High pitch noise - FSB Forums
Thread Tools Display Modes
Old 01-24-2013, 09:30 PM   #1
whiteboysbronco
whiteboysbronco's Avatar
Bronco Info: 92 FORD BRONCO EB( 5.8, 351) knn cold air,6 in lift,35 in super swampers, flow master full exhaust
High pitch noise
Well for the last two weeks I've been try to figure out where this noise is coming from and finally figure it out.. My throttle body is bad and now I need a new one, any advice on where I can get one for cheap? Or maybe I'm thinking of upgrade to a better one! I can't go to the for sale section but if anybody can help me out I would much appreciate it...:)
whiteboysbronco is offline   Reply With Quote
Old 01-24-2013, 10:47 PM   #2
knukcowboy
Bronco Info: 1979 bronco lsd front and rear I6 300 motor auto tranny np205 tcase
I've never heard of a throttlebody making a high pitch noise. Interested to hear what exactly causes that but as far as cheap goes...like anything else. Go to a junkyard and pull one of a wrecked unit
knukcowboy is offline   Reply With Quote
Old 01-24-2013, 10:52 PM   #3
cmartin2112
cmartin2112's Avatar
Bronco Info: 1990 XLT, 5.8L 351W, K&N intake, Custom exhuast, 33" MT tires
www.rockauto.com
Very good prices...
cmartin2112 is offline   Reply With Quote
Old 01-24-2013, 11:14 PM   #4
whiteboysbronco
It was the coil that is attached to the throttle body that is leaking. The one that controls the throttle cable..
Sent from AutoGuide.com Free App
Old 01-25-2013, 12:50 AM   #5
Steve83
Steve83's Avatar
Are you talking about the return spring? That can't leak - it must be the bushing & seal on that side of the throttle shaft that you're hearing. Try putting some THICK silicone grease (like MotorCraft Dielectric, or NAPA Sil-Glide) around the shaft against the housing using a Q-tip to see if that stops the noise.
Steve83 is online now   Reply With Quote
Old 01-25-2013, 01:51 AM   #6
whiteboysbronco
Yes the return spring is leaking air. There is a shaft that goes straight threw the throttle body, and right were the return spring is a vacuum leak. I sprayed carb cleaner and my rpms jumped. I finally had to take it to a shop and they told me the same thing that its leaking and I need a new throttle body.. I know it does not sound right and wish I could explain it better.
Steave 83 are you saying I can repair it with a sealer?
Old 01-25-2013, 02:04 AM   #7
Steve83
Steve83's Avatar
The return spring isn't designed to hold air; therefore it can't "leak". It merely happens to be installed around where your TB is worn. No, you can't permanently repair the leak with grease, but you could positively ID it as the source of the noise by at least momentarily stopping it. Any sealer strong enough to adhere to the throttle body would interfere with the shaft's movement.
Old 01-25-2013, 02:15 AM   #8
whiteboysbronco
Well I know for sure there is a leak by the shaft so I need a new one... I'm just glad it will finally stop the high pitch noise and cure my vacuum leak issue I've been trying to find.. Plus again I had a complete race shop who deal with just fords tell me that's I was right on and that it's leaking and that I need a new one so I'm pretty happy about that but hating that I have to spend 200 on a new one...
Old 01-25-2013, 04:53 AM   #9
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
you dont need to spend 200 bucks. got to the junk yard and pull one it is that simple.
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 01-25-2013, 12:53 PM   #10
whiteboysbronco
Ya but then I take the chance of getting another bad one... We didn't have any broncos at our local JY can't I get one off a f150
Old 01-25-2013, 12:57 PM   #11
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
You don't need to get it off a bronco. just get a TB off whatever the fawk engine you have (it'd be nice if you had it listed in your bronco information). Shit, I think the 302 and the 351 use the same TB, but I could be wrong.
Throttle bodies almost NEVER go bad. It's very rare, yours is the exception. Get a JY TB, clean it, swap your IAC and TPS, install with a new gasket and go on with your life.
2006 Kia Spectra 4 banger/5 speed.
I enjoy Alabama Hot-Pockets.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 01-25-2013, 01:16 PM   #12
whiteboysbronco
It's a 351
Old 01-25-2013, 11:50 PM   #13
Steve83
Steve83's Avatar
No, it's a 5.8; 351 is a carb engine. And if your K&N is open to the engine bay, it's a HOT-air intake.
Old 01-26-2013, 02:07 AM   #14
whiteboysbronco
I know it's a 5.8 but its also called a 351 I'm not a dumbass..
Old 01-26-2013, 02:10 AM   #15
whiteboysbronco
And it's a cold air intake
Old 01-26-2013, 01:57 PM   #16
Steve83
Steve83's Avatar
But you think WE are, so you put BOTH in your profile?
My point is: it's common to use c.i. for carb engines, and L for EFI. Whatever you want to do - ONE is enough. Read this caption & use that space in your profile (and signature) for USEFUL info - not redundancy again repeated over & over.
Old 01-26-2013, 03:55 PM   #17
whiteboysbronco
Well Steve83 if you don't like the way I do stuff, dont comment or look at what I post...
Old 01-26-2013, 04:04 PM   #18
TheUnforgiven
Steve is an argumentative dick, but he knows his shit, quit whining and we're more abt to help. And he right its a HOT air intake. It's long been known that the factory air intake on these trucks is far superior AND is true cold air.
Old 01-26-2013, 04:12 PM   #19
whiteboysbronco
Whining who the **** do you think you are to talk to me like that go **** your self....get a life...both of you are the biggest jackasses on this site....it's funny that I'm not the only person who thinks that either on this site...
Old 01-27-2013, 01:38 AM   #20
Steve83
Steve83's Avatar
...dont comment or look at what I post.
No sweat. Consider yourself IGNORED.
...get a life...
Not only do we already have them - we KNOW HOW TO FIX BRONCOS.
Have you met all the jackasses on this site?
Yup - hilarious!
http://www.fullsizebronco.com/forum/...ad.php?t=86532
You may not post replies
Forum Jump
