Need advice on tranny swap auto to stick - FSB Forums
Thread Tools Display Modes
Old 02-11-2013, 10:42 PM   #1
BigCountry62
Bronco Info: 1990 bronco 5.0, 1979 f150 4x4, with the 400/c6
So I'm trading a guy my 85 f150 for a 79 f150 with 390 4 speed, comes with a 351m, c6 tranny and tcase, 2 Dana 44 complete hub to hub, another 4 speed, radiator with electric fan and more lol, I have a 79 f150 already with a c6 and want to convert to a 4 speed, how hard would it be? And is a 4 speed better than a auto on and offroad? Or just funner lol any and all advice is appreciated
Sent from AutoGuide.com App
BigCountry62 is offline   Reply With Quote
Old 02-11-2013, 11:02 PM   #2
lifeizhard102205
lifeizhard102205's Avatar
Bronco Info: 1993 EB 351W, SAS'd 44, 37" Hummvee tires, 10.25 rear, smittybilt 12k winch homemade mount
in your case it's a matter of finding a tranny with the correct bell housing bolt pattern and then adjusting driveshaft and tranny crossmembers. manuals aren't necessarily better or worse. it's your opinion. i think they are more fun and they can limp home if you poke a hole in the housing and lose the fluid. autos, especially the C6, can take a lot of power and are more convenient. the downside is they are heavier and if you poke a hole in the housing, can't drive anymore. i've blown a stock nissan truck trans and was stuck with 2nd gear only. i tend to prefer manuals however, i've seen people run autos with no problems behind high power rigs. in the end, it's your call. one thing i gotta give credit to autos....they are much harder to stall.
lifeizhard102205 is offline   Reply With Quote
Old 02-12-2013, 12:15 AM   #3
BigCountry62
So I would need different driveshafts front and rear? I've drove manuals and they are fun, If it's gonna be more headache than its worth I might stay with the c6, in just torn between the two lol
Old 02-12-2013, 01:33 PM   #4
BigCountry62
Still stuck
Old 02-12-2013, 02:38 PM   #5
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
You may be able to just find the driveshaft in a junk yard.
Other things you need to consider is the linkage for the clutch. The pedal swap is pretty straight forward, but you'll also need the components that connect the clutch to the bellhousing.
You'll also need a hole in the floor for the shifter. You can either get a center hump from a manual truck and put it into yours, or cut into your current one.
None of it is exactly hard, but it's more than just sticking the trans onto the engine.
Personally, I prefer a manual to an auto. The granny gear in the manual is also a big plus. They don't rob the engine of power like an auto does either.
1981 & 1984. Both w/ 300 I6. Holley 465 / 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 02-12-2013, 02:47 PM   #6
BigCountry62
The 4 speed I'm gettin is off a 390 but I got a 400 will it work bell housing wise? I'm gettin the other 79 that has the 4 speed in it so I got everything neccassary, but il have get a new clutch and pressure plate to fit on the 400 correct?
Old 02-12-2013, 03:10 PM   #7
Robs79BBbronco
Robs79BBbronco's Avatar
Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
You should get a new clutch anyways....the 390 bellhousing is not the same as the 400's.
Sent from my XT603
Robs79BBbronco is offline   Reply With Quote
Old 02-12-2013, 03:12 PM   #8
BigCountry62
What's interchangeable with the 400 or am I gonba have to go look for a bell housing
Old 02-12-2013, 03:19 PM   #9
rvcam
rvcam's Avatar
Bronco Info: 1979 Bronco, 400ci, 3" Lift, 33" Coopers.
A 390 is an FE block, the 400 is a big block. The bell housing will not match the block.
-too slow
-rvcam
1979 Bronco Ranger XLT, 351M400, C6, 4" lift, 33" Coopers.
http://www.supermotors.net/23872
rvcam is offline   Reply With Quote
Old 02-12-2013, 04:13 PM   #10
rvcam
rvcam's Avatar
400 is interchangeable with a 429 or 460 on the bell housing but the flywheel pattern is the same as a 351W.
-rvcam
Old 02-12-2013, 04:34 PM   #11
BigCountry62
What about the 351m?
Old 02-12-2013, 06:12 PM   #12
johnnyreb
auto or standard
You will also need the slutch equalizer bar. When you connect it to a 352-360-390-428--the equalizer bar has a bad lean to it. To correct this. Take the equalizer connector on the frame--and the socket on it will need to be set up so it will be as level as you can it. The everything else will be in line.
johnnyreb is offline   Reply With Quote
Old 02-13-2013, 12:42 AM   #13
BigCountry62
One more ?, what's the best 4 speed to go with?
Old 02-13-2013, 11:59 PM   #14
Robs79BBbronco
If going with the 351m...none of the FE stuff should be used...use the bellhousing,clutch fork off the 400 parts truck.best 4 speed?T18,np435, are both good and stout as hell.
Sent from my XT603
Old 02-14-2013, 01:39 AM   #15
BigCountry62
The parts truck has a 390, the truck that is gettin the 4 speed has the 400
Old 02-14-2013, 08:56 AM   #16
AbandonedBronco
Big Six
Definitely a T18, T19, or NP-435.
Supermotors Pics
Old 02-14-2013, 10:24 AM   #17
BigBud
BigBud's Avatar
Bronco Info: No bronco for now
The 4 spd on the 390 will not work for you. Wrong bell housing and shift fork. What you need to convert a 79 to manual is: transmission tunnel for the floor or cut a big hole in yours, the pedal assembly the and the floor plate that allows the rod through, the frame and engine mounts for the clutch lever assembly (frame side should be standard, don't know if a 390 mount will bolt to 400-460 bolt pattern) and that lever, 400 flywheel and clutch, and drive lines. Seems like the trans mount is the same or needs to be flipped around. It sounds like a lot, but it is fairly straight forward.
79 Bronco 6" lift, mild 460, and 3/4 tons----Sold
94 F150 4x4 302 zf5spd swap----run about
97 F350 Crew Cab 4x4 6" lift and 35" muds---work beast
BigBud is offline   Reply With Quote
Old 02-14-2013, 10:26 AM   #18
BigBud
BigBud's Avatar
If the 390 is a runner, why not just swap the whole setup?
Old 02-14-2013, 10:38 AM   #19
BigCheeseStick
BigCheeseStick's Avatar
Bronco Info: '94 XL 5.0, 5 speed
Having done more than a fair share of off roading in both auto and stick trucks. And being a person who can't stand driving auto's at ALL on the street (my Bronco's a stick), auto's RULE for off road. Torque converter gives them more off idle grunt, and when (NOT IF) you need to rock it out of a hole, its ridiculous even trying in a stick. Takes so long to get from 1st to Rev. and work the clutch, that the truck has lost the little bit of momentum you gained = worthless. Plus off roading a stick = TORTURING the clutch.
Obviously this is subject to opinion (go ahead silly nerds.. RANT), and because all the other benefits of owning a stick, I'd NEVER buy an auto..
One more thing I'd say is DON'T believe most of the bashing the M5R2 gets on here. There are plenty of guys racing highly modified Super Coupes with them, even others using them behind small diesels in trucks! They are a half ton truck trans., and a good one. NOT a one ton truck trans.. If it'll stand up to the uses above... What is it you have in mind that would be worse?!? If it IS worse, then ZF all the way. :)
BigCheeseStick is offline   Reply With Quote
Old 02-14-2013, 10:58 AM   #20
AbandonedBronco
Big Six
From what I usually hear, the M5R2 gets a bad rap because of the design flaw where they leak from the plugs, so most of them are burnt up, or close to it.
I'd say auto vs. manual depends on the type of off-roading you do. For me, I do a lot of camping, and trail crawling, so I'm not commonly stuck. A granny gear and low range is amazing for winding my way up steep old mining roads and picking my way around rocks and ruts. I'd hate to be doing that in an auto. For the few times I have been stuck, rocking myself out with a manual wasn't anything that ever made just wish it was an automatic at the moment.
Now for mudding, rock crawling, etc. etc. I can see an auto being really beneficial.
Supermotors Pics
You may not post replies
Forum Jump
