#1 |
iTrader: (0) Bronco Info: 91 Bronco Eddie Bauer 5.0 AOD 2" Skyjacker Painted with tan bed liner
Seat Recline
I have a 91 EB....the driver's seat reclines too far back in the most upright position. Is there a way to adjust the seat to where it lets me sit up straighter? Or should I just find some seats in a junkyard...if this is the case is I would appreciate recommendations.
Jon |
| Sponsored Links | |||
Advertisement | |||
#2 |
iTrader: (1) Bronco Info: 1996 Black 302 XLT - 1994 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
Jon, I have a similar problem, I think the seat back is too far back. I had my seat apart a couple of years ago, and on the outside of the seat, there is a sector like part of the seat recline mechanism, with a pawl that sets the seat back angle. I looked at the sector and thought that I might be able to put an additional notch in it to set the seat a little more upright.
At that time, my '96 was my DD and I needed to get the truck back in service (the seat frame cracked, and that's why I had it apart). Bottom line, I've never taken it apart again to cut that additional notch, but it looked like it would not be too hard to do with a Dremel grinding disk.
"The simplest solution is usually the best solution" - Occam's Razor "The significant problems we face cannot be solved at the same level of thinking we were at when we created them." - Albert Einstein |
#3 |
Chillin on the Gulf Coast
![]() Join Date: Apr 2009
iTrader: (4) Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
I have the same problem except my seat flops all the way back. I am going to change the entire brackets for now I think. I guess the PO had a big girlfriend because the passengers seat was FUBAR. I scrapped it and kept the seat mount slider.
#4 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
There may be a pair of angled shims between the chair & the slides that can be removed (with SOME effort) to tilt the whole thing forward. If you only want the seatback forward, start by inspecting the notches in the mechanism for GUNK and make sure it's catching as far forward as it's designed to. Peeling the upholstery is relatively easy - click my tan CV in my signature (BELOW) and read the captions in the Seats & Belts album.
#5 |
I am going to try all of the above....I can't stand laying back like that when I'm driving. Rebel: hilarious...but they happen.
#6 |
I used to know this stuff
yo
Recliner Lubrication, Service, Overview, Part Number (Part of 62648), etc. in a 96 excerpts; The manual recliner system is modular and does not require adjustments. However, proper lubrication of a hesitant seat back recliner assembly is permitted using Multi-Purpose Grease D0AZ-19584-AA or equivalent meeting Ford specifications ESR-M1C159-A and ESB-M1C93-A. The only authorized service permitted on the recliner mechanism is the following: Tightening of all retaining screws to 51-59 Nm (38-44 lb-ft). Replacement (in entirety) of a damaged or nonfunctional recliner assembly. Removal of any foreign material, such as tie straps, pieces of foam and trim
96 XL 5.0 E4OD, Man Xfer/Hubs USN (Ret) & MIL/DoD Contingency Planner (ret) THANKS to ALL WHO SERVE! my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
