#1 |
iTrader: (0) Bronco Info: 1990 bronco with the inline 6 1993 bronco with a 302
ok i will gladly admit i am a noobie at this but i was wondering if anyone ever thought or tried to take a front ttb dana 44 and create a rear ifs setup with it?
| Sponsored Links | |||
Advertisement | |||
#3 |
Salt blows goats for fun
![]() Join Date: Aug 2004
iTrader: (8) Bronco Info: 2006 Kia Spectra
Nvm.
2006 Kia Spectra 4 banger/5 speed. I enjoy Alabama Hot-Pockets. "Kids, they see the good in everything and through their eyes, they open ours." - Hank Davis Last edited by TheUnforgiven; 01-16-2013 at 03:12 PM. Reason: My link failed |
#4 | |
iTrader: (5) Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
Trent NORTH COUNTRY SPECIALTIES Picador (1979 4door Bronco) 79 Ford CrewCab 4X4(My Dually Project) 79 Ford Bronco and My Boat |
#6 | |
straight to google home page I am going out on a limb a post what you though you posted http://www.fullsizebronco.com/forum/...d.php?t=163491
#7 |
That wasn't the thread i was posting, but the picture of the ranger at hand is in the thread you linked.
http://www.therangerstation.com/foru...d.php?t=116943 http://www.explorerforum.com/forums/...d.php?t=350561 |
#8 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Why not use the independent 8.8 center and make you own a-arms. Seams like it would be a better way to go and would leave the driveshaft centered and tucked up high. Doing a arms would greatly reduce camber change during suspension cycling. The a arms could be made with some dom and hiems. Im thinking out loud but you could use a leaf spring flipped upside down and turned 90 degrees from its current position as a way to put it on springs.
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#9 |
iTrader: (1) Bronco Info: 1996 Black 302 XLT - 1994 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
@JBFab - I had a '77 Corvette, and what you're describing is the rear suspension of that vette, right down to the single traverse leaf spring.
"The simplest solution is usually the best solution" - Occam's Razor "The significant problems we face cannot be solved at the same level of thinking we were at when we created them." - Albert Einstein |
#10 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
All IRS Vettes (except maybe the current body) use that setup.
Using a front axle in the back is just as bad as a rear axle up front - the gears aren't designed for that kind of load on their coast faces, and the oiling pattern doesn't work in reverse; especially not upside-down. Axles aren't designed to work in space; they need gravity to be where it was expected to be during the design. And they need the ring gear to spin the direction it was expected to spin for any significant loads to be handled. |
#11 |
Age. Fac ut gaudeam
iTrader: (2) Bronco Info: 1989 Bronco Custom 4.9/M5OD EFI
I had a pic saved of this...
1991 Ford Bronco XLT 5.0/E4OD EFI 1996 Ford Bronco Eddie Bauer 5.8/E4OD EFI 1990 Pontiac Formula Firebird 5.7/T5 TPI 1991 Ford F150 Custom 4.9/M5OD EFI 1993 Ford Mustang Convertible 2.3/AOD EFI |
#12 |
Nothing beets a Fullsize
iTrader: (10) Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
would be kind of a waist but might make a good prerunning setup if done right. would have to regear it with normal gears instead of reverse cut. would have to find a way to get the diff center or the u-joints might have alot of angle. the actual strength wouldnt be there compared to an 8.8. the only reason to do this is 4 wheel steering. even then id say a Dana 60 would be a better choice. i blew up my 96 dana 44 diff from driving around front wheel drive for about 3 weeks, imagine doing that all the time?
#13 |
Man with a Golden ticket
![]() Join Date: Jul 2007
iTrader: (0) Bronco Info: 96 blackout XLT Sport 5.8L E4OD, 4" Rancho w/ 35" MTR's
Just a thought here,
Would it not be easier to use an IRS 8.8 out of a Thunderbird or Mustang for this I'm thinking it would require less fab work, the Diff housing should be able to sit higher giving more clearance, it is designed for the rear and all of the parts are all factory parts. ????
You just might be a redneck if you start a conversation with: ![]() "happened to us when Dad got pinched by the feds." - Biker Pepe' - |
#14 |
Unforgiven's Pet
![]() Join Date: Dec 2007
iTrader: (4) Bronco Info: '90 xlt 351w E40D Truetrac I GOT ROLLER ROCKERS !
Or ..or...or or just use the motor,trand and diff setup out of a Pantera in the back of the Ranger or Bronco everything would go in back, see ?
#15 |
![]() Join Date: Jan 2010
iTrader: (1) Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
This question comes up every other year doesn't it? ........
I think in a truck a ttb might be better than a ifs from a mustang or vette. As the ttb would have more flex I would think.
"hold my beer and watch this" ![]() Hydroboost walkthrought My Build Thread!! II My Build Thread!! - retired |
#16 |
I looked into it earlier, the exploders and expeditions went to independent 8.8's. i googled explorer irs 8.8 and some people are building some nice setups using them. The cobra setup would be nice for handling but would lack alot for anything off road.
#18 |
Age. Fac ut gaudeam
You ever notice how Cobra owners swap out for a live rear?
#20 | |
I will have to look into this since I want to do an explorer rear disc brake upgrade anyway and the idea of an IRS is interesting. Just don't get all the naysayers about the TTB's? I've owned several vehicles with TTB and I have never had any problems with any of them. It seems sometimes there is a forum wide mindset that SAS good, TTB bad group think going on without thinking that not everyone plans to use their Bronco for rock crawling or other type of off-road driving where the extreme flex is needed. Honestly IMO that is the only area where the SAS is superior. For snow, sand, desert or general off roading I think the TTB is better. Not everyone wants their Bronco to just be a play toy. Personally I want mine to be good at all off-road situations as it is my go anywhere anytime I need to get somewhere regardless of the situation or driving conditions. So for the O.P. who is interested in a rear TTB, if it fits for what you are trying to build than go for it. Just don't get mind locked onto a rear TTB if another replacement will work better, be stronger and/or be more cost effective and easier to build.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
