#1 |
BKO is back running.. small coolant issue
Hi all,
Last night i finally got my project done. I dropped a brand new 351w in with all new temp sensors, 195* t-stat, a new radiator and electric fan. Once i got the bko running and tweaked some timing issues i was stuck on my cooling system. My dash gauge was showing a high temp, past the NORMAL, at the last line but the coolant wasn't that hot. The fan was blowing cool air, the hoses weren't that hot and my meat thermometer that i stuck in the radiator was reading anywhere from 160-185* The dash gauge spent most of its time on the L on NORMAL. Could it be the sensor? Just looking to see if there are any other possibilities out there. Thanks! Tim |
| Sponsored Links | |||
Advertisement | |||
#2 |
Loves the vag.
![]() Join Date: Aug 2004
iTrader: (8) Bronco Info: 2006 Kia Spectra
it could be the sender for the gauge, or the gauge itself. The instrument cluster (like much of fords electronics) are VERY sensitive to the grounds. Make sure those are all clean and tight.
#3 | |
iTrader: (0) Bronco Info: 1989 Ford Bronco 5.0 (Eddie Bauer) 4x4
#5 |
![]() Join Date: Apr 2005
iTrader: (1) Bronco Info: 1986 Bronco XLT 4x4 -AOD -Warn Hubs, NEW stock 302EFI, MSD cap, rotor, 48kv coil, 9mm FMSR wires
Temp guage sending units are inexpensive enough, $10.00 max for the Brass one, recently I just put one in, how does the fan clutch look. I just replaced mine as it was the original one along with a new Stat 195* thermostat and new radiator cap which started it all, I bought a new one by Murray from O'Reillys but the quality wasn't very good, made in Israel....? and for some reason it backed off a half a turn by itself, the little prongs weren't strong enough to hold it tightly shut....so I took it back.
I was having some issues with my dash temp guage where it used to peg right at NO/RMAL ever since I've had the BKO but then it started pegging around NORM/AL which is why I wound up replacing everything so now it just pegs around NOR/MAL most of the time and no change if I run the heater, it stays about the same so I'm not sure if it's the idiot dash guage or electrical........very odd but it's not overheating at all.... Good Luck ~
#6 |
Thank you guys!
I believe the issue was indeed my grounds.. probably because i didnt have any of them grounded ![]() I did not run it yesterday. i was focused more on getting the front end re-assembled, but ill check back next week. Thanks! Tim |
#7 | ||
iTrader: (0) Bronco Info: '87 Bronco Custom; 300cid EFI w/ 3" exhaust; 35" Goodyear Wrangler Kevlar MTRs on 15x8; 2.5" lift
Usually that means that the thermostat hasn't opened...
"I'll try to be nicer if you'll stop being an idiot." Quote:
#8 |
when i run my self diagnostics for the codes the code for improper temperature is never given which tells me 180 is fine...Also its working great so maybe they are right. I dont go by what people say i just use it as a guidline.
#9 | ||
#11 |
rolling Rolling ROLLING....
![]() ![]() ![]() Join Date: Jun 2005
iTrader: (34) Bronco Info: 93 Cherokee
what do you mean the fan was "blowing" cool air? the fan should be setup to be a "puller" which means it will pull air thru the radiator not push it thru.
#13 | |
Loves the vag.
You're wasting fuel running it colder, and your performance is suffering not much but the truck isn't running at it's best. Do as you wish, it's your truck but it's wrong. |
#14 | |
#15 |
Chillin on the Gulf Coast
![]() Join Date: Apr 2009
iTrader: (4) Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
Running a T-stat below 195° will cause the EEC to add more fuel than necessary to help the engine warm up, which that thermostat will not allow. An engine running richer will have lower gas mileage and performance.
#16 |
iTrader: (8) Bronco Info: '96, 5.8, 4.56, Rancho 4", 35's, Thorleys, Warn 8274, 5100's, 160 3G, Sag, 10.25, E-fan, Projectors
It could also attribute to a bad cat problem down the line as the unburnt fuel will clog the cat or load it up and burn it at a higher temp and melt the honeycomb and at $600 and $650 a cat, for people who have two like me, that is a huge risk compared to a $15 thermostat change it. I was always told by the techs that the sensors on our trucks operate at certain temps and if you don't hit that temp it's like a chain reaction of "bad" events to compensate the difference.....
-Kevin-
PUSH THE PEDAL ON THE RIGHT JUST A LITTLE BIT HARDER DNBELOWBRONCO www.fullsizebronco.com/17883 "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind" -Dr. Seuss-
#17 |
Thanks everyone for your feedback.
Redwagon - you are right. I meant to say the fan was pulling cool air from the radiator. I was not talking about the heater/blower fan. After installing my adjustable temp controller i found out that it was junk. The built in plastic screw that should only turn 90* to adjust controller just spun and spun. So i am replacing it tomorrow morning with a 185* preset temp controller. Now for those of you that have and understand e-fan conversions, if i have the following setup and have it hooked up properly i should be good correct? 195* Thermostat 185* E-fan temp controller with 2 prong temp probe: Red Power wire -> Battery + Black Ground wire -> Radiator Support ground Green Wire -> A/C bk/w wire Yellow Wire = Ignition Wire -> Temp Probe Orange Wire with 25A fuse -> Fan + Brown Wire -> Temp Probe Negative Fan Wire -> battery or body ground Thanks in advance Tim |
#18 |
well it looks like i failed to comprehend the fan control temp. I will now be getting another adjustable temp controller so i can raise the fan switch to around 200-205* instead of the preset 185* which is lower than my thermostat. Gives me time to fab up my new upper radiator hose though
Tim |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
