Engine diagnosis, rod knock. - FSB Forums
Thread Tools Display Modes
Old 02-11-2013, 09:52 PM   #1
musclegto
Seeking your advice in diagnosing my engine. The truck has a new battery, cap and rotor, spark plugs and wires and an oil change. The engine turns over fine, sometimes I need to hold the gas a little when I start her in the morning. It idles fairly smooth expect for a repeating knock in the engine. My buddy said it was rod knock. No vacuum leaks that I was able to detect and it is not throwing any codes. How would I go about in diagnosing the problem? The oil levels are good.
95' 5.0/E4OD
musclegto is offline   Reply With Quote
Old 02-11-2013, 10:06 PM   #2
omp
Bronco Info: 96 302, 5spd, 4" lift
Install a Mech oil pressure guage and check oil pressure if you suspect any mech knocking. Can also get a 2' long heater hose, have motor running and see if you can isolate the sound with it. A stethescope is easier but i'm cheap and heater hose I have.
Have you pulled and checked plugs, see if one is discolored differently.
Look at manifolds for black soot if there is a leak or cracks.
omp is offline   Reply With Quote
Old 02-11-2013, 10:15 PM   #3
musclegto
Not sure if this is related but I have a good amount of exhaust smell in the cabin. I was thinking it was an exhaust leak. Anyway, the plugs were installed 3 days ago ran maybe 20 miles, too early to pull them for discoloration?
95' 5.0/E4OD
Old 02-11-2013, 10:19 PM   #4
omp
Check for cracked manfiolds for sure then. How many miles? Mine they where both cracked at the back near the collector and I was missing two bolts on each side as well.
Exhaust coming into cab? Do you have any holes in exhaust pipe, driving with rear window down sucks all that sleepy gas inside if any leaks.
Old 02-11-2013, 11:18 PM   #5
rwrankin
exhaust leak will sound more like a tick than a knock. unless you have a portion of the exhaust physically banging against something with the vibration of the motor.
x2 on the hose to isolate the sound. you can also use wooden rod like a broom handle.
rwrankin is offline   Reply With Quote
Old 02-11-2013, 11:20 PM   #6
rwrankin
good way to check intake cracks is to spray starter fluid or carb spray on the area. if there is a crack in the intake you will hear the motor jump rpms.
Old 02-12-2013, 12:37 AM   #7
buffaloroams
Man with a Golden ticket
buffaloroams's Avatar
Bronco Info: 96 blackout XLT Sport 5.8L E4OD, 4" Rancho w/ 35" MTR's
X3 on the hose.
Garden hose works just fine too.
Great way to isolate where the knock is coming from.
Sometimes the old school ways are still the best.
I would recommend you isolate the noise first,
May save you a lot of unnecessary time and effort.
You just might be a redneck if you start a conversation with:
"happened to us when Dad got pinched by the feds."
- Biker Pepe' -
buffaloroams is offline   Reply With Quote
Old 02-12-2013, 12:42 AM   #8
musclegto
will do on the garden hose
95' 5.0/E4OD
Old 02-12-2013, 12:43 AM   #9
musclegto
might actually have access to a stethoscope
95' 5.0/E4OD
Old 02-13-2013, 05:50 PM   #10
BigCheeseStick
BigCheeseStick's Avatar
Bronco Info: '94 XL 5.0, 5 speed
Harbor Freight sells them for like $3 :/
BigCheeseStick is offline   Reply With Quote
Old 02-13-2013, 07:17 PM   #11
kemicalburns
Never Done
kemicalburns's Avatar
being an 95 you have efi. pull codes should be your first step. if your hitting the gas peddle to get it started that also is an issue being you shouldnt need to do that. check your fuel pressure as well and timing
94 XLT 357/E4OD Trans-go stage II
6" Stage II ProComp,35x12.50BFG/AT
4.88 f (aussie) / r (open) / Custom Sliders
JBA headers,Custom Y pipe hi flow cat & Full 3"
kemicalburns is offline   Reply With Quote
Old 02-13-2013, 09:04 PM   #12
musclegto
noted
95' 5.0/E4OD
Old 02-13-2013, 10:39 PM   #13
yoomooman
my bko ate my money
yoomooman's Avatar
Bronco Info: 92 Eddie Bauer Bronco 5.0, E4OD,MAF Conv, sixltre tune-up, OBA, on 31x10.50x15s
the hose is a good method
also if it comes rite down to it and you cant isolate the rod/crank knock youll have to drop the oil pan and try to wiggle each rod journal to see which one is knocking
if a rod is found to be knocking hopefully it wont be slaping the head and all youll have to do is replace that rod/bearing/piston rings for that cylinder......hone the cylinder before reinstalling the piston so the rings can seat properly
parts needed would be a complete engine gasket set, connecting rod, rod bearings, piston rings, fresh oil, and a cylinder hone with instructions on how to hone a cylinder properly
92 Eddie Bauer bronco 5.0--Travis
Originally Posted by jopes
11:47 pm: hand pack it on the shaft. it's somethign you should be good at
yoomooman is offline   Reply With Quote
Old 02-13-2013, 11:07 PM   #14
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
I've heard manifold leaks that sound like knocks. the fact that you have exhaust IN the cab, and this sound, i'd thoroughly inspect the exhaust system.
2006 Kia Spectra 4 banger/5 speed.
Originally Posted by paintballdude902 View Post
I'm going to shoot you and rape your girl
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 02-14-2013, 01:29 AM   #15
Mikey350
Bronco Info: 1996 Black 302 XLT - 1994 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
The classic method of finding a rod knock is to run the engine up to about 1000 RPM, and then pull one plug wire at a time. The knock will go away when you pull the plug for the offending cylinder.
Mikey350 is offline   Reply With Quote
Old 02-17-2013, 05:38 PM   #16
war1ock
war1ock's Avatar
Bronco Info: 1980 300 I6 4spd/1981 302 C6
So the rod wont knock since theres no ignition in the cylinder? The compression alone wouldnt be enough to make the rod move?
war1ock is offline   Reply With Quote
Old 02-17-2013, 07:29 PM   #17
windsoreight
windsoreight's Avatar
Bronco Info: 1992 Nite Bronco
Yes, it takes the load off the piston and the rod.
windsoreight is offline   Reply With Quote
Old 02-17-2013, 07:48 PM   #18
war1ock
war1ock's Avatar
Thats awesome,im guna have to remember that
Sent from my C771 using AutoGuide.Com Free App
My Build
Old 03-01-2013, 09:20 AM   #19
Mitchy7
Rod knock/crank bearings
You shouldnt let your girlfriend sign you up with mitchy as your user name...
i'll never let it go.
Mitchy7 is offline   Reply With Quote
Old 03-03-2013, 07:14 PM   #20
blackbronco92
I have a Straight Six
blackbronco92's Avatar
Bronco Info: (SOLD) 1992 Bronco XLT, 6" BDS, 35" Pro-Comp, 4.9L I-6, E4OD
I don't feel like that is a reliable method. And how is that easier than a stethoscope?
1987 Chevy K10 4x4, 4.3L TBI V6, 700R4, SWB, 31" A/T's
1994 F-150 XLT 5.8L, E4OD, 2WD, Reg. Cab, LWB.
2011 Chevy Colorado LT 3.7L I-5, 2wd (Company Truck)
[Gillamonster] 9:50 pm: broncos will suck you dry if you arnt careful
blackbronco92 is online now   Reply With Quote
You may not post replies
Forum Jump
