Topper Bolts...Tightening Sequence? - FSB Forums
Thread Tools Display Modes
Old 01-24-2013, 08:58 PM   #1
JScatt
JScatt's Avatar
Bronco Info: 1995 XLT 351W, 2.5 R/C Lift,4.10's..much more to come
Is there a tightening sequence for the fiberglass top bolts? Or just tighten side to side starting with the long bolts along the top?
I removed my top last weekend for paint and replaced the seals while it was off.
It rained today and it is leaking from the top left corner, it leaked before but not there.
I also noticed that the gap between the A pillar and the top is slightly wider on the leaky side. Perhaps it is cocked?
I'm gunna loosen it up this weekend and re- tighten the bolts just wondering if there is a sequence.
No bum that can't speak poifect English oughta stay in this country...oughta be de-exported the hell outta here!"
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
A wild or half-tamed horse, esp. of the western US.
JScatt is offline   Reply With Quote
Old 01-24-2013, 09:08 PM   #2
war1ock
war1ock's Avatar
Bronco Info: 1980 300 I6 4spd/1981 302 C6
Ive never tightened them in a certain sequence except I start with the front bolts then just do one side then the other side. Never had a leak knock on wood lol
Sent from my C771 using AutoGuide.Com Free App
My Build
war1ock is offline   Reply With Quote
Old 01-24-2013, 09:19 PM   #3
379sinvb
Resurection Ranch
379sinvb's Avatar
Bronco Info: War Horse,Blue Eyes,Black Stallion & Youngblood the newest member.
I get mine all started and then tighten down the front but not to tight. Then I'll pick a side and switch back & forth front to back until all are semi tight. Then I'll go back over them all with one more turn.
Rick
My Project- "Left for Dead"
379sinvb is offline   Reply With Quote
Old 01-24-2013, 09:23 PM   #4
Andrew James
Age. Fac ut gaudeam
Andrew James's Avatar
Bronco Info: 1989 Bronco Custom 4.9/M5OD EFI
I run three or so bolts and no leak... Just loosen up and make sure its sitting right then tighten down.
1991 Ford Bronco XLT 5.0/E4OD EFI
1996 Ford Bronco Eddie Bauer 5.8/E4OD EFI
1990 Pontiac Formula Firebird 5.7/T5 TPI
1991 Ford F150 Custom 4.9/M5OD EFI
1993 Ford Mustang Convertible 2.3/AOD EFI
Andrew James is offline   Reply With Quote
Old 01-24-2013, 09:26 PM   #5
Shane C.
Shane C.'s Avatar
Bronco Info: 78 Bronco, FI 460/1995 RIP
I get them all started then tighten the middle top then alternate driver side to passenger side moving from that top center bolt all the way to the back bolts. I usually crank em down good and dont go back over them although thats probly a good idea (I am too impatient). If the foam is good and the top is properly seated, I dont know that a tightening sequence matters, but thats how I do mine.
My other car has doors.
Shane C. is offline   Reply With Quote
Old 01-24-2013, 09:27 PM   #6
fartman
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs
one in the middle then one at each corner, never leaks. dont over think it.
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options.
J A S N
http://www.supermotors.net/registry/19528
free caveman
fartman is offline   Reply With Quote
Old 01-24-2013, 09:37 PM   #7
JScatt
JScatt's Avatar
Alright, well I guess I will loosen it up then pull it back a bit to re-seat it. What is the thread size of the bolts?
Thanks for the input!
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
Old 01-26-2013, 01:30 PM   #8
JScatt
JScatt's Avatar
Just an update on my progress of finding these damn leaks.
The water is leaking through the seams of the top.
Least I know the problem and thanks to Steve83 how to fix it.
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
Old 01-26-2013, 02:18 PM   #9
Steve83
Steve83's Avatar
The captions in my Camper Shell & Sliding Windows album have all the info on bolt threads. Ford never published a tightening sequence for it, but I usually put the bolts into the nut plates first, then those in the U-nuts. If the seal has a light coat of silicone lube or grease all the way around, it's not necessary to tighten-loosen-tighten.
Old 01-26-2013, 05:10 PM   #10
JScatt
JScatt's Avatar
Yeah, I read through your camper shell album. Lots of good info, especially about resealing the seams of the top which is the source of my leaks.
After pulling the top back about six inches I found that everywhere around the seals was dry as a bone.
After running a hose on the top I could see that the water was coming from between the two sections of the top.
Turns out the factory seam sealer was pretty much shit.
What would be the best way to remove the old stuff? I was thinking of using one of those hand held tile grout removers.
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
Old 01-27-2013, 01:48 AM   #11
Steve83
Steve83's Avatar
Didn't you read the TSB that specifically explains how to fix that? It's linked in those captions.
Old 01-27-2013, 04:58 AM   #12
cajunrebel
Chillin on the Gulf Coast
cajunrebel's Avatar
Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
Here is Steve's referenced link.
cajunrebel is offline   Reply With Quote
Old 01-27-2013, 10:49 AM   #13
JScatt
JScatt's Avatar
Yes I did read the TSB. It says to remove the old sealer but doesn't say how.
After looking at the TSB pic it doesn't seem like water could leak through to the inside of the truck even if the old seam sealer was cracked...am I missing somthing here?
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
Old 01-28-2013, 02:13 AM   #14
Steve83
Steve83's Avatar
Originally Posted by JScatt View Post
...doesn't say how.
Steps 1a & 1b aren't explicit enough?
...it doesn't seem like water could leak through to the inside of the truck even if the old seam sealer was cracked...am I missing somthing here?
I guess you're missing the meaning of the word "cosmetic". It means: "only affecting appearance - not functionality". IOW, the cracks just make it ugly; they don't actually allow anything through (since the fiberglass is glued together, and the cracked sealer just fills the groove at the joint). You say yours are leaking - OK. Ford never found that, but the repair should still work, if that's actually where your leak is.
Old 01-28-2013, 08:52 AM   #15
JScatt
JScatt's Avatar
No, I did not miss the word cosmetic which made wonder if the cracked sealer was the actual cause of the leak.
Anyway, after removing the old sealer I could see small gaps between the two sections that are glued together and the leak got way worse with the sealer removed.
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
Old 01-28-2013, 12:48 PM   #16
Shane C.
Shane C.'s Avatar
Not sure what your goal with the topper is (trying to keep it stock?) but I know guys who have had them in pretty bad shape who prepped them the rhino lined them. That sealed them up and they looked pretty sharp. Thats the current plan for mine...
Old 01-28-2013, 08:41 PM   #17
JScatt
JScatt's Avatar
My top had holes in it from a rack that the PO had on it. After the holes were fixed I thought about rhino lining it cuz it does look cool but decided to sand off the factory texture then paint it. It looks pretty good smooth.
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
You may not post replies
Forum Jump
