Fuel Filter stuck - FSB Forums
Thread Tools Display Modes
Old 01-29-2013, 12:17 AM   #1
Helipilot2
Helipilot2's Avatar
Bronco Info: 1996 Bronco 302 w/ M5OD
Fuel Filter stuck
I am trying to change the fuel filter on my buddies 94 F-250, its the big 460. The filter is located right in the frame rail just like my broncos. I have the tool for removal but the line will still not disconnect from the filter, the tool will only slide about half way in. Any suggestions?
1996 Ford Bronco
302 w/ 5spd tranny, Manual locking hubs
Pictures
http://www.supermotors.net/25534
Helipilot2 is offline   Reply With Quote
Old 01-29-2013, 12:57 AM   #2
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
push harder it will go or should. spray wd40 in there then use air. sometimes dirt will get packed in there and make it hard for the tool to work.
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 01-29-2013, 11:52 AM   #3
Steve83
Steve83's Avatar
Study this diagram & its caption:
Larry, if you weren't in the quote thread before, you are now!
Old 01-29-2013, 02:00 PM   #4
96EB
96EB's Avatar
Bronco Info: 1996 Ford Bronco EB *STOCK* Mods to come
Might not be using correct size, try a different size of disconnect. Or just push harder
96EB is offline   Reply With Quote
Old 01-29-2013, 02:07 PM   #5
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
Remember they are saying "push" the lines harder against the fuel filter, then apply the tool. When properly seated, then pull on the lines.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
Old 01-29-2013, 03:24 PM   #6
LarryP
Thanks 351w500
LarryP's Avatar
thank you for making that more clear
You may not post replies
Forum Jump
