#1 |
WHEELS UP
![]() Join Date: Dec 2011
iTrader: (0) Bronco Info: 1995 xlt,302,3in lift,33in mud claws,custom exhaust and intake.MSD ignition system,automatic
Rattling sound?????
Ok guys and gals,ever since i went up tray mtn. i have had this rattle or knock sound (only when hitting a decent bump) coming from the passenger side.Sounded like a shock was broke or the door wasnt shut all the way.Shocks are good,checked everything under the truck and re tightned all the bolts i could find,tightned all door bolts on the hinge and inside the door,i had one of my techs ride with me so we could locate it and he thinks its the door,but we double checked everything on and around the door nothing loose,even jerked on the door with it open no sound,just with door closed and hitting bump,anyone got an idea,please help driving me nuts,as you know by now im pretty OC about my truck and this is getting to me.
THE BLACK PEARL
| Sponsored Links | |||
Advertisement | |||
#2 |
Beach bumming it....
![]() ![]() Join Date: May 2011
iTrader: (3) Bronco Info: 88 XLT 351W C6 With way too much to list here done to it.
All the screws on the panel still there? Have you taken the panel off to see if anything is loose or broken?
Josh 88 XLT with rebuilt 351W and C6. 7" lift on 35" 12.50 mickey thompson baja claw mtz's, SUMMIT headers, direct fit MagnaFlow High Flow cat, No mufflers, Saginaw, TRE flip, 3g 160 amp alt, HIDs, sliders, and custom bumpers with KCs. FSB Official Health and Fitness Thread My Build - El Surfista |
#3 |
WHEELS UP
yeah took panel off saturday and tightned evrything in the door,to no avail.
THE BLACK PEARL
#5 |
WHEELS UP
yep door stryker still there and intact and tight,i cant seem to find anything loose or missing.
THE BLACK PEARL
#6 |
![]() Join Date: Dec 2007
iTrader: (41) Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
I had a rattle once like what your describing. It ended up being the nut for the coil spring hold down wasn't tight enough and the big washer was rattling.
~ Scott ~ ~My Exhaust clip on YouTube ~ 204k on the odometer and no longer a daily driver. ~ ~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
#7 |
The Anti Yam!
![]() ![]() Join Date: Oct 2003
iTrader: (4) Bronco Info: 86 Bronco XLT 357w/AOD
92-96 Broncos and F-Series are notorious for there dashes coming loose on the pass side near the door.
http://www.thedieselstop.com/faq/949...les/941513.pdf
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT My SuperMotors Site - My Engine ![]() The Greatest Thread on FSB |
#8 |
The Anti Yam!
A thread about it and the obsolete kit to fix it.
http://fullsizebronco.com/forum/showthread.php?t=85371
#9 | |
WHEELS UP
THE BLACK PEARL
#10 |
AKA: Butthead
iTrader: (0) Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
I'm not a fan of Ford stealerships and prob'ly isn't limited to just Ford since
all of 'em are run by -people-. LOL :) The one I bought my '75 F150 from would remove the anti-rattle clip from the driver's side disc brake pad. I shit you not. It'd take me a week to type out all the crap that particular dealership pulled on me and others. ----------------------------- I've got a -rattle- under my Bronco too I can't figure out. ...It's different from the -clunk- that I think is just "C clip play" from the 8.8" axle when the Bronco tilts. (?) Alvin in AZ |
#11 |
![]() Join Date: Dec 2009
iTrader: (2) Bronco Info: 95 XLT 302 E40D 5.5 devers 3"body lift 35" MTR's Warn locking hubs custom rock sliders.
sounds like the dash, has broke the lower mount point. its a very common thing. i need to figure out how to repair mine.
remember its your ride build it your way not there way. but build it dont buy it
#12 |
WHEELS UP
looks like i have to remove dash,is that correct?
THE BLACK PEARL
#13 |
WHEELS UP
Ok just to update this in case anyone else ever has this issue,it ended up being the lower hing pin bushing (that i had already replaced).The bushing split due to the rough terrain and was giving enough room for the pin to move when i hit a big hole or bump.The fix,re pin the door and realign the door with factory bushings and pins instead of aftermarket ones.
THE BLACK PEARL
#14 |
The Anti Yam!
Well, there ya go.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
