rear shackle angle - FSB Forums
Thread Tools Display Modes
Old 02-04-2013, 05:36 PM   #1
m-unit
Bronco Info: 1990 5.8 e4OD, 2wd, 5in" lift, 33's
rear shackle angle
please advise on my shackle angle. This is with full weight of vehicle on the truck...
I have 4-5" lift springs in the front (deaver maybe) and hefty's 2.5" shackle flip in the rear as well as an add-a-leaf.
I'm thinking of getting a longer shackle from hefty to add some height. Perhaps that will help?
opinions
m-unit is offline   Reply With Quote
Old 02-04-2013, 05:59 PM   #2
Steve83
Steve83's Avatar
These are the primary considerations for shackle angle:
1) at normal ride height, the line between its bolts should be roughly perpendicular to the line between the leaf spring eye bolts.
2) at either extreme of the suspension travel, those 2 lines should not approach parallel.
Old 02-04-2013, 06:51 PM   #3
JBfab
JBfab's Avatar
Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Why is your second leaf shorter then the third? Angle doesnt look bad.
It's not custom if you bought it from a catalog!
Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825
JBfab is offline   Reply With Quote
Old 02-04-2013, 07:10 PM   #4
m-unit
gotcha. I'll check it out when it's flexed to see what's going on as it cycles.
Old 02-04-2013, 07:34 PM   #5
BRONCONUT
Local # 40 Boilermakers
BRONCONUT's Avatar
Bronco Info: 5.8 w/ MSD, optima, K&N, OBA, 8 lugs, Detroit w/ 4.88's, 4 wheel disc brakes & Kick ass camo,
The angle is bad, you need to shoot for about a 30* angle on the shackle. Looks like you need to move your front hanger back a bout 1-1.5" to get it right. Where you are now you are pretty much depending on the springs to do all of your movement wich means you are within inches of max down travel. If you move the front hanger back some it will also help recenter the wheel in the wheel well. I did this exact tsame thing along with a 1" inch zero rate.
BRONCONUT is online now   Reply With Quote
Old 02-04-2013, 07:54 PM   #6
BRONCONUT
BRONCONUT's Avatar
Here is a pic of a good shackle angle
Old 02-04-2013, 09:24 PM   #7
m-unit
I've read about moving the front hanger back. Always something to do with this thing...
I need to move my pass side radius arm mount up an inch as well. lots of dam drilling. I hate drilling.
edit// should center up the tire in the wheel well too eh?
Old 02-05-2013, 01:36 AM   #8
Steve83
Steve83's Avatar
Yeah, the gas tank angle looks just about right, too.
BEFORE you start cutting & drilling in your frame, try aligning the BODY to the frame first. Loosen all 10 body bolts and use a hydraulic jack to get it centered across the frame, and fore-aft onto each bolt hole. Then retorque all 10 to spec. That might be all it takes to get the wheels centered in the arches.
Old 02-05-2013, 09:43 PM   #9
m-unit
steve I was under the impression that it's not the body, but the rear that gets shifted forward because of the shackle flip.
Old 02-06-2013, 12:20 AM   #10
Steve83
Steve83's Avatar
Regardless - CHECK the body position before attempting to adjust the axle to match the (possibly displaced) body.
You may not post replies
Forum Jump
