#1 |
iTrader: (0) Bronco Info: 1990 bronco 5.0, 1979 f150 4x4, with the 400/c6
Ladder bar/traction bar ??
Okay I'm looking at getting a traction bar/ladder bar for my 79 f150, what's a good setup to go with and were could I find it? I was looking at the one on JBG but us like some other options and yalls opinions
Sent from AutoGuide.com App |
| Sponsored Links | |||
Advertisement | |||
#2 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
Any setup that uses 2 will interfere with articulation. I'm building my own single central bar that will ONLY stop axle wrap; nothing else. There was a thread about 2 months ago with several pics - try searching...
#3 |
Local # 40 Boilermakers
![]() Join Date: May 2007
iTrader: (20) Bronco Info: 5.8 w/ MSD, optima, K&N, OBA, 8 lugs, Detroit w/ 4.88's, 4 wheel disc brakes & Kick ass camo,
Plug ugly had a good one, at least I plan to build one similar.Looked simple and strong and from the pics I seen it would flex fine too.
#4 |
iTrader: (0) Bronco Info: 95 XL lifted, bored and capable
What about the Superlift ones or something similar?
http://broncograveyard.com/bronco/i-...Fa5QOgodowUAvg I am also toying with the idea of either building 1 like Plugs or just buying this kit
Built 351 w/GT40 heads, E-fan, Flowtech ceramic coated shorty headers, Bassani y-pipe, single chamber 3" muffler,10.25" rear, ZF 5spd, 16.5" chrome wagon wheels, 37"x 12.50" Goodyear Wrangler M/T OZ tires, 6" lift ProComp rear leafs, Front Leaf D60 SAS Front bumper build in progress!
#5 |
I was looking at those also but I still need to be able to haul some and that setup don't seem like it would work?
#6 |
If you can build it then do it, you can build one better for cheaper than what you will buy.
#8 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
You would need one of these, a welder or someone to weld it and a grinder. If it were me i would replace the single bushing nearest the tcase with a hiem joint.
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#9 |
I meant as far as material for the actual build, I have everything needed to fab it just need some ideas on material
#10 |
You can try to design around the materials you have, or you can try to use your materials in an existing design. That's why engineers get paid the BIG bucks!
Cobbling something together that looks vaguely like something you saw is probably NOT going to achieve the effect you want. It may only lower your CG.
#11 |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
