#1 |
iTrader: (0) Bronco Info: 93 XLT 351w E40D 6" Toyo Mt Stock Motor
Buying rebuilt 351w what do you think pictures included
Hey all what do you guys think about this motor?? $$ 1,499.00
![]() ![]() ![]() ![]() Rebuilt Small Block Ford 351 Windsor Short Block 0 Miles All Parts Jetwashed & Shot Blasted Clean Block - Bored & Honed + .030, Lifter Bores Honed, Painted Crank - Shot Peened, Resized, & Polished Rods - Shot Peened & Resized Cam - Custom Ground Performance Heads - Performance 3 Angle Valve Job, Bronze Guides, Big Block Springs New Parts Include - Pistons, Rings, Main Bearings, Rod Bearings, Cam Bearings Timing Set, Cam, Gaskets, Oil Pump |
| Sponsored Links | |||
Advertisement | |||
#2 |
SOD BUSTERS Member
Depends on the pistons? and the rest of the parts used in the build
They should not have to re-size the rods, the crank is what should be ground smaller and then you use ovresized bearings for the now smaller crank. Has it been balanced? Also what heads are on it? Also I would ask for specific details on the cam, as if this is going in the '93 listed in your info you might run into issue there.
![]() '92 Eddie Bauer- C6/208 swap, Roller 357W, MAF, RJM Harness, BlueOvalChips SCT Tune '78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's '96 F250- Tow Rig, 460, E4OD Punisher Valve Body, Triple Piler Gauges '92 F150- 2wd, Winter Beater, 3.73's, 5.0 '79 F250- 2wd, Farm Truck, Waiting Restoration '03 SVT Focus- Daily Driver, OZ Wheels, 6 Spd '86 Mustang- Fastback, SOHC 4.6L Swap Project |
#3 |
![]() Join Date: Dec 2007
iTrader: (41) Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
That's not an F4TE (Roller) Block. It's a D4 (1974) block. It will probably be just fine, Run fine, but you may already have the F4TE block in your truck without the roller cam. If they're asking for a core, I don't know if I'd want to part with that.
Definitely get the specs on the cam.....You want to make sure it will work with your SD setup. That's called reconditioning the rods. They cut the cap down, then resize the hole. It doesn't change the length.
~ Scott ~ ~ Ford's, please bring back the Bronco!! ~ ~ My Exhaust clip on YouTube ~ 203k on the odometer and no longer a daily driver. ~ ~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
Last edited by sackman9975; 01-26-2013 at 05:45 PM. Reason: added info from previous quote |
#4 |
SOD BUSTERS Member
that makes sense on the rods. Same as line honing the mains only it just makes the hole round again instead of also aligning them to one another.
I looked at the pics some more and it looks like it has some ARP hardware on it too, so that makes it worth some more then just a stock rebuild, or would to me
![]() '92 Eddie Bauer- C6/208 swap, Roller 357W, MAF, RJM Harness, BlueOvalChips SCT Tune '78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's '96 F250- Tow Rig, 460, E4OD Punisher Valve Body, Triple Piler Gauges '92 F150- 2wd, Winter Beater, 3.73's, 5.0 '79 F250- 2wd, Farm Truck, Waiting Restoration '03 SVT Focus- Daily Driver, OZ Wheels, 6 Spd '86 Mustang- Fastback, SOHC 4.6L Swap Project Last edited by CrazyBRONCOguy; 01-26-2013 at 06:10 PM. |
#5 |
well i talked with the guy today and he said that cam wont work but we can put a different one in that will so what cam should be a good choice and would this be a good motor? btw he does not care about my core i told him im putting it in a sand rail
#8 |
Chillin on the Gulf Coast
![]() Join Date: Apr 2009
iTrader: (3) Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
Its not a bad motor. What are those heads? Do they have the ports in the rear for your smog pump? If not you will have to deal with removing that. About the best thing that you could do if you are wanting to have a motor ready for yours coming out is go to the junkyard and pull a 94-97 5.8 and rebuild it. Just pull the heads in the yard and see the condition of the cylinders. A 94+ block should be roller ready at minimum. Thats atleast what I am planning to do this summer.
#11 |
Man with a Golden ticket
![]() Join Date: Jul 2007
iTrader: (0) Bronco Info: 96 blackout XLT Sport 5.8L E4OD, 4" Rancho w/ 35" MTR's
I am getting a bad feeling that this is not going to end well.
Do you have any engine building experience? what is the reason the guy is abandoning his build?
You just might be a redneck if you start a conversation with: ![]() "happened to us when Dad got pinched by the feds." - Biker Pepe' - |
#12 |
Great question! I didn't even think about that being an older motor.
#13 |
Unforgiven's Pet
iTrader: (4) Bronco Info: '90 xlt 351w E40D Truetrac I GOT ROLLER ROCKERS !
Cole, All roller rockers are going to do on a stock motor are keep the valve guides from being side loaded when the rockers actuate the valves, therefore cutting a path in the valve guides {in the long run} and eliminating the stock fulcrum sukkage. Do not buy them for the 3 or 4 h.p. that you will get.... That timing chain kinda sucks too.... kinda.
#14 |
You will never get 300hp out of that engine. To make that hp the heads would have to flow 40 hp over those stock heads you have there. Also the compression would have to be at least 9.1 or so and those pistons look like original stock dished pistons. With the increased hp you would also need upgraded exhaust over stock and upgrade in injectors and etc etc. You have there a good built stock engine with about 230 or 240 hp the way it looks.
#15 |
![]() Join Date: Jun 2010
iTrader: (1) Bronco Info: Brick Nose on 15x10s/32s with leveling coils
70s engines are dime a dozen. someone is always trying to pawn off a 70s 351 or 302 off on someone in every major city on craigslist. I wouldn't put it no 94+ ford truck I cared about.
#16 |
iTrader: (0) Bronco Info: 1978 Bronco, 466 EFI
Downsides:
2 piece rear seal 70's casting, nothing special or noteworthy here. Rods are probably from a passenger car Paint on oil pan rail and pump attaching point worries me. Typically you do NOT paint these. Offer him $600, if he does not take it then walk away. Get an F4TE from the pick-n-pull and rebuild it yourself.
Opportunity is missed by most people because it is dressed in overalls and looks like work- Thomas A Edison |
#17 |
![]() Join Date: Oct 2005
iTrader: (0) Bronco Info: 84 full sixpoint cage,engine cage,prerunner bumpers,trussed and disc braked 9inch,king coilovers etc
I think you could do better.Maybe go to a wrecking yard and find a explorer with a 302 in it with the p40 heads. tell the pick-a-part guys you need some explorer 302 heads. And maybe you can get out of there cheap. Dont say you,re looking for P40 heads.Price will go up. And then find a newer F4TE block. Take it to a good machine shop for about $500 bucks for hot tank,bore,hone,surface block,new cam bearings,and freeze plugs.pick a good cam from the SD EFI cam choices on here.with new roller timing chain,and high pressure oil pump.And have the machine shop set you up with a new set of SRP pistons with a little more compression.Up from the stock 8.8 to 9.5:1 or so.I would think you could come close to the motor your looking at price wise.And be alot better foundation.Not to mention more HP.JMHO.
#18 | |
#20 |
he also said he can rebuild mine if i wanted him to. Would that be a better options he said i could have him put what ever i want in it im only gonna have around $$1600 to play with and thats the only decent price i have found unless you guys can point me into the right direction or just have him rebuild my motor also this a machine shop he builds them
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
