#1 |
Is my alternator toast?
Hey guys, it's been awhile. My bronco has been having electrical issues for over a year. The battery would die when left off, randomly at first. Then it would started happening more frequently and faster.
After troubleshooting for a bad ground and pulling fuses one at a time I couldn't find a "leak". the test light would stay lit no matter what I disconnected. Last time I drove it the voltage shot up way higher then usual, so I suspected the voltage regulator. I disconnected the voltage regulator and BINGO, no more leak. I though it was going to be as simple as a new voltage regulator. Now my worry started when i took my alternator apart and noticed that some of the diodes on the rectifier look burnt and one of them had a solder point that was completely loose. This one isn't loose but it is not seated right. ![]() This is the one that is loose and comes out. you can lift it right out of the diode. ![]() A couple of others just look a bit burnt.
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Id say get replacement parts from fireguy's site, rpm injection. I wouldnt want to run it like that.
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#3 | |
![]() Join Date: Jan 2010
iTrader: (1) Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
Or upgrade to a higher output alt from his site.
"hold my beer and watch this" ![]() Hydroboost walkthrought My Build Thread!! II My Build Thread!! - retired |
#4 |
#5 |
#6 |
Chillin on the Gulf Coast
![]() Join Date: Apr 2009
iTrader: (3) Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
http://www.rjminjectiontech.com/
He separated the sites after Ford gave him a bunch of grief a while back. Got an order from him a couple weeks ago. |
#7 |
I ended up getting a 3G 160 amp from a e350 diesel for $60 shipped on eBay. I had to switch the pulleys but other then that I should be fine. I'll put it in tomorrow and see if it solves my other electrical drain issues and then I can finally tackle my smog issues.
#9 |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
