I can only put gas in 10 cents at a time !!!! What - FSB Forums
Thread Tools Display Modes
Old 01-28-2013, 06:14 PM   #1
b-rex90
Bronco Info: 1991 bronco xlt
Hi I think I have air in the lines or a bad vent I guess my bronco won't let me put more than 10 cents of gas at a time with out stopping the gas pump so it take me like a hour to fill the truck
b-rex90 is offline   Reply With Quote
Old 01-28-2013, 06:16 PM   #2
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Was the gas tank recently dropped?
The problem has to do with the air return, it's either out of place from a recent drop, or it's developed a hole.
~ Scott ~
~My Exhaust clip on YouTube ~ 204k on the odometer and no longer a daily driver. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
sackman9975 is online now   Reply With Quote
Old 01-28-2013, 06:19 PM   #3
b-rex90
I have never dropped the tank but I have only owned truck for six months
Old 01-28-2013, 06:24 PM   #4
sackman9975
It's not an easy task, but can be done without dropping the tank.
If you crawl under the truck and take a look at the bolts holding up the tank, usually you can see evidence that the tank has been dropped before (missing bolts or mismatched bolts).
If this just started, most likely it's developed a hole.
~ Scott ~
Old 01-28-2013, 06:49 PM   #5
96EB351
96EB351's Avatar
Bronco Info: 1996 Eddie Bauer 351 e4od stock auto hubs
couldnt it be a clogged air return line?
96EB351 is offline   Reply With Quote
Old 01-28-2013, 06:57 PM   #6
sackman9975
I guess it could be, but what's going to clog it? Gas is liquid and that should be the only thing in there.....
~ Scott ~
Old 01-28-2013, 07:00 PM   #7
96EB351
96EB351's Avatar
who knows, but i've heard of that before.
Old 01-28-2013, 07:17 PM   #8
Steve83
Steve83's Avatar
Study this & follow the links in the caption:
Old 01-28-2013, 07:59 PM   #9
351w500
Unforgiven's Pet
351w500's Avatar
Bronco Info: '90 xlt 351w E40D Truetrac I GOT ROLLER ROCKERS !
Kink in the filler.
351w500 is online now   Reply With Quote
Old 01-28-2013, 08:11 PM   #10
88Bronco300
She likes my
88Bronco300's Avatar
Bronco Info: '88 XLT with 4.9. 10" of lift on 40's. Saving for sas!
Something wrong with the gas pump? Did you try different pumps?
88Bronco300 is offline   Reply With Quote
Old 01-28-2013, 10:48 PM   #11
TheUnforgiven
I Swallow on 1st date.
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
That's not a gas pump issue, that's a truck issue. I had this exact problem on my spectra, the vent fitting for the vent line was clogged and full of garbage. $8 part, cost me $450 after i threw parts at it, gave up and took it to dealer. that was an expensive lesson.
I don't know if a bronco has that type of emission parts (vent valves and the like) but i'd check what steve suggested and make sure the vent for the tank is clear of all obstructions. Yes i KNOW how much it sucks to have to to trickle fuel into the tank, and i was only filling a 14gal tank. Couldn't imaging having a 33 gallon to fill.
2006 Kia Spectra 4 banger/5 speed.
Anything for you Saltlife!
Originally Posted by paintballdude902 View Post
I'm going to shoot you and rape your girl
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 01-28-2013, 10:56 PM   #12
bulrid8
Bronco Info: 1990 4x4 351w
You have a inch hose that is your filler hose. That goes into tank. Then you have the three inch hose around that.. 3" runs from tank to filler neck. 1" runs inside 3" and goes inside tank.
The large 3" is your vent hose. Look under rear fender at back side of filler neck. See if hose is linked at all. Or you can disconnect filler and pull hoses out to inspect.
Unbolt filler neck, lossen clamp on 3" hose. Pull filler neck off. 1" hose will slide out with neck. No need to drop tank.
bulrid8 is online now   Reply With Quote
Old 01-29-2013, 09:54 AM   #13
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
I used to have this issue. It would take me a good 10+ minutes to fill my tank, and I had to stand next to it, leaning over, listening to the gas going in because once the pitch changed, I knew it was going to barf out a bunch of gas all over the ground.
It was a problem with the filler neck and it not venting. Once I figured out what was causing it, it was an easy fix.
1981 & 1984. Both w/ 300 I6. Holley 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 01-29-2013, 10:51 AM   #14
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
The 1" filler hose that Steve shows there for your '91... had fallen off and
was inside in the rear tank on the '91 F150 I inherited. Don't know how it
got that way, there was talk about they were -going- to drop the tank on
it but I don't believe they had yet. It had only 66k miles on it.
Wasn't any harder to fill than the rear tank on my '75 F150 I bought new.
The '75 F150's been a friggin' pain to fill from the very first day. :(
The trick to it is to park with the truck tilted-away from the pump and to
also tilt the filler nozzle 20 degrees or so either direction from straight up.
I don't bleed blue, YMMV on that? ;)
Anyway, my Bronco doesn't have the 1" plastic-filler-hose either because
it'd gotten damaged from throwing the tread off a tire before I got it. The
parts truck's 1" filler pipe was screwed up too etc so I ain't got one on the
'91 Bronco. It's not that big of a deal, for me, since the Bronco takes fuel
a little bit better than the '75 F150 I've had for ~38 years. :)
So...
If -your- trouble is because the filler hose fell off, then just know your '91
Bronco takes fuel -better- than the Ford-designed-it-that-way-early-
dent-side-pickups. And be friggin happy about it! ;) LOL
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 01-29-2013, 11:44 AM   #15
ModIt
Gone..Be back at Dark :30
ModIt's Avatar
Bronco Info: 89 XLT, '12 Ford BlueFlame Metalic Paint, Soft Top for Summer, Stock 302 and AOD Trans.
Just my 2 cents, but could it be possible that there is something in the filler tube? I am thinking maybe something like someone tried to stick a hose in the tank to siphon gas, and hose got dropped in filler.
If it has Tits or Wheels, It WILL give you problems. Just Enjoy the Ride while you can.
ModIt is offline   Reply With Quote
Old 01-29-2013, 01:37 PM   #16
jowens1126
jowens1126's Avatar
Sounds to me like the filler tube fell into the tank and your just filling thru the vent tube. Its easy to check. Remove the clamp on the tank holding the vent line, remove the screws holding the filler neck to the body, remove hose. If you only have one hose thats the problem.
1994 EB Bronco, 302 MAF, E4OD, BW1356, box stock
jowens1126 is offline   Reply With Quote
Old 01-29-2013, 01:49 PM   #17
AFBronco235
AFBronco235's Avatar
Bronco Info: 91 Bronco w/ 5.0 L V8, Auto w/ E40D
You think 10 or 15 minutes to fill a tank is a pain. Try over an HOUR. I'm talking about how our motor pool on base added a mesh screen to the 120 gal fuel tanks on our de-icing trucks. The screens would be clean, but they didn't let the gas flow fast enough and would always shut down the pump. UGH! And we didn't even fill them up all the way.
1991 Bronco w/ 5.0L V8, Auto w/ E40D trans, factory spare tire rack,
Prev. Owner added: trans temp guage (NF),
AFBronco235 is offline   Reply With Quote
You may not post replies
Forum Jump
