blower randomly doesnt work - FSB Forums
Thread Tools Display Modes
Old 01-28-2013, 02:18 PM   #1
DKM MIKE
DKM MIKE's Avatar
Bronco Info: 1989 XLT 5.0L 3spd auto w/od
Hey guys. This morning(about 36 degrees) I got in my 89 bronco to warm it up and the blower didnt turn at all. it was like it was unplugged completely, but it wasnt. I checked the fuse and harness and they were both fine. Later on down the road I tried it again and it came on just fine as normal. This isnt the coldest morning its been in. Ive had 22 degree days and it worked fine. Its a brand new blower and the speed switch in the dash is also new. Im asking in fear that Ill have to take another morning drive freezing my ass off. Thanks
YOU WANT SOMETHING DONE RIGHT, DO IT YOURSELF
DKM MIKE is offline   Reply With Quote
Old 01-29-2013, 09:16 AM   #2
mettler
The only other part in the line is the resistor. Tho I dont see why it wouldnt allow operation at all. I am not an electrician so Im not sure on how to check resistance. Ive never been able to master that skill but, process of elimination would point to the resistor if the other two components are new and all the fuses are good.
Real men do it in the mud
mettler is offline   Reply With Quote
Old 01-29-2013, 10:35 AM   #3
DKM MIKE
DKM MIKE's Avatar
OK so this morning I noticed the blower works fine key on engine off. Its when I start the engine. Also my key is sticking so the starter will stay on if I don't pull it back.
Old 01-29-2013, 11:18 AM   #4
87Roughneck
87Roughneck's Avatar
Bronco Info: '87 Bronco Custom; 300cid EFI w/ 3" exhaust; 35" Goodyear Wrangler Kevlar MTRs on 15x8; 2.5" lift
When the blower does not work, do the rest of the accessories work or not?
"I'll try to be nicer if you'll stop being an idiot."
Originally Posted by Steve83 View Post
Is he STILL arguing this? I put him on my ignore list years ago, so I don't have to read his ranting.
Originally Posted by TheUnforgiven View Post
Years? He's only been here since February of this year.
87Rougneck knows his shit, even though he can be a dick. I'd listen to him.
87Roughneck is offline   Reply With Quote
Old 01-29-2013, 12:26 PM   #5
Steve83
Steve83's Avatar
What exactly does that mean? Did you pull the fuse out? Click this & read the caption:
You should also search up the Tech Writeups thread about the "ignition actuators", read it, and then inspect yours.
Steve83 is online now   Reply With Quote
Old 01-29-2013, 04:54 PM   #6
DKM MIKE
DKM MIKE's Avatar
So I mentioned the keys getting stuck and starter stays engaged. Same with blower. I have to click the key back a little because there's no electricity going to blower cause it thinks the starters turning. Actuator rod?
Old 01-29-2013, 09:18 PM   #7
Steve83
Steve83's Avatar
...or ig. sw. It's pretty easy to pull the plastic column shrouds off & watch the rod as you turn the key. If the rod doesn't mimic the key motion, buy actuators. If it does, buy a switch.
You may not post replies
Forum Jump
