mercury cougar motor questions? - FSB Forums
Thread Tools Display Modes
Old 01-14-2013, 09:23 AM   #1
IIVIIoonshiner
IIVIIoonshiner's Avatar
Bronco Info: 1994 f-150, 5.0, 4x4, zf 5-speed, short wheelbase daily driver
so I blew at least one head on my 302 several months ago and the truck has just been sitting. I have been debating doing something trick like a 4bt or just going back with a stock 302 or something inbetween.
I just got offered a free 5.0 from a 1987 mercury cougar xr7. less than 100k miles on car when wrecked sideways in a ditch.
my questions are...
1.how does this motor compare? same?
2.would yall put the longblock straight in and switch the stock stuff over to it or would you do a stroker setup or something cool?
3.I have another truck I'm driving right now... should i hold out for a frito truck to show up?
I realize that some of my questions are just for your opinions but I'm very undecided right now on what direction to head in. I do feel like a little extra power would be nice going up hill (my truck is not lifted) but maybe my motor was just tired....
I wheel japanese metal ---- don't hate me ---- I still drive my Ford everyday
Toylexurai buildup
IIVIIoonshiner is offline   Reply With Quote
Old 01-14-2013, 09:25 AM   #2
IIVIIoonshiner
oh and my motor was over 200k fyi
Toylexurai buildup
Old 01-14-2013, 11:04 AM   #3
Gacknar
The Anti Yam!
Gacknar's Avatar
Bronco Info: 86 Bronco XLT 357w/AOD
Whats your budget?
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears
Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT
My SuperMotors Site - My Engine
The Greatest Thread on FSB
Gacknar is offline   Reply With Quote
Old 01-14-2013, 11:13 AM   #4
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Cool. :)
Me? For the least money I could, I'd swap parts and get it going.
No EEC or other hassles, I'd just have fun swapping parts. LOL :)
Knowing the whole time it'll run good, see? :)
Right after you get it bolted in, hit the key and go for a drive. ;)
As far as rings, bearings, valve guides/seals etc, check all that out
while you got it out, but if they're within spec... keep 'em.
There'll be plenty of future opportunities to take advantage of in
a whole different way?
Alvin in AZ
ps- Compression test it etc :)
Alvin in AZ is offline   Reply With Quote
Old 01-14-2013, 11:31 AM   #5
88bronc91stang
88bronc91stang's Avatar
Bronco Info: 88 Bronco XLT, 5.0/AOD...the engine is a roller motor from a 91 Mustang GT
The long block is basically the same. Only real difference would be the cam (the Cougar should have had an HO, so it's a hydraulic roller with a bit more lift) and the pistons (HO's had TRW forged pistons). Swap the oil pan, pump, pickup, intake and exhaust manifolds and front accessories and ride. I just swapped an HO 5.0 from my 91 Mustang into my 88 Bronco and it runs great.
The stroker setup will end up costing quite a bit. Ballpark $800+ for the stroker kit, then machine work (boring the block, having the lower cylinder walls cut to clear the longer rods).....and you would still have a stroked short block with E7 heads, which would negate any hp gain from the increased displacement.
88 Bronco XLT (was stock, now has a 91 HO roller motor)
90 Mustang GT (not much left that's stock)
96 F-150 XL (it has A/C!!!)
81 Chevy C-10 (wrecked)
88bronc91stang is offline   Reply With Quote
Old 01-14-2013, 01:40 PM   #6
Gacknar
The Anti Yam!
Gacknar's Avatar
Check the heads. They should be E7TE, but a few 86 E6TE heads could have slipped out in 87 on an H.O. engine.
If there E6 heads, well that brings up a few issues with engine mods. That and E6 Heads suck.
Old 01-14-2013, 01:54 PM   #7
Moze
Moze's Avatar
Bronco Info: 1982 302, T-18, 4in lift w/35's
Were all cougar motors HO or just certain ones? I grabbed a engine from a 86 cougar didnt check the model but its a roller engine. Just changed over my intake, carb, headers, valve covers and oil pan.
Moze is offline   Reply With Quote
Old 01-14-2013, 09:16 PM   #8
IIVIIoonshiner
He seemed to think it was not an ho motor
Toylexurai buildup
Old 01-14-2013, 09:31 PM   #9
BigWheelz
Bronco Info: 1978 Bronco, 466 EFI
87-88 cougar / t-bird had basically the same engine as the crown vic. Cast pistons, peanut cam, E6SE heads. It is not an HO
Opportunity is missed by most people because it is dressed in overalls and looks like work- Thomas A Edison
BigWheelz is offline   Reply With Quote
Old 01-14-2013, 10:31 PM   #10
Gacknar
The Anti Yam!
Gacknar's Avatar
E6 heads are a problem. The heads suck, and the pistons are flat tops.
And your right it is E6SE, not E6TE. My bad.
Old 01-15-2013, 09:11 AM   #11
IIVIIoonshiner
what was teh stock truck motor rated at? comparable hp? torque?
if the heads suck... which i believe you... will i notice on a stock truck or is that more likely to be a problem with lifts tires more hp etc?
also would it be better for me to find new heads for the motor I have and freshen it up? are there say mustang gt heads that are really beefy or some jazz?
Toylexurai buildup
Old 01-16-2013, 09:36 AM   #12
IIVIIoonshiner
can i get some thoughts on this before it gets too many pages back guys? thanks ever so much!
Toylexurai buildup
Old 01-16-2013, 10:40 AM   #13
Apache0715
Apache0715's Avatar
Bronco Info: 1987 XLT, Locked 9"/Posi D44 SAS, 4.10s, 351W/C6 37" STT 1995 XLT 6" lift, 351W/E4OD 35" AT
take the engine from the mercury, Change the oil pump/pickup/pan front accessories, go get a set of GT40 heads from a junkyard if you can. Make sure it is all within spec and replace necessary seals/gaskets. If you can get a bassani or other better Y pipe and some headers. Probably the best bang for your buck, but the other guys on here can correct me if Im wrong. It would be nice to have a block to freshen up without decommissioning your ride.
Apache0715
1987 Ford Bronco XLT362W/C6 Holley 4bbl Edelbrock Performer, Comp cams
8" SAS Lift, 37" Discoverer STT
D44 Eaton Posi 4.10, Strange 9" 35sp Detroit 4.11
3G Alt and hydroboost
1995 Ford Bronco XLT; 351W, E4OD, 6" Lift, 35" BFG AT
Apache0715 is offline   Reply With Quote
Old 01-16-2013, 05:23 PM   #14
rcracerx
rcracerx's Avatar
Bronco Info: 5.8 m5od 33" cooper STT removed sway bars msd ignition, MAF swap with open filter, SAS, M15000
If you had the cash, look into a 4bt swap, they put out more torque, though not as much HP, but when your getting close to 30MPG I would rock it if I had the coin.
BIG BABIES!!!
rcracerx is offline   Reply With Quote
Old 01-16-2013, 06:43 PM   #15
Gene1219
I put a '90 Grand Marquee engine in my rig without too much issues. The one thing that I did run into is that the car's block did not have a provision for the knock sensor (just a freeze plug in it's place) I've been running without the knock sensor without issue and get no codes.
On performance wise, i think the engine from the Grand Marquee is rated only a few HP higher than the bronco (maybe only 5hp?) It is slow, but then again, most cars/trucks from the bronco's time period were slow/low HP anyways. I haven't noticed any gains or decrease in performance.
Gene1219 is offline   Reply With Quote
Old 01-16-2013, 11:46 PM   #16
Andrew James
Age. Fac ut gaudeam
Andrew James's Avatar
Bronco Info: 1978 Ford Bronco RangerXLT 400/C6
You should prolly drill & tap the block for the knock sensor mate.
1996 Ford Bronco Eddie Bauer 5.8/E4OD EFI
1978 Ford Bronco Ranger XLT 6.6/C6
2004 Jeep Liberty 3.7/42r
2000 Hyundai Tiburon 2.0/5speed
2002 Honda Shadow Spirit 1100
Andrew James is offline   Reply With Quote
You may not post replies
Forum Jump
