Lock cylinder kits? - FSB Forums
Thread Tools Display Modes
Old 02-13-2013, 01:54 PM   #1
Tx_007
Bronco Info: 83, 351w 33x12r15
Lock cylinder kits?
Is there any place that sells a 4 piece kit?
Ignition, tailgate, and doors that work with the same key(s)?
Or another way to fix the problem?
Tx_007 is offline   Reply With Quote
Old 02-13-2013, 02:58 PM   #2
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
Bronco Info: '89 Bronco, 5.8, MAF, Summit shorties, Bassani SS, AOD, Tru-trac posi, Stocker
You didnt really describe the problem.
1) You can buy new locksets on Ebay (some NOS, OEM)
2) you can take yours to an automotive locksmith and have him fix cut new keys or repin them.
3) Visit the j/y and find a good used set (unlikely)
4) visit the j/y and get whatever (if any) might be broken on yours, and have a locksmith repin it.
There is no easy 'one key' solution to your problem.
Recommendation would be based on your budget, time factor, desire to remove any/all locks and access to a j/y ....among other things.
Click HERE to visit my frame-off NOS restoration thread.
Photobucket Album ....and a crap load of pictures....
j. r. Nice is offline   Reply With Quote
Old 02-13-2013, 04:18 PM   #3
Steve83
Steve83's Avatar
No. http://www.fullsizebronco.com/forum/...d.php?t=218042
Old 02-13-2013, 04:28 PM   #4
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Cool thread. :)
My '75 F150 uses only one key.
My '91 Bronco uses two keys.
J.R. is it possible to swap any of those "ignition key using" older door lock
cylinders into the '91? :) Did Ford change things too much to do that?
I'm especially wondering about the tailgate lock. It's not so much I want-to
as much as if the opportunity arises I might try it. :) I guess what I'm really
asking is...
In your opinion, should I collect those parts or leave 'em be? :)
The '90 F250 ZF parts truck and '91 Bronco had the exact-same door key
pattern. LOL :)
I swapped pins around in a "like new" '75 C700's lock/ignition switch and
installed it in the Bronco and so the Bronco uses the same key as the '75
F150 I bought new...
^it need at least two added relays to make that work IMO. I used three.
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 02-13-2013, 05:30 PM   #5
Tx_007
Will the door cylinders fit the tailgate as well?
Old 02-13-2013, 05:44 PM   #6
Tx_007
Problem
I bought an 83 bronco that has 4 keys and none match the tailgate I would like to narrow the keys down to at least 2.
Old 02-13-2013, 05:51 PM   #7
Tx_007
I have one key that fits the ignition and one key for the 2 doors one lock on the passenger side doesn't work, an I have no key for the tailgate..
Old 02-13-2013, 06:50 PM   #8
Steve83
Steve83's Avatar
No.
I bought an 83 bronco that has 4 keys and ...I would like to narrow the keys down to at least 2.
4 IS at least 2. Do you mean "no more than 2"? If you can't find a Bronco with its keys & locks in a local JY, go to a locksmith.
I have one key that fits the ignition and one key for the 2 doors..., an I have no key for the tailgate..
My 1st-Grade math is pretty rusty, but that sounds like 2 keys.
Old 02-13-2013, 08:29 PM   #9
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
Originally Posted by Alvin in AZ View Post
Cool thread. :)
asking is...
Alvin in AZ
You can use the older door locks in your '91.
You can collect spares and donors, but just make sure you mark them as to application (year, make, model, left, right, front rear etc). You'd be surprised how similar they look in a pile.
Collecting tailgate locks (actually any lock) would only do you good if you can make keys or repin them. Helps to be able to cut fresh keys and not try to re-pin to older, worn out keys.
You could probably even sell them without a key. Not sure if that's what you were asking.....
You could make them physically fit the opening, but the extension / tailpiece that actuates the window switch won't fit the door lock.
Sounds like someone swapped some parts around. Probably as a result of an accident. Sometimes they just seize from dirt and lack of use, etc.
On yours the ignition is one key ("square") and everything else is supposed to be another ("round"). If the driver's door works, pull the passenger and the t/g lock and take them to a locksmith to have them re-pinned to the drivers side.
Before you pull them, lube them with graphite, and try the only round key you have in the passenger and tailgate lock. After you try the key one way, make sure to flip it over and try the other side.
Sometimes getting a correctly cut key (to factory specs) will resolve an issue.
If your driver's side key or lock shows a lot of wear, you might be as well off having it refreshed too. You could also consider going on Ebay and looking for a set. I checked a while ago and they run about $70.
Old 02-13-2013, 09:16 PM   #10
Tx_007
My bad I was in a hurry
There are 2 keys for the doors, one for the ignition, and one key for the gas tank but it doesn't count I have so many Keys I feel like a janitor, cause I have two hitch locks and a bike lock key, none of those count.
I want one key that fits the ignition, tailgate and the doors my bad.
I can't count, I just guessed it was 4 keys I've only had the truck a day or two and have 11 keys i just counted alltogether not counting my mustang keys that I am leaving at home
Old 02-13-2013, 09:19 PM   #11
Tx_007
P.s.
Did I mention I can't count? Haha
Old 02-13-2013, 10:21 PM   #12
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
More than likely you will end up with 2 keys for the Bronco. Depending on the year of the Mustang, you might be able to consolidate. If it's newer, not gonna happen.
Old 02-14-2013, 01:00 AM   #13
Steve83
Steve83's Avatar
I want one key that fits the ignition, tailgate and the doors...
Ain't gonna happen with stock parts. All Bronco t/g lock cylinders use a round key; all ignitions use square; ne'er the twain shall meet.
Old 02-14-2013, 07:49 AM   #14
Tx_007
That sucks, so is there an easy/ do it yourself way of getting a new lock cylinder for the tailgate that does have a key?
I kinda want to replace the motor in the back window with a new one as well and have not been able to find a new/ remanufactured one at a local level I was told that some times it doesn't roll up and needs help, if I just lubricated things in there would that work?
Old 02-14-2013, 08:28 AM   #15
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
Not accurate. But not readily available.
You can re-read my first post to you.
1) Easiest? call a locksmith, pay a service call or take the truck to him, and let him fit one.
2) or pull it, take the t/g lock to him and let him fit one.
3) Buy one (new / used) with a proper key and replace it when you do the motor.
You can find them periodically on Ebay and on the ads here on FSB.
I've sold several, but you need 75 posts to view the ads.
It might help to lube the mechanism, but considering it's age, it probably neds replaced.
Old 02-14-2013, 12:53 PM   #16
Tx_007
I've never dealt with a lock smith, what would that cost for him to make a new key?
I found some motors on the bronco graveyard site that look good has anyone bought from them before and maybe had a exp?
Old 02-14-2013, 03:37 PM   #17
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
If you pull it, maybe as little as $20-25. Rekeying a door or trunk (t/g) about the same.
You have several options, ask him what would be cheaper. If your driver side door key works, just have him rekey the pass door and t/g to that. It should be the same keyway.
That would be absent finding a used set keyed alike. A new set (without ignition) would probably be $70. Again, check Ebay., sometimes there are some really good deals.
Old 02-15-2013, 03:44 AM   #18
Steve83
Steve83's Avatar
Click my black Bronco in my signature & read the captions in the Tailgate Tech album.
Old 02-16-2013, 03:28 PM   #19
Tx_007
Thanks Steve, some detail in those albums,
I have seen a truck tent on jc Whitney that supposedly fits a bronco but I don't really believe it, you think they make tents for broncos?
Old 02-16-2013, 04:38 PM   #20
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
HEY look Steve, he doesn't like having extra keys........
You may not post replies
Forum Jump
