| View Poll Results: Which radius arm bracket to use? | |||
| Reuse the old ones (clean & paint) |
3 | 23.08% |
| Ford OEM (pay the Ford man for quality parts!) |
7 | 53.85% |
| Moog |
0 | 0% |
| Raybestos |
0 | 0% |
| Bronco Graveyard |
0 | 0% |
| Other (post what & where to get them) |
0 | 0% |
| Dude, they're BRACKETS... you are overthinking this! |
3 | 23.08% |
| Voters: 13. You may not vote on this poll | |||
#1 |
I'm going to replace my radius arm bushings soon and I'm contemplating replacing the brackets since I'll be taking them off anyway. I'm not sure if the radius arm holes in the bracket are ok or not (there's some bushing left), but the bracket is rusted enough that the factory coating is flaking off. The ones from Ford are pretty expensive, are the aftermarket ones equivalent or thinner/weaker?
Oh yeah, I have ProComp extended radius arms so the brackets have already been moved using bolts instead of rivets. Thanks.
1995 5.8L XLT w/tow pkg, 4" ProComp Stg II lift, 33X12.5X15 Duratrac, 3.55LS rear/open front JBA Headers, Bassani Y-pipe, high-flow cat, Spintech 3000XLP |
| Sponsored Links | |||
Advertisement | |||
#2 |
Nothing beets a Fullsize
iTrader: (10) Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
there all gonig to be bout the same strength. i cant say i ever heard of someone breaking them from wheeling. only that they rusted out. also if the bushing is completly worn out and the arm is rubbnig the lip of the hole, it will wear them out and you do need to replace them. jsut get a cheap set of them that are still in good condition.
#3 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
Rust doesn't cause the factory coating to flake; the flaky coating traps water & salt, causing rust. There's no point even guessing until you know what yours look like, and you can do that quickly by simply removing the big nut, rear washer, & rear bushing. That's all it takes to inspect the bracket for wear, then you can put it all back until you're ready to fix it. If it's OK, reuse it. If it's trash, buy a replacement - there is no "strongest"; they're all the same (EXCEPT lifted ones which are effectively weaker). If you don't know, take some GOOD pics, and I'm sure plenty of opinions will be offered!
#4 |
What do you mean "lifted ones"?
#6 |
I had some time after working on the exhaust last weekend and spent some time on the radius arm bushings. I was surprised to find that the inside of the bushings looked pretty good. (the outsides were crumbling) I'm thinking that the brackets look ok, I just need to clean them up and POR-15 them.
Here's some pics: Pass side 1 ![]() Pass side 2 ![]() Driver side 1 ![]() Driver side 2 ![]() I did go ahead and replace the rear half of the bushing since it was taken apart anyway. I'll get the front half when I have time to remove the bracket.
#7 |
whats welded to the bottom? i wish i still had the brackets form my friends lift kit. they were in great condition and i woulda gave them to ya free.
#8 |
That's the side post lift I was using. The truck is about 5ft off the ground in these pics. I HATE lifting it by the brackets, but with the way these particular lift arms were designed and the extended radius arms in the way, it was my only option.
#9 | |
AKA: Butthead
iTrader: (0) Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
longass drop radius arm bracket. xD ...9/16" fine thread grade-8 bolts with pinched top nuts and ->NO<- washers from McMaster-Carr. |-p Alvin in AZ |
#10 |
There's nothing wrong with lifting by the RA brackets, and the stock RAs are the alternate lift points. IDK if those aftermarket ones can handle it, though...
#11 |
thats not mine, i found that pic on google. i have extended radius arms with stock brackets. 1 bracket is 1/2" bolts and the other is 7/16" all grade 8 fine thread of course. 9/16" is way overkill IMO
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
