II
My Build Thread!! - retired
Ewgoetz is offline   Reply With Quote
Old 01-06-2013, 02:04 PM   #3
Steve83
Steve83's Avatar
Start with the ground wire for the L h/l bulb. It's probably broken, loose, or corroded. Then check the connectors on the h/l bulbs - they commonly fatigue, crack, burn, drop terminals, the insulation shrinks, or the wires break off at the terminals. Then pull the switch & inspect its terminals - they commonly burn, too, but that would affect both sides.
Get a digital multimeter (DMM) with a 15A range on DC, remove the 30A blower fuse, and check current draw across that socket with the blower running on each speed.
Work the hazard switch several times. Its contacts corrode from lack of use, so it may need replacement. Click this & read the captions:
Get a new horn. They're cheap in junkyards.
Rewiring an entire vehicle isn't easy; certainly not easier than repairing a few faults. I'd repair a sawzalled harness before I'd replace it. And even if you COULD buy a new or unmodified original wiring harness that fits your truck & all its options, it would cost more than you paid for the truck. The only person I know of who even comes CLOSE to offering replacement wiring harnesses for these trucks is Ryan.
http://www.oldfuelinjection.com/
http://rjminjectiontech.com/
Old 01-06-2013, 06:23 PM   #4
stangfromhale
I may change out the whole switch like you did in the diagram. When I use the left turn signal, sometimes I have to play with the lever for it to work correctly.
Replacing the entire wiring harness in the truck was more of a joke (sarcasm gets lost on these boards).
So when I test the amp draw on the heater, what should I be looking for numbers wise? The truck was originally equipped with A/C but it's long gone. Nothing of the system is left except for the bracket that held the compressor. Condensor, evaporator....everything is gone.
2013 Brembo GT
Old 01-06-2013, 08:32 PM   #5
Steve83
Steve83's Avatar
Originally Posted by stangfromhale View Post
...sometimes I have to play with the lever for it to work correctly.
Are you old enough for Viagra?
Well, look at the specified fuse size.
Old 01-06-2013, 09:06 PM   #6
stangfromhale
Are you old enough for Viagra? Well, look at the specified fuse size.
It's apparently excedeing 30amps which is what the required fuse is. I guess I should rephrase my question. What would make it pull more than 30 amps?
2013 Brembo GT
Old 01-06-2013, 09:11 PM   #7
Steve83
Steve83's Avatar
V=R*i, so the only thing that causes too much current (i) is not enough resistance (R) for the voltage (V). High voltage would affect the whole truck, so it has to be low resistance on that circuit, which could be caused by: a bad motor; a motor that needs oil; wiring faults; a bad switch; wiring modifications...
BTW
It's actually exceeding 34A, which is where a 30A fuse blows.
Old 01-06-2013, 09:15 PM   #8
stangfromhale
BTW
Thanks Steve. The plugs look good that hook in to the resistor and motor. I replaced the fan speed switch and the vac. selector switch as well as the resistor. The only thing that's left is the motor. So I should try replacing the motor? They aren't much anyway and everything else is new so I guess it wouldn't hurt.
2013 Brembo GT
You may not post replies
Forum Jump
