#1 |
iTrader: (0) Bronco Info: '91 Ford Bronco 351 V8 E40D Tranny D44 TTB 8.8 Rear Axle 4.56 Gears Front and Back 6in Lift w/35in
1356 Tail housing
I'm trying to figure out how to remove the tail housing for a 1356 t-case. I'm trying to figure out the count to the gear inside and see if its damaged.
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Remove rear drive shaft. Remove the nut in the center of the drive flange. Remove the vss/speedo cable. Then remove the four torx head bolts and it should pop off with a little coaxing.
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#3 |
do i need to seal it back with permatex gasket and do i have to drain the t-case out? also, do i have to take the t-case off the bronco.
#4 |
Yes i would reseal it with permatex lightly. No need to drain it as long as your not parked facing up a big hill. And aslo no need to remove the tcase i think. Let me ask you this, are you only taking the tail housing off to count the speedo gear teeth? Or are you looking to open up the whole tcase to have a look inside? Your first post is a little vaige so i figured only the tail housing. If your wanting to open the whole case more is involved.
#5 |
Chillin on the Gulf Coast
![]() Join Date: Apr 2009
iTrader: (3) Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
You can look through the hole for the VSS. Disconnect the driveshaft and put the TC in neutral and use a mirror to look through the hole as you spin the yoke. You should be able to see all of the teeth and if you mark one you can count them as well.
#6 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
You can't count the drive gear teeth since it's a spiral (worm-drive). Don't remove anything but the driven gear. All you need is the COLOR of the drive gear - that identifies its tooth-count.
#7 | |
#8 | |
#9 |
Well, you can count the spirals along the gear and that might be how that website IDs drive gears, but that number will be meaningless for gear ratio (the way most gearsets are IDed). To get the effective tooth count for the ratio, you'd have to wrap something around the drive gear & then count how many lands it crosses. But that would require removing either the gear or the tailhousing, which is pointless when it's color-coded.
#10 |
Well...I just got back from the Hobby Shop( It' a place on the base where you can work on your vehicles) and could not get that nut off to get the tail housing off! I couldnt find the right socket metric and standard to save my life
Even the Ford Master Tech that works there says those gears are color coded. Thanks for all the input fellas
#18 |
My Snap-On chrome 1 1/4" barely fits in my '93 flange. A cheaper brand with a thinner wall should be easier, but cleaning the bore of the flange would help.
#19 |
Does it matter if its six or twelve point. Also, do I need to buy new seals if I'm just removing the tailhousing.
#20 |
No seal needed but for the $5 it costs for the output flange seal its good insurance.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
