steering stiff spots - FSB Forums
Thread Tools Display Modes
Old 01-20-2013, 08:38 PM   #1
Coors
Coors's Avatar
Bronco Info: 78 Bronco, HP60, 14 Bolt, 4.88's, Detroits
So it seems everytime i fix one thing something else goes wrong, I noticed a couple of weeks ago that the steering in my 78 felt a little funny, like it has some sticky spots in it. Granted I have 38's, but it never used to feel like this, sometimes better then others, I do have an after market ps pump with high output, been on for about a year now.
Guessing maybe the box, fluid is new in it, actually running about half good fluid in in, royal purple, need to drain and completely refill with it all together. just has a funny uneven feel to it when turning, before it would turn the 38's sitting still on pavement at an idle with one finger on the wheel no problems,still turns them with ease but has a little hesitation and stiffness, but not all the time, it is hit and miss,
my guess would be the gear box possibly,anyone else ran across this and fixed a similar issue?
Coors is offline   Reply With Quote
Old 01-21-2013, 12:16 AM   #2
bronco ox
Bronco Info: 1978 Bronco,400m,c6,d44,custom d60 rear,np205,410's,ox locker front&rear,33" bfg's,hd bumpers
Check the track bar bushings and make sure the bolts on each end are tight. I had a similar issue after putting new bushings in and still having the same problem. Then realized the cotter pin in the castle nut had come out and the bolt had backed off letting a little play and the axle assembly to move and bind the steering.
bronco ox is offline   Reply With Quote
Old 01-21-2013, 12:30 AM   #3
raleigh
raleigh's Avatar
Bronco Info: 1 1978 and 2 1979 Broncos mishmashed together into one
My 250 was doing the dame thing when I got it, the PO put power steering fluid rather than ATF.
Drained and refilled 3 times to get all the PS fluid it out, solved my problem.
Of course you have a saginaw pump, I am not sure on what fluid it runs...
Dave
FOTM is BACK!
FB Build page
"...when a long train of abuses and usurpations, pursuing invariably the same Object evinces a design to reduce them under absolute Despotism, it is their right, it is their duty, to throw off such Government, and to provide new Guards for their future security."
raleigh is offline   Reply With Quote
Old 01-21-2013, 10:08 AM   #4
Coors
Coors's Avatar
No bushing in my track bar, running bullet.proof steering. But I will check go see if everything is tight
Old 01-21-2013, 10:10 AM   #5
Coors
Coors's Avatar
I was running atf but was having problems with the pump making noise when getting warm so the manufacture said run something like royal purple, been running about half and half for a while now, been doing good, this issue just started. I need to drain and refill with just one fluid, haven't had the time yet
Old 01-21-2013, 11:13 AM   #6
TheUnforgiven
InsanePyro licks my
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture
check the rag joint on the steering shaft.
2005 Chevy Venture, not a bronco. Deal with it.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 01-21-2013, 12:30 PM   #7
Coors
Coors's Avatar
I kind of peaked at that last night and it looked good, I may try flushing the fluid real good and see what happens, it does have a couple different types of fluid in it, mybe that is causing me some issues
Old 01-21-2013, 01:10 PM   #8
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
This right here.
well look by it,I had a problem last yr after putting my deavers up front. somehow the coil tower was pushing in after i flexed it. and the rag joint was hitting the coil tower in one spot. drove me nuts for a week till I got someone in the bronco to turn the wheel while I looked at the steering and saw the joint hitting.
I highly doubt it is the fluid.
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 01-21-2013, 01:54 PM   #9
Coors
Coors's Avatar
Thumbs up
I will check that out when I get home, thanks
Old 01-21-2013, 02:17 PM   #10
Coors
Coors's Avatar
Originally Posted by LarryP View Post
This right here.
This just might be it, I have a plate behind my steering box on the frame do to it being cracked, so that would put my rag joint closer then stock, will look when I get home
Old 01-21-2013, 08:54 PM   #11
Coors
Coors's Avatar
Well I came home and got just a few minutes to look it over, rag joint isn't touching, not even close, so I fired it up and spun the wheel around a little bit, starting to think it may be the u joint, as u spin it around, it feels to have 2 tight spots as it rotates
Old 01-22-2013, 12:13 AM   #12
raleigh
raleigh's Avatar
Good thought, I didn't think to ask if it has tilt
Dave
FOTM is BACK!
FB Build page
Old 01-22-2013, 12:35 AM   #13
Coors
Coors's Avatar
Thumbs up
It doesn't have tilt, but still has the u joint on the engine side of fire wall that does work at a slight angle, enough that if it was starting to seize up I would feel it when rotating, maybe if I get time tommorow after work I will take a further look into it
Old 01-22-2013, 10:08 AM   #14
OX1
OX1's Avatar
My 79 street rig had that exact problem recently. Only 2 "caps" on the U-joint in the upper end of steerin shaft were binding up (pretty good too). Made steering alternately hard then normal going from lock to lock.
79 XLT, 400/C6/mog 404's/42 IROKS, 8.5" lift.
79 XLT, 400/C6/D60-D44 8 lug, 2" lift, 35 BFG AT
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies
OX1 is offline   Reply With Quote
Old 01-22-2013, 10:55 PM   #15
Coors
Coors's Avatar
Well the u joint appears to be my problem, took it apart tonight and it is almost totally froze up in 2 of the joints.
Old 01-25-2013, 09:47 PM   #16
Coors
Coors's Avatar
So I pulled the shaft out, took it to work with me for the day a nd soaked it for a couple hours in some penetrating oil and then worked it back and forth till it gradually freed up. Got it to where it moved freely and smoothly, put it back in and the steering works like a champ.
Old 01-26-2013, 05:41 AM   #17
LarryP
Thanks 351w500
LarryP's Avatar
Awesome
Old 01-26-2013, 12:11 PM   #18
OX1
OX1's Avatar
Good deal. Pretty odd though that over and over on many rigs, only one set of those joints seizes up bad..................
Old 01-29-2013, 09:37 PM   #19
Coors
Coors's Avatar
No kidding, well at least mine is back to normal for now. I like my one finger steering. After doing the Saginaw upgrade and putting the performance pump in, my steering is a breeze, even with 38x14.50, I can turn the tires with ease even on pavement. Can a superduty owner say that!!
Old 01-30-2013, 08:52 AM   #20
InfoFord
InfoFord's Avatar
Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
this is a common issue I have seen if more times then I care to count
loose hard loose hard steering is the tell tale sign
Trent
NORTH COUNTRY SPECIALTIES
Picador (1979 4door Bronco)
79 Ford CrewCab 4X4(My Dually Project)
79 Ford Bronco and My Boat
InfoFord is offline   Reply With Quote
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
