351w suggestions? - FSB Forums
Thread Tools Display Modes
Old 01-14-2013, 08:43 AM   #1
Pennywiserawker
Pennywiserawker's Avatar
Bronco Info: 95 XL Emerald Green
351w suggestions?
Okay so have done a little bit of searching here but since I'm at work, I'm a little limited with time here.
Engine specs:
-'95 351w roller motor Bored .15 over
-Erson cam ( need to find the cam card)
-1.6 Erson roller rockers
-Stock upper and lower intake
-Stock '95 351w automatic trans Speed Density Computer
-Stock freshened up bottom end
-Stock injectors
-Cast Iron GT40 Lightning heads
The cam is a bit much for the SD comp. I'm looking more into doing the MAF conversion and I'm trying to gather more information about it.
I plan on buying the RJM wiring harness or snagging one from a BKO I saw in my local junkyard.
Member here psmwrx recommended to use the 4 hole Exploder injectors.
Any suggestions you guys have for me would be greatly appreciated
I'd love to get my hands on the matching GT40 upper and lower intake from the Lightning but have had trouble finding the lower. I heard they make some sort of spacer so you can run an Exploder 302 lower. Is that true/okay to do?
Thanks for the help!
Cole
Built 351 w/GT40 heads, E-fan, Flowtech ceramic coated shorty headers, Bassani y-pipe, single chamber 3" muffler,10.25" rear, ZF 5spd, 16.5" chrome wagon wheels, 37"x 12.50" Goodyear Wrangler M/T OZ tires, 6" lift ProComp rear leafs, Front Leaf D60 SAS Front bumper build in progress!
Pennywiserawker is online now   Reply With Quote
Old 01-14-2013, 11:46 AM   #2
88bronc91stang
88bronc91stang's Avatar
Bronco Info: 88 Bronco XLT, 5.0/AOD...the engine is a roller motor from a 91 Mustang GT
The 351W GT-40 lower should still be available through FRPP, Summit Racing, Jegs or any of the gazillion aftermarket suppliers that specialize in Ford performance parts. I've never seen any kind of adapter plates that would allow running a 5.0 lower on a 5.8 block. Just imagine, there would be two more intake gaskets to worry about, not to mention the front and rear lifter valley seals would have to be almost an inch thick to compensate. Keep trying the salvage yards if you don't want to buy a new lower...surely some yard either has or can find a Gen I Lightning intake set.
88 Bronco XLT (was stock, now has a 91 HO roller motor)
90 Mustang GT (not much left that's stock)
96 F-150 XL (it has A/C!!!)
81 Chevy C-10 (wrecked)
88bronc91stang is offline   Reply With Quote
Old 01-14-2013, 01:51 PM   #3
Pennywiserawker
Those companies make a reproduction GT40 lower? Or is it something that the GT40 upper will mate up to?
Good call on double the gaskets. That didnt even cross my mind
Old 01-14-2013, 02:09 PM   #4
CrazyBRONCOguy
SOD BUSTERS Member
CrazyBRONCOguy's Avatar
Bronco Info: Which One?
http://www.pricemotorsport.com/html/...e_adapter.html
this place is literally down the road from me
BCbroncos also makes an adapter to go from a 351 lower to a 302 Mustang upper.
there is also the edelbrock efi truck intake you can buy the lower only and then run their mustang upper on top of that.
'92 Eddie Bauer- C6/208 swap, Roller 357W, MAF, RJM Harness, BlueOvalChips SCT Tune
'78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's
'96 F250- Tow Rig, 460, E4OD Punisher Valve Body, Triple Piler Gauges
'92 F150- 2wd, Winter Beater, 3.73's, 5.0
'79 F250- 2wd, Farm Truck, Waiting Restoration
'03 SVT Focus- Daily Driver, OZ Wheels, 6 Spd
'86 Mustang- Fastback, SOHC 4.6L Swap Project
CrazyBRONCOguy is online now   Reply With Quote
Old 01-14-2013, 07:47 PM   #5
Swat
Swat's Avatar
Bronco Info: 1993 F150 Flare Side
I have seen Lightning lowers recently on ebay and corral.net classfieds. Expect to pay though, $300 plus.
Find that cam card to see if a MAF upgrade will run it.
The Mtn Bolt - 93, F150, Flares Side, Short Bed, 4X4, Tweecer Tuned, Built/Blown 351W, Punisher E4OD, 4" lift, 4.11's and 33's on Hurricanes.
Swat is offline   Reply With Quote
Old 01-14-2013, 10:34 PM   #6
gadawgz71
gadawgz71's Avatar
Bronco Info: 96 M EB w/ SAS'd D44 35s 302, 95 Blk XLT 351
Your not going to find a full gt40 5.8 intake for less than $700. And your surely not going to find one in a j/y. There is always an exception but not in this case.
Like mentioned above, the eddy b intake can be had for a smidge over $600 or go the 5.8 lower-to-5.0 upper. In my opinion, the eddy b intake is not worth the price. Others will disagree but, I felt it was not enough bang for the buck. They're also very hard to find used as well.
You'll be fine running either intake w/ a set of gt40's but keep that cam SD friendly.
1996 M EB SAS D44 w/ 35's 302w-1995 Black XLT 351w-
SOLD
1996 PG EB 351w -1996 Wht EB 351w-1996 Wht Sport 351w
1996 MB EB w/ KR Interior 302w-1996 EB 351w, 3" BL- 1996 PG EB 351w
1996 351w, 115k - 1996 EB 351w- 1996 Blk Sport 408w
1995 Blk Sport 113k - 1996 Wht sport 351w-1996PG EB 351w
1993 EB 351w - 1990 302w/ M5OD -
1978 XLT 351m - 1971.5 Sport, 331w
gadawgz71 is online now   Reply With Quote
Old 01-14-2013, 10:59 PM   #7
DNBELOWBRONCO
DNBELOWBRONCO's Avatar
Bronco Info: '96, 5.8, 4.56, Rancho 4", 35's, Thorleys, Warn 8274, 5100's, 160 3G, Sag, 10.25, E-fan, Projectors
Engine specs:
-Stock injectors
Cole
If you're looking into the RJM wiring harness then you should also look into his 3G 160 amp alt to replace that stock 65 amp one, looks nice black though. That will help power all your new and up coming stuff..... -Kevin-
DON'T GIVE UP PUSH THE PEDAL ON THE RIGHT JUST A LITTLE BIT HARDER DNBELOWBRONCO www.supermotors.net/17883 "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind" -Dr. Seuss-
DNBELOWBRONCO is offline   Reply With Quote
Old 01-15-2013, 09:30 AM   #8
Pennywiserawker
Thanks guys! Yeah I've been running this set-up for almost a year now. It runs fine and has more power than I expected. I just want to make sure it is running as smooth as can be. I know I saved the cam card somewhere but it'll take some time to track the fawker down.
I have often thought about doing the 3G alt upgrade but just haven't found the need/money/time to do so. \
Old 02-06-2013, 02:24 PM   #9
Jlrobbins
351 swap/build
I have a 1992 bronco with the 5.0 as well as a 95 with the 5.8. I just got the 95 for the engine and trans, I plan on building the 351w starting in a month or so and I am trying to decide the best route to go. Preferably I would like to take the 351 .030 oversize and find a set of gt40s off of a 96-97 explorer and have them milled and drilled to fit the windsor. What i desperately need help with is a cam and good rebuild kit. I found several on summit but I am unsure of whether or not I should get hypereutectic or forged dish pistons. The hypers have a 9.12:1 comp ratio with 63cc heads and the dishes have a 9.06:1 with 63 cc heads. I would like to get 330-350 whp out of the truck so anyone who has done this or knows of a good streetable yet aggressive build please chime in. I know its going to be hard but i would like to stay around 2k on the build.
thanks in advance
Jlrobbins is offline   Reply With Quote
Old 02-06-2013, 03:07 PM   #10
Pennywiserawker
In complete honesty, i took my entire motor apart down to a short block and took it to a good friend of mine who specializes in Gran National motor work. But he knows a good bit about mustang stuff as well. I bought the cast iron Lightning heads on CL for $265 and the were freshly rebuilt. Took the SB and heads to him and told him what I really wanted to do, my budget and that it was going in a 6500 lb truck lol. I paid him 2k total and this motor runs way beter than I ever expected.
Old 02-06-2013, 08:51 PM   #11
huggyb1972
Dirty Minded
huggyb1972's Avatar
Bronco Info: 89' Bronco 5.8l Variable Speed V8, Forward, Rev, Turns left, right, stops, and everything.
That is good news I'm thinking about using a set of GT40's I aquired yesterday I am on 37's and have a ZF5-47 ready for a swap. What gears are you running and are you happy with them?
DRAFTHORSE
351W, C-6, 10.25/D44
FOTM DEC. 2011
"Quando Omni Flunkus, Moritati,"
When all else fails roll over and play dead.
I'm as Free as Federal, state, and local laws/ordinances allow.
huggyb1972 is online now   Reply With Quote
Old 02-07-2013, 12:50 AM   #12
rwrankin
being from the mustang world I have seen the spacers so you can use a 302 lower. you are right though..they are a PITA. prone to leakage.
rwrankin is offline   Reply With Quote
Old 02-07-2013, 12:35 PM   #13
Jlrobbins
So can someone knowledgable of 351w help me with some suggestions about a budget build. I want to use gt40 heads, maybe the E7s I someone can convince me they can flow as well as the others for around the same price. I am lookin for 350 whp and spend 2k or less.
Old 02-07-2013, 02:37 PM   #14
Diabolic
I don't want to burst your bubble but it just isn't going to happen. There is no way you will get 350, 340, 330, 300, or even 275 whp with any Ford cast iron head. Think about it for a second. The Lightning engine had a great performing GT40 intake, GT40 heads, 65mm tb, and factory headers. They lay down a whopping 220 to the tires and this is through a 2wd setup. Lets say you get an offroad exhaust with Longtubes all in 3", swap the camshaft to something a little more aggressive and add 1.7's. You still have heads that even when ported don't flow well above .500 lift. That really limits the camshaft selection. Now lets think about the SD aspect of it. Anything more than 220º duration and a 114º LSA and you need MAF. Anything above 210º and you really need a stall converter too.
I personally have Longtubes, AFR heads, HO Roller camshaft, GT40 intake, 70mm tb, 4" CAI, 1.7 RR's, UD crank pulley, Electric fan, and a tune. That combo was making 300 to the tires. Any combo that has heads with the letters GT40, GT40P, or E7, and you can count on 250hp to the tires. Thats assuming headers, intake, exhaust, and camshaft are all upgraded from stock Bronco 5.8 parts. if you want to just barely make or maybe on a good day slightnly exceed 300hp to the tires then you will need TW 170's, 190's, AFR 165, 185 in the combo.
1995 Bronco, OJ Edition, 5.8/E4OD, Towing Package, LS 3.55's, 32/11.50/15's, 15x10 wheels, Warn Manual Premium Hubs, Panel K&N, Moates QH. Stock as a rock.
Diabolic is online now   Reply With Quote
Old 02-07-2013, 02:49 PM   #15
Pennywiserawker
Im running 4.10's and they are a perfect match for the ZF and the 37's
Old 02-07-2013, 06:40 PM   #16
huggyb1972
Dirty Minded
huggyb1972's Avatar
Wierd I was thinking 4:10 would be a little to tall on the top end. I was thinking more along the lines of 4:56. How much trail do you see with yours?
DRAFTHORSE
FOTM DEC. 2011
Old 02-07-2013, 07:20 PM   #17
Jlrobbins
Well how much would the tws or afr heads run me? I'm gonna get at least 300 out of it or I'm gonna reconsider the build and put the money into an old 86 fs blazer with a 6.2 diesel that needs swapped to a gas truck. What cams are ad friendly. I've heard a lot about the 5.0 ho cams but I don't want to put a used cam in with all new internals. Does anyone know that cam specs so I could call around about having one ground to the right spec if I go that route.
Old 02-07-2013, 07:39 PM   #18
Diabolic
10.1 compression ratio
TW 170 FAC heads
GT40 or ported RPM intake
Cam with 212/218 dur, .555/.575 lift, 114 LSA
30# inj
Shorty or LT headers, 2.5" exhaust
70mm tb
1.6 Roller Rockers
Mark VIII electric fan
Chip for the 30's.
That will get you 300 to the wheels.
Old 02-07-2013, 09:16 PM   #19
rwrankin
ok first of all, all manufactures of this area were prone to under estimating actual rhp output to prevent getting the crazy eye look from the EPA. So you cant base your logic off that.
Secondally, you are incorrect, a gt40 iron is capable of handling 300 + horse power. Heads are not the the only variable to produce horse power. With mild porting and polishing of ports and gasket matching..a iron GT40 matched with the right components can produce over 300 rear wheel horse power naturally aspirated. more with forced induction or nitrous.
I had gt40's in a mustang both natural aspiration and forced induction and have produced 300-400 respectively. With a 302.
It can be done.
Old 02-07-2013, 09:23 PM   #20
rwrankin
I have been toying with 302- 351 windsors for over 10 years. I can tell you it can be done, but its not just the heads. you have to take in account everything else; induction, exhaust, cam, timing, fuel, and computer.
Bud, I think you are going to hit a wall with the computer. These Bronco computers do not adjust to variable changes; like air intake, fuel ratios, higher combustion, more timing, valve overlap, ect.. These computers are designed to run the motor efficent with minimal emmisions.
To get your disered horse power, if you want to stay fuel injected, I think you will have to invest in a computer management system or chip.
If you want to carb i think you can get it with in your budget.
You may not post replies
Forum Jump
