#1 |
![]() Join Date: Jul 2009
iTrader: (1) Bronco Info: 90' 351/E40D 38" tires, 4.88 gears, full float 8.8, lockers F&R
Pinion nut
I took a look under my truck before a long trip. While checking the driveshaft for loose u-joints, I noticed the pinion nut had backed off a little.
The right way to deal with this is to replace the nut and crush sleeve. But you have to remove the carrier to torque the nut correctly. I wasn't really in for a two+ hour job, so I just tightened it. Not much tech here but I highly recumend making one of these. It's just 1/2" by 2 1/2" flat bar with a couple holes. It was allot better and I made my trip with no problem. I will fix it right later. Now for the question. Does anyone know if the crush sleeve work hardens? Although I got it tighter, it never got all the play out of the pinion. I was really reefing on it with a long cheater. Seemed like it just stopped. |
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Dec 2004
iTrader: (15) Bronco Info: 1995 sport,6''DC Stage II 37's streetlocks 4.56's ARB,BroncoAir rear bumper Hefty Fab front bumper
I have replace a lot of pinion seals and never had a problem, no reason to change the crush sleeve unless there is another problem. The pinion is supposed to have some play in it, that's the backlash between the pinion and ring gear.
Sent from my iPhone using AutoGuide.com App
![]() ![]() MALL CRAWLER EXTRAORDINAIRE Silent One's Supermotors Page January 2010 FOTM Winner |
#3 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
It doesn't. Work-hardening occurs within the elastic limit of certain materials. During work hardening, the unstressed shape doesn't change because the material springs back to its original shape when the stress is removed. Crushing goes beyond the elastic limit (by definition) into the plastic range. Plastic deformation destroys work hardening.How much torque? A new sleeve begins to crush somewhere above 200 lb-ft. An old one may crush slightly lower.
BTW If your gears have worn enough to have some significant backlash, the pinion preload can be set with the carrier installed by only measuring the rotating torque within the backlash zone (no contact with the carrier/ring gear). OR, if the carrier & wheel bearings are well-worn, the effects of their drag will be minimal (by a factor of the gear ratio, plus a little for the gear teeth friction) on the pinion rotating torque. |
#4 | |||
#6 | |
What I'm saying is torque cumulitive? |
#7 |
Nothing beets a Fullsize
iTrader: (10) Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
if the pinion moves front and back then the bearing is bad. you really need to replace it and do the job right. doing it halfassed will jsut make it not reliable. my friend replaced his halfass and it blew up in less than a month
#8 |
AKA: Butthead
iTrader: (0) Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
http://www.youtube.com/watch?v=7MWsPJBCrww
---------------------------- Steve, where'd you get the crazy ideas plastic deformation -doesn't- work harden steel and plastic deformation even removes(!) work hardening? Alvin in AZ |
#11 | |
AKA: Butthead
The crush sleeve or solid spacer is the -minimum- size -before- any bearing wear. ;) Tightening it down ain't gonna hurt anything as long as you don't get carried away, IM(limited)E. King's friend's experience could be the opposite of mine or the same. ;) His was just too shot to go much farther -any which away-? ;) But x2 King's warning and advice to do it right tho, at least you can save the housing and rebuild it better than new, ...if that's your thing? Alvin in AZ ps HellaRich, can't find my notes or wiring diagrams since the move -in- and so I don't know the wire colors for the defrost-power to window-power swap. Heck, I can't even find the thread it was in! :/ No kidding. LOL :) pps- Having heard ol'guys talk about rebuilding rear axles and setting up the gears since I was a kid... I fiNgure that torque readings on the carrier and pinion preloads are mostly for -books-. YMMV on that. |
#12 |
Generally, yes. But with hypoid gears, it's not that simple. That's why no axle mfr. specifies preload torque with the carrier installed. The actual torque to turn the pinion becomes dependent on too many variables, including (but not limited to) gear mesh settings, oil viscosity, oil film thickness on the teeth actually in mesh (which changes with position & speed of rotation), oil temperature, carrier bearing preload/oil film... Will it get you closer than you are now? Probably. Will it be right? Probably not.Mechanical Engineering 203 & 204, IIRC (Mechanics of Materials & Lab). BTW I wasn't referring to "creep", which is technically plastic deformation. But creep occurs in the elastic zone.
#13 | ||
AKA: Butthead
No carrier causing drag here... http://www.youtube.com/watch?v=x5_0FYWgWI8 ...and not much weight to keep it spinning either. :) This one's ~3 minutes long... http://www.youtube.com/watch?v=8APYO...ture=fvwp&NR=1 Quote:
Got my information from Metallurgy class, ASM's Metals Handbook and silversmiths. ;) Alvin in AZ |
#14 | ||||||
Anyone following the pinion nut can disreguard the following. Quote:
What does YMMV stand for? Quote:
#15 |
Chillin on the Gulf Coast
![]() Join Date: Apr 2009
iTrader: (3) Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
YMMV= Your Mileage May Vary. I am watching this pretty close. I have a loose pinion myself and changed the crush sleeve but couldnt get it to crush. My springs just kept flexing. I will try putting something to stop the pinion from rotating up and try again when I get back. I found out this week that my bronco that I have not gotten running needs to drive cross country in March.
#16 | |
Thanks for the translation |
#17 |
I have a large piece of flat steel that is drilled to fit the yoke and is bolted up and supported by the jack stand. It is not rotating the normal direction a pinion rotates, it is wrapping the leaf springs and rotating the entire housing. It is rotating on the same axis as the tires, not the driveshaft.
#18 | |
Those variables aren't directly-proportional to the preload or to the rotating torque.
#19 |
I think he is doing that except he's got the bar horizontal on a jack stand. I would recomend letting the bar on the floor. (Like in my pic) then it will have less leverage to rotate.
#20 | |
The only thing I'm unsure of is if it takes 10 in/lbs to rotate the axle and 15 to rotate the preload, can I assume it will take 25 to rotate the two assembled. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
