broken trasfer case - FSB Forums
Thread Tools Display Modes
Old 01-24-2013, 02:02 PM   #1
dirtycountrygirl
Post broken trasfer case
ok so my transfer case broke something internally the other day it wouldn't go in 2wd or 4H but I got it in 4L and got it home so here is my question I called about a 91 transfer case (mines a 92) that sounded just like mine man/ shifter, bolts to the rear driveline sounded great but when I called he told me that his computer said that it would not work that I need a 92-95 but he explained the same t-case what is different if anything . will it work?
dirtycountrygirl is offline   Reply With Quote
Old 01-24-2013, 02:26 PM   #2
jermil01
Charlie doesn't surf!!
jermil01's Avatar
Bronco Info: 1992 xlt, 351EFI, .040, E4OD, D44 SAS w/Trutrac,Detroit locked 8.8, MAF conv, Tweecer tuned
the older case will work in your rig. need to make sure the case was from a Bronco and just transfer your linkage over to the new case. pretty straightforward really.
Vote 4 Top 4x4 Site!!!
jermil01 is offline   Reply With Quote
Old 01-24-2013, 03:31 PM   #3
sackman9975
"living life"
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
It will work, however I believe there should be a port for the Speedo/vss on the 91. The 92 won't have one. So just ask for the Speedo/vss plug in when getting it to plug the hole.
~ Scott ~ My Tech write ups:
How to properly set the timing on a 302 or 351
Harmonic Balancer Crankshaft bolt removal
How to press rotors without taking them to a machine shop
~E303 w/Flowmaster 40 & 3inch exhaust rumble ~ 220k & counting. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 23 years ~
sackman9975 is online now   Reply With Quote
Old 01-24-2013, 04:00 PM   #4
jermil01
jermil01's Avatar
forgot about that..sackman is right. you can just swap the tailshaft housing off of your current transfercase to the new one and call it a day..
Old 01-24-2013, 04:44 PM   #5
SomeDude451
Bronco Info: 1989 F350 XLT Lariat, 4x4, 7.5L SD, E4OD
Wasn't the speedo still cable driven until 93 or 94? And then it went all electric?
-Travis
My Supermotor(What's left of it.)
SomeDude451 is offline   Reply With Quote
Old 01-24-2013, 06:47 PM   #6
Kingfish999
Nothing beets a Fullsize
Kingfish999's Avatar
Bronco Info: 96 Bronco (5.8 DD E4OD), 88 Bronco Mudder (Engineless), 90 F250 (Explorer 5.0 4R70W)
first things first, lets make sure you are shifting it right
if you are in 4low, you have to put the transmission into nuetral. park wont let you shift in/out of 4low. also the transfer case requires a special action of either pushing the shifter down to the ground or to the side
-----96 5.0 E4OD--------------88 5.8 C6--------------96 5.8 E4OD------
---------KIA-------------------Mud/Trail---------------Daily Driver------
Kingfish999 is online now   Reply With Quote
Old 01-27-2013, 05:22 PM   #7
dirtycountrygirl
I shifted it right I could get in 2wd and 4h but it would grind but in 4L it would drive now my next question is what is different on the inside of the transfer cases that have a shifter and the button activated one can I get a button transfer case and use the parts to rebuild my transfer case I cant find one that's has a shifter there all button active
92,351w,33in m/t, first bronco
Old 01-27-2013, 09:20 PM   #8
bluebolt
Bronco Info: 1974 Bronco with 351w, 1978 F150 4x4 with 1966 F100 cab
Transfer case
I take it you mean yours is a manual shift transfer case and all you can find is the electric shift ones with the switch on the dash. The cases aI believe are quite a bit different and you can not easily convert an electic into a manual.
Where are you located? I might be able to help find one if I knew what area of the country to look in.
bluebolt is offline   Reply With Quote
Old 01-28-2013, 09:01 PM   #9
dirtycountrygirl
im near Portland OR. the only two I can find they want 200-250$ and they have around 160,000 miles on them , at that price I would rather just buy a rebuild kit but if I can find one with less miles and not so much I would just swap them out and then rebuild mine when I have time. I hate having her sit in the driveway knowing that I cant just get in her and take off.
Old 01-28-2013, 09:34 PM   #10
JBfab
JBfab's Avatar
Bronco Info: 94 C150 prerunner 351/zf/maf. To many mods to list.
You could swap in an electric till you rebuild your manual! You wont have 4x but it will still drive till you get yours rebuilt.
It's not custom if you bought it from a catalog!
Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825
JBfab is offline   Reply With Quote
Old 01-28-2013, 10:28 PM   #11
bluebolt
Transfer case
I used www.car-part.com and found one in Portland for $150, manual shift, flange rear output, 98,000 miles. Stock # DD451 at Light Truck Parts 1-800-452-8004
Old 01-28-2013, 11:30 PM   #12
dirtycountrygirl
just had a guy from a auto parts store tell me about car-parts.com and I found several transfer cases the lowest prices are 150$ now im waiting to find out how much a rebuild kit is to see which direction im going to go . ill let you all know tomorrow thanks to everyone for the info
Old 01-28-2013, 11:31 PM   #13
dirtycountrygirl
Smile
I didnt see your post until I posted that last one thank you bluebolt
Old 01-29-2013, 01:37 AM   #14
bluebolt
Thanks
No problem I get it right once in a while LOL.
Old 01-29-2013, 11:07 AM   #15
helirich
helirich's Avatar
I'm not sure if there is a "rebuild kit" for them. If they do have one, it probably has lots of stuff you don't need. Just take it apart and see what it needs. Probably a couple shift forks and you'll be fine. (Unless it ate the pump)
helirich is offline   Reply With Quote
Old 02-01-2013, 02:47 PM   #16
dirtycountrygirl
t-case linkage
so I got the new t-case but im having one hell of a time getting the linkage off the old on under my rig. is there a trick im trying to use a screw driver to get it to pop off but no luck any suggestions
Old 02-01-2013, 02:50 PM   #17
TheUnforgiven
Huh Huh vanzercool
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture, 1997 Acura TL
Get REAL pry bar that's larger. PB Blaster is your friend, or a torch if you have one.
2005 Chevy Venture. 1997 Acura TL. $500 beater.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 02-01-2013, 02:58 PM   #18
cajunrebel
Chillin on the Gulf Coast
cajunrebel's Avatar
Bronco Info: Blue 89' EB 5.0, E4OD, OBDII, Mass Air, Saginaw, Hydroboost, 3G alt
Torch the grommet and and pick up a replacement at autozone (might want to get the replacement in hand first though). They have them in the help section from Dorman. Part number 14041 on Rock auto I believe.
cajunrebel is offline   Reply With Quote
Old 02-01-2013, 03:06 PM   #19
dirtycountrygirl
ok so a lighter and a little prybar is all it takes
Old 02-01-2013, 03:07 PM   #20
dirtycountrygirl
I love pb blaster I have swern by that stuff for years wd 40 has nothing on it. I love this forum
You may not post replies
Forum Jump
