t19 swap? - FSB Forums
Thread Tools Display Modes
Old 01-16-2013, 12:06 AM   #1
joerickson
Bronco Info: 1978 F150 Shortbed
t19 swap?
Swapping in a t19/205 for the c6/205 in my 1978 f150, and running into some problems.
I bought the trans and tcase from a junkyard about 3 hours away, got home and found that the adapter housing on the 205 will not bolt up to the t19. Wondering if anyone else has run into this problem.
I talked with the yard I got it from, and from the measurements I gave them all they could come up with is an aluminum adapter that came on the np208/bw1356 tcases. Would this work?
t19 is from an 86 f350 if that helps.
joerickson is offline   Reply With Quote
Old 01-16-2013, 02:51 PM   #2
InfoFord
InfoFord's Avatar
Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
tcase in ford all share the same bolt pattern and spline count
the adapter will work if it does not have the notch for the shifter rod then cut one in
Trent
NORTH COUNTRY SPECIALTIES
Picador (1979 4door Bronco)
79 Ford CrewCab 4X4(My Dually Project)
79 Ford Bronco and My Boat
InfoFord is offline   Reply With Quote
Old 01-16-2013, 03:33 PM   #3
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Originally Posted by joerickson View Post
Swapping in a t19 in my 1978 f150, ...t19 is from an 86 f350
Cool! :)
That transmission's going to kick butt. :)
You seen this? :)
http://www.novak-adapt.com/images/gr...ecs_gasket.gif
More gear ratios just for comparison...
1st 2nd 3rd 4th 5th -R-
T18 ========== 6.32 3.09 1.69 1.00 === r7.44
ZF M5OD-HD ==== 5.72 2.94 1.61 1.00 0.76 r5.24
Mazda M5OD-R2 =- 3.91 2.24 1.49 1.00 0.80 r3.39
NP435 ======== 6.69 3.34 1.74 1.00 === r8.26
E4OD ========= 2.71 1.53 1.00 === 0.71 r2.18
Clark282V ====== 6.99 4.09 2.17 1.17 1.00 r5.89
NV 4500 ======= 5.61 3.04 1.67 1.00 0.73 r5.61
Alvin in AZ don't know nuthin''bout 4wd stuff :/
Alvin in AZ is offline   Reply With Quote
Old 01-16-2013, 04:20 PM   #4
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
Butthead, you should put that in the transmission and tcase information sticky
2006 Kia Spectra 4 banger/5 speed.
I like to eat poop.
New nuts are in the plan.
TheUnforgiven is online now   Reply With Quote
Old 01-16-2013, 10:47 PM   #5
bluebolt
Bronco Info: 1978 F150 with 1966 cab
Trans.
What parts exactly did you get?
Is the trans a 4wd trans?
Was the transfer case adapter from that trans??
Or did the transfer case adapter come from the 205?
bluebolt is offline   Reply With Quote
Old 01-16-2013, 11:34 PM   #6
joerickson
The trans is a 4wd, as it has the trapezoid pattern and not the square. The transfer case had the adapter on it.
I had an idea that there were different adapters between the c6 and manuals, just didnt have any measurements to go off.
Alvin in AZ, I have seen the Novak website. Decided on the t19 for the syncro'd first gear, and ended up getting one with the 4:1 gear as well. Should work well on the street with 33's and 3.50 gears.
Old 01-17-2013, 12:06 AM   #7
bluebolt
Adapter
So where is the adapter that was on the T-19? Is that the aluminum adapter that they are offering you? If so it should work. A T18 adapter will probably work as well.
Old 01-17-2013, 12:39 AM   #8
joerickson
There was no adapter on the transmission, that's the problem I am trying to solve. The junkyard said the only adapters that match the measurements I gave them is the aluminum ones.
I just wanted to make sure it would all work before having them ship it to me to find out.
Old 01-17-2013, 01:14 AM   #9
bluebolt
Adapter
I just measured a T-18 4wd trans out of a 79 Bronco. The 205 transfer case has already been removed. The adapter is 7 1/2" long and the splined shaft sticks out about 3/4" past that. How does that compare to your measurements?
Old 01-17-2013, 01:21 AM   #10
EB79Bronco
Bronco Info: 1979 Bronco C6w/wide ratio & Twin Sticks
this thread should help you.
http://www.fullsizebronco.com/forum/...housing&page=2
Please let us know what length adapter ends up working for you. I would guess it is a T18 adapter (Not NP435)....but I sure would like to have this confirmed.
EB79Bronco is offline   Reply With Quote
Old 01-17-2013, 01:27 AM   #11
joerickson
The length seems about right for what I need. Can you measure the trapezoid pattern of the t18 to see if it matches up with what I have?
I appreciate all the help so far, so thanks a ton.
Old 01-17-2013, 01:54 AM   #12
bluebolt
According to Novak the Ford 2wd and 4wd t18 and t19's have the trapezoidal pattern, its the NP435's that have a square 2wd pattern or trapezoidal 4wd pattern. Also Novak uses the same transfer case adapter for t18/t19 to jeep transfer cases. Make sure your t19 has the output splines that matches the 205.
Old 01-17-2013, 02:45 AM   #13
joerickson
What's the difference in splines? I believe it has the 31 spline output shaft, and the 205 seemed to match up when I tried putting them together, the bolt holes just didn't line up.
Sorry if my answers are a little vague, the truck is stored about an hour from where I lived currently.
Old 01-17-2013, 03:24 AM   #14
bluebolt
Splines
Just wanted to make sure what you had was correct, you have enough problems without getting an adapter and then finding out the splines are wrong LOL. If the adapter is about 3/4" shorter than how far your output shaft protrudes you should be fine.
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
