#1 |
iTrader: (0) Bronco Info: 1993 custom 302, flowmaster super 10, interco tsl's 33x12.5x15, rancho rs5000's, summit shortys
lift the ttb or d60 leaf swap
hey yall, im trying to decide which direction i wanna go with my truck. the plan is to run 38x13x15 tsl's. i cant decide which is more effective to do this. i already have a 3in bodylift. im looking at either a pro comp stage 2 6in susp lift or taking the diffs of a donor f350 and swaping them in. i know the ttb doesnt flex all that well but i run mostly in mud so alot of flex isnt a big issue. any ideas?
| Sponsored Links | |||
Advertisement | |||
#5 |
iTrader: (8) Bronco Info: '96, 5.8, 4.56, Rancho 4", 35's, Thorleys, Warn 8274, 5100's, 160 3G, Sag, 10.25, E-fan, Projectors
TTB + 38's = broken axles.
Leaf sprung D60 + 38's = fun in the sun! Plus, since they offered leaf D60's in '93-'96 F350's it will look totally stock, swap in relatively easily, and other than the 8-lug...be a sleeper...well the 38's might give it away too ![]() -Kevin-I still go back-n-forth deciding on leaf or coil but either way I'm going this route (Kingpin D60, 4.88's, 37's, manual 1356 clocked higher, lockers, belly-pan) then I will be far enough in this build to feel confident about going anywhere......
PUSH THE PEDAL ON THE RIGHT JUST A LITTLE BIT HARDER DNBELOWBRONCO www.supermotors.net/17883 "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind" -Dr. Seuss-
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
