receiver hitch - FSB Forums
Thread Tools Display Modes
Old 02-04-2013, 04:18 PM   #1
cjy01
cjy01's Avatar
Bronco Info: 1996 ford bronco 33' mt
receiver hitch
does anybody have install pictures for receiver hitch install for a 96 ford bronco
cjy01 is offline   Reply With Quote
Old 02-04-2013, 04:48 PM   #2
oakback
Bronco Info: 1988 Bronco Custom 302 C6
Have you looked at etrailer.com? They have install pics and/or vids.
link for '96 bronco hitch
The vid on this one is for an F150, but in the comments below, someone says:
I installed this receiver on a 1995 Ford Bronco. Plan on about 3 hours for installation on this truck because access to the frame is blocked by the gas tank. I found it easier to lower the gas tank instead of trying to fish the bolts with a wire. Good fit and quality construction. Instructions were simple and complete, including torque specs. Video of the F-150 install will give you a good idea of what's involved.362
I promise I'm not a shill for etrailer.com. I haven't used them for my Bronco (yet), but I did buy a hitch from them for my Mazda minivan, and have been pleased.
oakback is offline   Reply With Quote
Old 02-04-2013, 05:04 PM   #3
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
moved
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 02-04-2013, 08:34 PM   #4
black95-302/M5OD
Bronco Info: also a white96-302/E4OD and a 1993 F150 SC XLT 2WD 351/E4OD
It's definitely a PITA to put a receiver hitch on a Bronco. I didn't want to mess with dropping the gas tank, and I couldn't get a fish wire to work (probably both a lack of finesse and not wanting to wallow out the mounting holes), so after much cursing and gnashing of teeth I thought of using one of those little 4-prong spring-loaded pickup tools. I used the pickup tool and a little duct tape to hold the bolt and slid it down the inside of the frame rail, and was able to drop the bolts right into the holes. It was a pretty tight fit on the driver's side because there's more stuff on that side, as I recall, but it ended up working pretty well for me.
black95-302/M5OD is offline   Reply With Quote
You may not post replies
Forum Jump
