79 to modern tail light conversion. Anyone ever done one? - FSB Forums
Thread Tools Display Modes
Old 01-13-2013, 02:26 PM   #1
DirkDiggler
Bronco Info: 79 Bronco. bone stock ... for now
So i am looking to update the look of my bronco. I am in the middle of doing a bunch of body work as it is, and thought it might be nice to freshen up this thing a little. I am looking to model the front grill after a modern f250, fill the molding channel in the middle of the body to make it more uniform, grind off the drain trim around the door, and put in modern tailights.
Only issue is i cant seem to find anyone who has converted the old one sided tailight to a wrap around one. Main issue is the body shape at that point. There has to be some truck that has a tailight that would match the body lines. Anyone ever seen it done?
DirkDiggler is offline   Reply With Quote
Old 01-13-2013, 04:58 PM   #2
Fox005
The Original FullSize
Fox005's Avatar
Bronco Info: 78XLT Ranger,6"and35x12, Built351,Race Rad,Roll Bar,100MPH Speedo,Tach,LED Lights ,
It would be easier to weld in a filler and do a roll pan with Custom taillights . I posted some pics in another thread it's a later model . I'd say frenching ( installed behind the sheetmetal)in a set of something close might be do able ? Maybe clear lenses with red LEDs for a more modern look would be a better choice ? I've never seen the mod on a 78/9 that you are after but have done lots of body mods . My flat black 87 I shaved everything , drip rails , emblems ,handles ,locks and tail lights . Cool idea and lots of tail lights out there .
Fox005 is offline   Reply With Quote
Old 01-13-2013, 05:44 PM   #3
JBfab
JBfab's Avatar
Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Best way to add tail lights from any other truck is to cut the bucket out of said truck. Make a cardboard template of the shape of your rear corner and wonder threw the junk yard/used car lot till you find the right shape/design you like.
It's not custom if you bought it from a catalog!
Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825
JBfab is offline   Reply With Quote
Old 01-14-2013, 10:15 AM   #4
deathmobile2
Bronco Info: 1978 XLT Ranger; 400, AT, 4" Superflex Lift, No Rust & No Knicknacks!
Don't do it man - it will look like ass.
deathmobile2 is online now   Reply With Quote
Old 01-14-2013, 11:22 AM   #5
psychlopath
Student of life, man.
psychlopath's Avatar
Bronco Info: 1979 Freewheel'n, PowrLok, ARB, OBA, and anything else I can cram in
I'd love to see pictures of every step with this project. Have you done anything so far??
I <3 FAR 43.
psychlopath is offline   Reply With Quote
Old 01-14-2013, 03:10 PM   #6
Robs79BBbronco
Robs79BBbronco's Avatar
Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
agreed....how about leaving the lens and doing an LED conversion?...that would be modern, but not take away from the unique features of these old trucks.
Robs79BBbronco is online now   Reply With Quote
Old 01-14-2013, 03:28 PM   #7
379sinvb
Resurection Ranch
379sinvb's Avatar
Bronco Info: War Horse,Blue Eyes,Black Stallion & Youngblood the newest member.
Personally I like the placement of the lights in these. I'm with Rob and think the LED would look good. I have purchased the LED trailer lights and have an idea of how I'm going to do it.
Rick
My Project- "Left for Dead"
379sinvb is offline   Reply With Quote
Old 01-15-2013, 07:38 AM   #8
Stonewater
Stonewater's Avatar
Bronco Info: #1: 1979 XLT Free Wheeler. #2 1979 XLT.
I'm looking forward to seeing that! I've been looking for an LED set for the bronco with no luck.
Stonewater is offline   Reply With Quote
Old 01-15-2013, 10:53 AM   #9
Fox005
Fox005's Avatar
I found the complete set of clear lenses and individual LEDs for exterior and interior .You don't have to change the lenses but why not while doing the upgrade?
www.hipoparts.com has LED Gauge Upgrades
www.memoimports.com has All Clear Lenses for Exterior
www.carid.com has LED bulbs and Color Lenses
Ebay has LED Bulbs and Kits
Headlights with LEDs come in other color versions
Old 01-15-2013, 11:35 AM   #10
joseph69
joseph69's Avatar
I dont have pictures up, but I cut out the back of the taillight and put in one of these.
I just cut enough room for it to fit and duct taped it in.
Passing red light through a red lenses does not reduce the brightness.
joseph69 is offline   Reply With Quote
Old 01-15-2013, 01:02 PM   #11
379sinvb
Resurection Ranch
379sinvb's Avatar
Started a thread with more info
Delet the thread and put it here. It will cut down the search results saving us time. I looked at it by the way good info. Thanks
Rick
Old 01-15-2013, 01:58 PM   #12
Fox005
Fox005's Avatar
You got it
Old 02-27-2013, 07:32 PM   #13
Dovepower
Dovepower's Avatar
Bronco Info: '79 Bronco 460 C6 coilsprung D60front/D70rear 1410Driveshafts 40"swampers 6"susp/3"body
"fill the molding channel in the middle of the body" on a '79??
"Everything feels tight when you're full-sized!"
Dovepower is offline   Reply With Quote
Old 02-27-2013, 08:45 PM   #14
EastLA78Bronco
oscar espinoza
EastLA78Bronco's Avatar
Bronco Info: 78 bronco, 460 mild built. D60 front 14 bolt rear. detroit lockeds. OBA. twin stick np205. built c6
just what i did..
[size="4"][font="Fixedsys"]78 bronco, 460 cid,true dual exhaust,c6 with a shift kit,NP205 twin stick,9"lift,shackle flip,14B/D60d, 410 gears, 40" boggers. croseovver stering r
EastLA78Bronco is online now   Reply With Quote
Old 02-27-2013, 08:53 PM   #15
Happster
99 Problems
Happster's Avatar
Bronco Info: '79 Bronco XLT Ranger, 351M, 205, C6, LS 9"
just go buy a newer truck if you want yours to look like one... i'm sure there are plenty of folks looking for a '79 that doesn't look like the new crap they make :P
sounds like a lot of filler otherwise
I know you believe you understood what you think I said
but i am not sure you realize that what you heard
is not what i meant
Happster is offline   Reply With Quote
Old 02-27-2013, 10:54 PM   #16
79BOSSHOGG
79BOSSHOGG's Avatar
Bronco Info: 1979 Ford Bronco Custom, 351m, c6 auto, np205 transfer case, 4" suspension lift, 35" tires
I agree! The point of having a 78/79 is the old look. Why have one if you want to modernize it that much? Some modern things are good like led bulbs or 3G alt or rear disks, but that's not major changes to the old look
[><]BOSS HOGG[><] NOT A CONCRETE QUEEN!!! GOTTA PAY TO PLAY!
79BOSSHOGG is offline   Reply With Quote
Old 02-28-2013, 07:16 AM   #17
CBboots
CBboots's Avatar
Bronco Info: 79 Custom, 460, C6
Dude, it's your Bronco...do what you want to it.
In a world where we have some 'tard paying through the nose to have a customs shop put an F150 interior into a fullsize (among other things)......frenched tailights is nothing, lol.
Not the way I would go, but as long as it's safe, it works and you like it...go for it. Custom mods are always cool
My 79 build http://www.fullsizebronco.com/forum/...d.php?t=207864 - Aluminum 3-core radiator, Mallory 85 HEI conversion distributor, High Angle Driveline One Tons front and rear, JBFAB Twin stick shifter kit, True trac differentials front and rear, Yukon 4.56 gears front and rear, Moser Extreme 31 spline rear axles, Borgeson adjustable steering shaft and rag joint, 95 amp 3G alternator, Fireguy/RJM Tech upgraded headlight harness, and a ton of other crap!
CBboots is offline   Reply With Quote
Old 03-02-2013, 12:54 PM   #18
johnnyreb
Thumbs up
Thanks Fox005. I just looked at them and was wondering if someone had brighter dash lights . All 3 companys has 78-79 bronco updates and the prices are cheaper then some I had looked at. I liked the clear front park light lens for $39 -A PAIR. I saw them one place at $55 EACH and passed . Thanks again.
johnnyreb is offline   Reply With Quote
Old 03-04-2013, 11:44 AM   #19
scott79
scott79's Avatar
Bronco Info: 4-79 Ranger XLT Bronco's, 2-96 EB Bronco's, 4-79 F-150's 4x4, 3-79 F350 SC 4x4, 1997 F350 XLT 4x4 PS
Check out the thread for "LED interior upgrade"...Look at what ranger429 did, I plan to do the same to a couple of mine in the near future.
YESTERDAY WAS ABOUT HONOR, TODAY IS ABOUT JUSTICE
scott79 is offline   Reply With Quote
Old 03-10-2013, 12:29 AM   #20
Fox005
Fox005's Avatar
Haven't got the clear exterior lenses but I have all the bulbs now .The interior colored Look like Lego blocks
I Dont always go Wheeling, but when I Do I prefer "Green Goblin" 78 Bronco XLT Ranger
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
