#1 |
iTrader: (0) Bronco Info: (96 Bronco Xlt,93 frame,94 axles,96 body) (66 bronco uncut halfcab slow project)
Exhaust manifold replacement 96 bronco
Ok so the studs snapped clean off on my passenger side exhaust manifold and to save time I just bought new manifold and while doing this I snapped the last two exhaust manifold that go into black on passenger side so. The two back screws for last cylinger on passenger side broke off and are stuck in head..I'm sure this is happened to other but I can't seem to fina any threads....are there any trick other then haveing to drill out whole bolt and re tapping ? Or just uese an easy out drill center out then ? The second to last bolt was already snapped off before I even touch the manifold I broke last bolt all other ones came out fine..
Lifes journey is not to arrive at the grave safely and in a well preserved body, but rather to skid in sideways, shouting ''Holy sh*t, what a ride!'' BUILT NOT BOUGHT CHECK MY BUILD THREAD OUT AT http://www.fullsizebronco.com/forum/...d.php?t=208774 |
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Dec 2007
iTrader: (41) Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
The last time I broke the studs, I had a machine shop drill them out and heli-coil them. Of course the heads were removed to do so....
~ Scott ~ ~My Exhaust clip on YouTube ~ 204k on the odometer and no longer a daily driver. ~ ~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
#3 |
WHEELS UP
![]() Join Date: Dec 2011
iTrader: (0) Bronco Info: 1995 xlt,302,3in lift,33in mud claws,custom exhaust and intake.MSD ignition system,automatic
i would try the easy out first,if that doesnt work then drilling and retapping is the only other option.
THE BLACK PEARL
#4 |
Thanks guys
#5 |
iTrader: (0) Bronco Info: 87 EB w/302,C6,1356, 36 TSL's and I need a spare, PM me if you local and have a spare tire for sale
If you drill it out yourself. Start with a small bit and once you punch through. Step up a size or two on the drill bit and make the hole bigger before you try an EZ-out.
http://www.sears.com/tools-hand-tool...e=CAT_REC_PRED If you try the bigger drill bit, it will probably walk around on you. that's why I said start with a smaller bit and work your way up. Then once the stud is drilled and it has very little structral strength, THEN use the EZ out. If the ez out breaks, just give up and take it to a machine shop. I have done this several times and didn't need no stinkin heli-coil and I didnt even clean the threads up. Just dont break the EZ out. Good luck p.s. I hate having to use EZ outs. p.s.s I like this type better than the I posted up there^^^ http://www.sears.com/craftsman-5-pc-...4&blockType=G4 Also, try removing your inner fenders. It will make this so much easier |
#6 | |
Thanks man I've had a lotta trouble in past with ex outs so I guess ill try these out..worse case sceanario..its a reall good reason to buy a new set of heads haha
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
