#1 |
Loss of ALL power but only when I turn the key
I'm getting the feeling that I am on this sight a little too much, but I'm getting my Bronco slowly up and running
. Anyway the problem for this week is a loss of power. I have a semi new battery and it seems to have power. I was going to hook up some off road lights when this all started but anyway heres what happens. With nothing connected to the battery except for the ignition power wire (no lights, no amps, speakers, sterio). I get in and I turn the key forward and all the lights on my dash come on the door starts to chime(I have the door open) then when I continue to turn the key to start cranking the engine, it all just cuts out. The lights on the dash go out the dome light goes out everything goes out. I have replaced my starter about a year ago and when that was dead I would turn the key and hear a single click and that is all but that was the starter, but now i dont even get the click so its like even the starter gets no power. I'm not sure what is going on and need this fixed asap. Everyone on this site is great at giving me great info so I want to thank everyone in advance for all your help.
| Sponsored Links | |||
Advertisement | |||
#2 |
iTrader: (0) Bronco Info: 1987 Silver and Blue 302 EFI 6" lift, 35" BFG's, man hubs
could be the starter switch. Turn the key to the run position and short the two large nuts on the starter solanoid on the fender with a long screw driver or similar tools WITH a plastic handle.
#3 |
I scrape on both sides
![]() Join Date: Jan 2011
iTrader: (0) Bronco Info: another rig that runs on crapoline
your battery seems to or does have power? do yourself a favor and go out to harbor freight and get one of their 2.99 multimeter. does voltage, amperage, and resistance and is a great tool for any technician.
check the ACTUAL voltage of your battery, check all your fuses, report back. although in the back of my brain I'm leading towards faulty ignition switch. also, did you put any kind of circuit protection in the wiring to the lights? disconnect the lights and see if the problem is still present. |
#4 | |
iTrader: (0) Bronco Info: '87 Bronco Custom; 300cid EFI w/ 3" exhaust; 35" Goodyear Wrangler Kevlar MTRs on 15x8; 2.5" lift
Sounds like a bad connection- it's loosing it when a load is applied. Check the battery cables and all of their ends- especially the ground(s). You could also have a bad cell in that "semi new" battery.
"I'll try to be nicer if you'll stop being an idiot." Quote:
#5 |
could it be possible that the battery is just toast. I have all of my subs and amps hooked up to it and the battery is four years old now. I dont do stuff like run the subs with the engine off but still. I also have fuses mid wire on all of the lights, and everything is disconnected now and it still wont work. Someone said the ignition switch but would that cause all of the power to go out? if so how is that replaced.....or actually ill just search it.
#6 | |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
If your battery cable terminals aren't original, or if they appear dirty or damaged in any way, click this & read all the captions: |
#7 |
RAAAAAH!
iTrader: (0) Bronco Info: '90 FSB, SAS'ed, locked, geared, caged, gutted, built and filthy
Seen this happen a bunch of time. Bad battery connection or cables.
Disconnect both battery cables, inspect them, clean them, clean the terminals, look for a damaged cable. Basically, only a little bit of power is getting our of your battery. Enough to power dash lights and such but when you throw the starter into the mix, the shitty connection can't supply enough power.
302 roller, GT40 heads, E-fan, off-road cam, headers, 35x14.5 Pitbull Bias Rockers, 10" aluminum wheels, 4.56 gears, rear Detroit Locker, front Truetrac, built AOD, Kodiak auto steps, custom exhaust, full 2" DOM cage, PRP reclining suspension seats and harness, D44 SAS, 1.5" DOM/heim steering, Deaver coils, Bilstein 7100 14", F350 brakes |
#8 |
Gone..Be back at Dark :30
![]() Join Date: Feb 2008
iTrader: (0) Bronco Info: 89 XLT, '12 Ford BlueFlame Metalic Paint, Soft Top for Summer, Stock 302 and AOD Trans.
My bet is the battery. Has enough reserve to power a few dash lights but when it goes for crank it kills the battery. Dead Cell or two will kill it to not even make the Solenoid click. Get a Jump and see if it will start or turn over.
If it has Tits or Wheels, It WILL give you problems. Just Enjoy the Ride while you can.
#9 |
iTrader: (0) Bronco Info: 89 Eddie Bauer 5.0 AOD
I've also seen this with bad cables. You can test it by measuring the voltage across the two battery posts and then the positive post to an engine/frame ground - when it is acting up. It it's a bad cable you should get good voltage across the posts, but a different # from the ground to the positive post.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
